[U-Boot] [PATCH] fs: btrfs: Fix tree traversal with btrfs_next_slot()
When traversing slots in a btree (via btrfs_path) with btrfs_next_slot(), we didn't correctly identify that the last slot in the leaf was reached and we should jump to the next leaf.
This could lead to any kind of runtime errors or corruptions, like: * file data not being read at all, or is read partially * file is read but is corrupted * (any) metadata being corrupted or not read at all, etc
The easiest way to reproduce this is to read a large enough file that its EXTENT_DATA items don't fit into a single leaf.
Signed-off-by: Yevgeny Popovych yevgenyp@pointgrab.com Cc: Marek Behun marek.behun@nic.cz --- fs/btrfs/ctree.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/btrfs/ctree.c b/fs/btrfs/ctree.c index 4da36a9..b44a47e 100644 --- a/fs/btrfs/ctree.c +++ b/fs/btrfs/ctree.c @@ -270,7 +270,7 @@ int btrfs_next_slot(struct btrfs_path *p) { struct btrfs_leaf *leaf = &p->nodes[0]->leaf;
- if (p->slots[0] >= leaf->header.nritems) + if (p->slots[0] + 1 >= leaf->header.nritems) return jump_leaf(p, 1);
p->slots[0]++;
Just a kindly reminder :)
- file data not being read at all, or is read partially
- file is read but is corrupted
- (any) metadata being corrupted or not read at all, etc
p->slots[0]++;
I shall test this today or tomorrow, but have too many things on my head, sorry :( You saying that this will fix reading large files? I haven't encountered such an error yet, but can try creating a large enough file. How large should it be?
On Mon, 1 Oct 2018 08:50:11 +0300 Yevgeny Popovych yevgenyp@pointgrab.com wrote:
p->slots[0]++;
Hi Marek,
No hurry from my side, please take your time!
I think that might be the case for every file that is > 32 MiB but it definitely depends on filesystem layout (other files) and maybe some options (my EXTENT_DATA describe blocks of 1MiB size)? This also can happen to almost any file that is > 1 MiB given that there are enough files + some luck.
Bottom line - create a 50MiB file and add 50 2 MiB files to the filesystem. I would expect that to create necessary conditions. After trying to read the file - check file checksum (no guarantee that it will end up with an error).
You can inspect FS with dump-tree to check if EXTENT_DATA items of this inode (large file) is split across the tree leaves.
Thanks!
p->slots[0]++;
Tested-by: Marek Behún marek.behun@nic.cz
Hello Tom, could you please apply the patch by Yevgeny?
Marek
On Fri, 7 Sep 2018 12:59:30 +0300 Yevgeny Popovych yevgenyp@pointgrab.com wrote:
p->slots[0]++;
Sorry, I'll just lament that patchwork no longer has the ability to list unassigned patches anymore. I've given this to myself in patchwork and will pick it up shortly. Thanks!
Marek
p->slots[0]++;
Signed-off-by: Yevgeny Popovych yevgenyp@pointgrab.com Cc: Marek Behun marek.behun@nic.cz Tested-by: Marek Behún marek.behun@nic.cz
Marek Behún
Yevgeny Popovych
