[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
pleas pull from u-boot-imx, thanks !
The following changes since commit 21866c34a1b4098a8868c9250daf01baf84c2397:
at91sam9rlek_mmc_defconfig: Add CONFIG_ARCH_AT91=y (2015-03-20 10:47:38 -0400)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 3bf801a2176e3330a3ef696d974d0d198d99b7e9:
ARM: mx5: add support for USB armory board (2015-04-09 09:14:12 +0200)
---------------------------------------------------------------- Andrej Rosano (2): ARM: mx5: move to a standard arch/board approach ARM: mx5: add support for USB armory board
Boris BREZILLON (3): ARM: mx6: move to a standard arch/board approach ARM: iMX: define an IMX_CONFIG Kconfig option board/seco: Add mx6q-uq7 basic board support
Fabio Estevam (1): mx53loco: Disable printing cpuinfo
Peng Fan (2): imx:mx6dlsabresd fix error detecting thermal imx:mx6slevk support reading temperature
Sebastian Siewior (1): watchdog/imx_watchdog: do not set WCR_WDW
Ulises Cardenas (1): Fix mxc_hab documenation for DEK blob generation
arch/arm/Kconfig | 14 ++ arch/arm/cpu/armv7/mx5/Kconfig | 27 ++ arch/arm/cpu/armv7/mx6/Kconfig | 42 ++++ arch/arm/imx-common/Kconfig | 2 + board/freescale/mx53loco/mx53loco.c | 1 - board/inversepath/usbarmory/Kconfig | 15 ++ board/inversepath/usbarmory/MAINTAINERS | 6 + board/inversepath/usbarmory/Makefile | 10 + board/inversepath/usbarmory/imximage.cfg | 82 ++++++ board/inversepath/usbarmory/usbarmory.c | 417 +++++++++++++++++++++++++++++++ board/seco/Kconfig | 63 +++++ board/seco/common/Makefile | 2 + board/seco/common/mx6.c | 138 ++++++++++ board/seco/common/mx6.h | 9 + board/seco/mx6quq7/MAINTAINERS | 6 + board/seco/mx6quq7/Makefile | 7 + board/seco/mx6quq7/mx6quq7-2g.cfg | 173 +++++++++++++ board/seco/mx6quq7/mx6quq7.c | 162 ++++++++++++ configs/mx6dlsabresd_defconfig | 2 + configs/mx6slevk_defconfig | 4 + configs/mx6slevk_spinor_defconfig | 4 + configs/secomx6quq7_defconfig | 7 + configs/usbarmory_defconfig | 3 + doc/README.mxc_hab | 1 + drivers/watchdog/imx_watchdog.c | 3 +- include/configs/mx53loco.h | 2 - include/configs/mx6slevk.h | 7 + include/configs/secomx6quq7.h | 166 ++++++++++++ include/configs/usbarmory.h | 126 ++++++++++ 29 files changed, 1496 insertions(+), 5 deletions(-) create mode 100644 arch/arm/cpu/armv7/mx5/Kconfig create mode 100644 arch/arm/cpu/armv7/mx6/Kconfig create mode 100644 arch/arm/imx-common/Kconfig create mode 100644 board/inversepath/usbarmory/Kconfig create mode 100644 board/inversepath/usbarmory/MAINTAINERS create mode 100644 board/inversepath/usbarmory/Makefile create mode 100644 board/inversepath/usbarmory/imximage.cfg create mode 100644 board/inversepath/usbarmory/usbarmory.c create mode 100644 board/seco/Kconfig create mode 100644 board/seco/common/Makefile create mode 100644 board/seco/common/mx6.c create mode 100644 board/seco/common/mx6.h create mode 100644 board/seco/mx6quq7/MAINTAINERS create mode 100644 board/seco/mx6quq7/Makefile create mode 100644 board/seco/mx6quq7/mx6quq7-2g.cfg create mode 100644 board/seco/mx6quq7/mx6quq7.c create mode 100644 configs/secomx6quq7_defconfig create mode 100644 configs/usbarmory_defconfig create mode 100644 include/configs/secomx6quq7.h create mode 100644 include/configs/usbarmory.h
On Mon, Apr 13, 2015 at 08:36:53AM +0200, Stefano Babic wrote:
Hi Tom,
Please note this adds a warning: w+(mx53loco) ../arch/arm/imx-common/cpu.c:29:14: warning: 'get_reset_cause' defined but not used [-Wunused-function]
But looking over the commits, yes, it's best to not give misleading information during startup, so..
Stefano Babic
