[PATCH v2] arm: dts: armada-37xx: update devicetrees from linux
Update existing armada-37xx DTS files with those in linux v6.8 and add devicetree for ESPRESSObin Ultra device.
Signed-off-by: Benjamin Schneider ben@bens.haus ---
Changes in v2: - upstream is missing a patch for PCIe mem
arch/arm/dts/armada-3720-db.dts | 6 +- .../arm/dts/armada-3720-espressobin-ultra.dts | 167 ++++++++++++++++++ arch/arm/dts/armada-3720-espressobin.dts | 2 +- arch/arm/dts/armada-3720-espressobin.dtsi | 22 ++- arch/arm/dts/armada-3720-turris-mox.dts | 133 +++++++------- arch/arm/dts/armada-3720-uDPU.dts | 8 +- arch/arm/dts/armada-3720-uDPU.dtsi | 8 +- arch/arm/dts/armada-372x.dtsi | 2 +- arch/arm/dts/armada-37xx.dtsi | 24 ++- 9 files changed, 284 insertions(+), 88 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-ultra.dts
diff --git a/arch/arm/dts/armada-3720-db.dts b/arch/arm/dts/armada-3720-db.dts index 1ee92406b7..0cfb384920 100644 --- a/arch/arm/dts/armada-3720-db.dts +++ b/arch/arm/dts/armada-3720-db.dts @@ -18,7 +18,7 @@
/ { model = "Marvell Armada 3720 Development Board DB-88F3720-DDR3"; - compatible = "marvell,armada-3720-db", "marvell,armada3720", "marvell,armada3710"; + compatible = "marvell,armada-3720-db", "marvell,armada3720", "marvell,armada3700";
chosen { stdout-path = "serial0:115200n8"; @@ -164,7 +164,7 @@ pinctrl-names = "default"; pinctrl-0 = <&spi_quad_pins>;
- m25p80@0 { + flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <108000000>; @@ -180,7 +180,7 @@ reg = <0x0 0x200000>; }; partition@200000 { - label = "U-Boot Env"; + label = "U-boot Env"; reg = <0x200000 0x10000>; }; partition@210000 { diff --git a/arch/arm/dts/armada-3720-espressobin-ultra.dts b/arch/arm/dts/armada-3720-espressobin-ultra.dts new file mode 100644 index 0000000000..870bb380a4 --- /dev/null +++ b/arch/arm/dts/armada-3720-espressobin-ultra.dts @@ -0,0 +1,167 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for ESPRESSObin-Ultra board. + * Copyright (C) 2019 Globalscale technologies, Inc. + * + * Jason Hung jhung@globalscaletechnologies.com + */ + +/dts-v1/; + +#include "armada-3720-espressobin.dtsi" + +/ { + model = "Globalscale Marvell ESPRESSOBin Ultra Board"; + compatible = "globalscale,espressobin-ultra", "globalscale,espressobin", + "marvell,armada3720", "marvell,armada3700"; + + aliases { + /* ethernet1 is WAN port */ + ethernet1 = &switch0port5; + ethernet2 = &switch0port1; + ethernet3 = &switch0port2; + ethernet4 = &switch0port3; + ethernet5 = &switch0port4; + }; + + /delete-node/ regulator; + + reg_usb3_vbus: usb3-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb3-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&gpionb 19 GPIO_ACTIVE_HIGH>; + }; + + usb3_phy: usb3-phy { + compatible = "usb-nop-xceiv"; + vcc-supply = <®_usb3_vbus>; + }; + + gpio-leds { + pinctrl-names = "default"; + compatible = "gpio-leds"; + /* No assigned functions to the LEDs by default */ + led1 { + label = "ebin-ultra:blue:led1"; + gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; + }; + led2 { + label = "ebin-ultra:green:led2"; + gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; + }; + led3 { + label = "ebin-ultra:red:led3"; + gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; + }; + led4 { + label = "ebin-ultra:yellow:led4"; + gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&sdhci0 { + status = "okay"; +}; + +&sdhci1 { + /delete-property/ vqmmc-supply; + status = "disabled"; +}; + +&spi0 { + flash@0 { + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "firmware"; + reg = <0x0 0x3e0000>; + }; + partition@3e0000 { + label = "hw-info"; + reg = <0x3e0000 0x10000>; + read-only; + }; + partition@3f0000 { + label = "u-boot-env"; + reg = <0x3f0000 0x10000>; + }; + }; + }; +}; + +&i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + + clock-frequency = <100000>; + + rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&usb3 { + usb-phy = <&usb3_phy>; +}; + +&mdio { + extphy: ethernet-phy@1 { + reg = <1>; + + reset-gpios = <&gpionb 2 GPIO_ACTIVE_LOW>; + }; +}; + +&switch0 { + reg = <3>; + + reset-gpios = <&gpiosb 23 GPIO_ACTIVE_LOW>; + + ethernet-ports { + switch0port1: ethernet-port@1 { + reg = <1>; + label = "lan0"; + phy-handle = <&switch0phy0>; + }; + + switch0port2: ethernet-port@2 { + reg = <2>; + label = "lan1"; + phy-handle = <&switch0phy1>; + }; + + switch0port3: ethernet-port@3 { + reg = <3>; + label = "lan2"; + phy-handle = <&switch0phy2>; + }; + + switch0port4: ethernet-port@4 { + reg = <4>; + label = "lan3"; + phy-handle = <&switch0phy3>; + }; + + switch0port5: ethernet-port@5 { + reg = <5>; + label = "wan"; + phy-handle = <&extphy>; + phy-mode = "sgmii"; + }; + }; + + mdio { + switch0phy3: ethernet-phy@14 { + reg = <0x14>; + }; + }; +}; diff --git a/arch/arm/dts/armada-3720-espressobin.dts b/arch/arm/dts/armada-3720-espressobin.dts index 1542d836c0..c5a834b33b 100644 --- a/arch/arm/dts/armada-3720-espressobin.dts +++ b/arch/arm/dts/armada-3720-espressobin.dts @@ -16,5 +16,5 @@
/ { model = "Globalscale Marvell ESPRESSOBin Board"; - compatible = "globalscale,espressobin", "marvell,armada3720", "marvell,armada3710"; + compatible = "globalscale,espressobin", "marvell,armada3720", "marvell,armada3700"; }; diff --git a/arch/arm/dts/armada-3720-espressobin.dtsi b/arch/arm/dts/armada-3720-espressobin.dtsi index 5fc613d241..fed2dcecb3 100644 --- a/arch/arm/dts/armada-3720-espressobin.dtsi +++ b/arch/arm/dts/armada-3720-espressobin.dtsi @@ -13,7 +13,7 @@ / { aliases { ethernet0 = ð0; - /* for dsa slave device */ + /* for DSA user port device */ ethernet1 = &switch0port1; ethernet2 = &switch0port2; ethernet3 = &switch0port3; @@ -145,19 +145,17 @@ };
&mdio { - switch0: switch0@1 { + switch0: ethernet-switch@1 { compatible = "marvell,mv88e6085"; - #address-cells = <1>; - #size-cells = <0>; reg = <1>;
dsa,member = <0 0>;
- ports { + ethernet-ports { #address-cells = <1>; #size-cells = <0>;
- switch0port0: port@0 { + switch0port0: ethernet-port@0 { reg = <0>; label = "cpu"; ethernet = <ð0>; @@ -168,19 +166,19 @@ }; };
- switch0port1: port@1 { + switch0port1: ethernet-port@1 { reg = <1>; label = "wan"; phy-handle = <&switch0phy0>; };
