[U-Boot] [PATCH 1/2] config_fallbacks: Add a default entry for CONFIG_SYS_PBSIZE
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the characters of the error message: "Unknown command '' - try 'help'".
Provide a default size for CONFIG_SYS_PBSIZE so that it can store the error message and allows the error message to be printed correctly with no hang.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/config_fallbacks.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 7d8daa2..508db56 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -79,6 +79,10 @@ #define CONFIG_SYS_PROMPT "=> " #endif
+#ifndef CONFIG_SYS_PBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + 128) +#endif + #ifndef CONFIG_FIT_SIGNATURE #define CONFIG_IMAGE_FORMAT_LEGACY #endif
Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx6sabre_common.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 9fdd841..f0f721e 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -220,9 +220,6 @@ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
