I'm trying to build u-boot-1.1.3 for use with skyeye-1.0.0 (an ARM simulator) and was hoping to get tips and help building it from people who've done it before or know how. I'm building my own toolchain using the buildchain script written by Chip Coldwell http://frank.harvard.edu/~coldwell/toolchain/ (gcc-2.4.4, glibc-2.3.5, linux-2.6.10). Unfortunately, I end up with a gcc compiler with a libgcc.a that's compiled to use hardware FP.
Could someone tell me how to rebuild gcc to avoid that problem with u-boot? Is there an elegant way of keeping two versions of gcc (one that uses hardware FP and one that uses software FP) for when I need to build code for the actual board?
Thanks for any help. --
Richard Plana Zi Corporation
In message 378D4198C6A64E4595DC307634CDF3B801B3B292@zicgy-ms00.zi.ziroot.com you wrote:
This is not a place to discuss "how do I build my own toolchain" problems. There are existing, known to be working toolchains (like the EKLDK), there are working build scripts (like crosstools), etc. Many working options. If you chose to use a non-working one this is off topic here.
Why would you need HW FP for a ARM system? Have you access to an ARM processor with FPU? Which one is this?
Richard Plana