- switch0port2: port@2 { + switch0port2: ethernet-port@2 { reg = <2>; label = "lan0"; phy-handle = <&switch0phy1>; };
- switch0port3: port@3 { + switch0port3: ethernet-port@3 { reg = <3>; label = "lan1"; phy-handle = <&switch0phy2>; @@ -192,13 +190,13 @@ #address-cells = <1>; #size-cells = <0>;
- switch0phy0: switch0phy0@11 { + switch0phy0: ethernet-phy@11 { reg = <0x11>; }; - switch0phy1: switch0phy1@12 { + switch0phy1: ethernet-phy@12 { reg = <0x12>; }; - switch0phy2: switch0phy2@13 { + switch0phy2: ethernet-phy@13 { reg = <0x13>; }; }; diff --git a/arch/arm/dts/armada-3720-turris-mox.dts b/arch/arm/dts/armada-3720-turris-mox.dts index 595b4b5abb..f1a9f22343 100644 --- a/arch/arm/dts/armada-3720-turris-mox.dts +++ b/arch/arm/dts/armada-3720-turris-mox.dts @@ -14,7 +14,7 @@ / { model = "CZ.NIC Turris Mox Board"; compatible = "cznic,turris-mox", "marvell,armada3720", - "marvell,armada3710"; + "marvell,armada3700";
aliases { spi0 = &spi0; @@ -35,7 +35,7 @@
leds { compatible = "gpio-leds"; - red { + led { label = "mox:red:activity"; gpios = <&gpiosb 21 GPIO_ACTIVE_LOW>; linux,default-trigger = "default-on"; @@ -45,7 +45,7 @@ gpio-keys { compatible = "gpio-keys";
- reset { + key-reset { label = "reset"; linux,code = <KEY_RESTART>; gpios = <&gpiosb 20 GPIO_ACTIVE_LOW>; @@ -100,11 +100,11 @@ sfp: sfp { compatible = "sff,sfp"; i2c-bus = <&i2c0>; - los-gpio = <&moxtet_sfp 0 GPIO_ACTIVE_HIGH>; - tx-fault-gpio = <&moxtet_sfp 1 GPIO_ACTIVE_HIGH>; - mod-def0-gpio = <&moxtet_sfp 2 GPIO_ACTIVE_LOW>; - tx-disable-gpio = <&moxtet_sfp 4 GPIO_ACTIVE_HIGH>; - rate-select0-gpio = <&moxtet_sfp 5 GPIO_ACTIVE_HIGH>; + los-gpios = <&moxtet_sfp 0 GPIO_ACTIVE_HIGH>; + tx-fault-gpios = <&moxtet_sfp 1 GPIO_ACTIVE_HIGH>; + mod-def0-gpios = <&moxtet_sfp 2 GPIO_ACTIVE_LOW>; + tx-disable-gpios = <&moxtet_sfp 4 GPIO_ACTIVE_HIGH>; + rate-select0-gpios = <&moxtet_sfp 5 GPIO_ACTIVE_HIGH>; maximum-power-milliwatt = <3000>;
/* enabled by U-Boot if SFP module is present */ @@ -125,9 +125,12 @@ /delete-property/ mrvl,i2c-fast-mode; status = "okay";
+ /* MCP7940MT-I/MNY RTC */ rtc@6f { compatible = "microchip,mcp7940x"; reg = <0x6f>; + interrupt-parent = <&gpiosb>; + interrupts = <5 IRQ_TYPE_EDGE_FALLING>; /* GPIO2_5 */ }; };
@@ -136,6 +139,7 @@ pinctrl-0 = <&pcie_reset_pins &pcie_clkreq_pins>; status = "okay"; reset-gpios = <&gpiosb 3 GPIO_ACTIVE_LOW>; + slot-power-limit-milliwatt = <10000>; /* * U-Boot port for Turris Mox has a bug which always expects that "ranges" DT property * contains exactly 2 ranges with 3 (child) address cells, 2 (parent) address cells and @@ -144,7 +148,7 @@ * no remapping) and that this address is the lowest from all specified ranges. If these * conditions are not met then U-Boot crashes during loading kernel DTB file. PCIe address * space is 128 MB long, so the best split between MEM and IO is to use fixed 16 MB window - * for IO and the rest 112 MB (64+32+16) for MEM. Controller supports 32-bit IO mapping. + * for IO and the rest 112 MB (64+32+16) for MEM, despite that maximal IO size is just 64 kB. * This bug is not present in U-Boot ports for other Armada 3700 devices and is fixed in * U-Boot version 2021.07. See relevant U-Boot commits (the last one contains fix): * https://source.denx.de/u-boot/u-boot/-/commit/cb2ddb291ee6fcbddd6d8f4ff49089... @@ -211,7 +215,7 @@ assigned-clock-parents = <&tbg 1>; assigned-clock-rates = <20000000>;
