[U-Boot] Multiple stdin/out without CONFIG_CONSOLE_MUX?
Mathieu, John,
While looking into a CONFIG_CONSOLE_MUX-related issue, I noticed the following:
include/configs/u8500_href.h:136: "stdin=serial,usbtty\0" include/configs/u8500_href.h:135: "stdout=serial,usbtty\0" include/configs/snowball.h:180: "stdout=serial,usbtty\0"
Those all include multiple devices in the stdin/stdout definitions. However, those config files don't set CONFIG_CONSOLE_MUX. I assume this causes usbtty to be ignored, and only serial used?
Or perhaps U-Boot even fails to parse the variable at all, since CONFIG_SYS_CONSOLE_IS_IN_ENV isn't set on those boards? Actually, there are a few more boards with that problem:
include/configs/km/keymile-common.h:258: "stdout=serial\0" \ include/configs/MVBC_P.h:146: "stdout=serial\0" \ include/configs/MVBLM7.h:460: "stdout=serial\0" \ include/configs/MVSMR.h:129: "stdout=serial\0" \ include/configs/sandbox.h:91: "stdout=serial\0" \ include/configs/snowball.h:180: "stdout=serial,usbtty\0" \ include/configs/u8500_href.h:135: "stdout=serial,usbtty\0" \
Hi Stephen,
I actually didn't get the point whats the problem here, but you are right our boards have stdin,stdout,stderr defined in their environment. It seems to be unneeded here. Maybe it is caused because we used CONFIG_CONSOLE_MUX in the past but the relevant code was dropped at some point.
So we can remove these variables from our boards completely. Thanks for pointing out.
Regards Holger
Stephen,
same for mvBC_P, mvBLM7 and mvSMR.
yes - and I don't mind if anybody else does this during mass cleanup ... as long as the boards keep working properly ;-)
Regards, André
MATRIX VISION GmbH, Talstrasse 16, DE-71570 Oppenweiler Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschaeftsfuehrer: Gerhard Thullner, Werner Armingeon, Uwe Furtner, Erhard Meier
Andre Schwarz
Holger Brunck
Stephen Warren