- spi-flash@0 { + flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; @@ -300,10 +304,16 @@ reg = <1>; };
- /* switch nodes are enabled by U-Boot if modules are present */ + /* + * NOTE: switch nodes are enabled by U-Boot if modules are present + * DO NOT change this node name (switch0@10) even if it is not following + * conventions! Deployed U-Boot binaries are explicitly looking for + * this node in order to augment the device tree! + * Also do not touch the "ports" or "port@n" nodes. These are also ABI. + */ switch0@10 { - compatible = "marvell,mv88e6190"; - reg = <0x10 0>; + compatible = "marvell,turris-mox-mv88e6190", "marvell,mv88e6190"; + reg = <0x10>; dsa,member = <0 0>; interrupt-parent = <&moxtet>; interrupts = <MOXTET_IRQ_PERIDOT(0)>; @@ -313,35 +323,35 @@ #address-cells = <1>; #size-cells = <0>;
- switch0phy1: switch0phy1@1 { + switch0phy1: ethernet-phy@1 { reg = <0x1>; };
- switch0phy2: switch0phy2@2 { + switch0phy2: ethernet-phy@2 { reg = <0x2>; };
- switch0phy3: switch0phy3@3 { + switch0phy3: ethernet-phy@3 { reg = <0x3>; };
- switch0phy4: switch0phy4@4 { + switch0phy4: ethernet-phy@4 { reg = <0x4>; };
- switch0phy5: switch0phy5@5 { + switch0phy5: ethernet-phy@5 { reg = <0x5>; };
- switch0phy6: switch0phy6@6 { + switch0phy6: ethernet-phy@6 { reg = <0x6>; };
- switch0phy7: switch0phy7@7 { + switch0phy7: ethernet-phy@7 { reg = <0x7>; };
- switch0phy8: switch0phy8@8 { + switch0phy8: ethernet-phy@8 { reg = <0x8>; }; }; @@ -426,9 +436,10 @@ }; };
+ /* NOTE: this node name is ABI, don't change it! */ switch0@2 { - compatible = "marvell,mv88e6085"; - reg = <0x2 0>; + compatible = "marvell,turris-mox-mv88e6085", "marvell,mv88e6085"; + reg = <0x2>; dsa,member = <0 0>; interrupt-parent = <&moxtet>; interrupts = <MOXTET_IRQ_TOPAZ>; @@ -438,19 +449,19 @@ #address-cells = <1>; #size-cells = <0>;
- switch0phy1_topaz: switch0phy1@11 { + switch0phy1_topaz: ethernet-phy@11 { reg = <0x11>; };
- switch0phy2_topaz: switch0phy2@12 { + switch0phy2_topaz: ethernet-phy@12 { reg = <0x12>; };
- switch0phy3_topaz: switch0phy3@13 { + switch0phy3_topaz: ethernet-phy@13 { reg = <0x13>; };
- switch0phy4_topaz: switch0phy4@14 { + switch0phy4_topaz: ethernet-phy@14 { reg = <0x14>; }; }; @@ -493,9 +504,10 @@ }; };
+ /* NOTE: this node name is ABI, don't change it! */ switch1@11 { - compatible = "marvell,mv88e6190"; - reg = <0x11 0>; + compatible = "marvell,turris-mox-mv88e6190", "marvell,mv88e6190"; + reg = <0x11>; dsa,member = <0 1>; interrupt-parent = <&moxtet>; interrupts = <MOXTET_IRQ_PERIDOT(1)>; @@ -505,35 +517,35 @@ #address-cells = <1>; #size-cells = <0>;
- switch1phy1: switch1phy1@1 { + switch1phy1: ethernet-phy@1 { reg = <0x1>; };
- switch1phy2: switch1phy2@2 { + switch1phy2: ethernet-phy@2 { reg = <0x2>; };
- switch1phy3: switch1phy3@3 { + switch1phy3: ethernet-phy@3 { reg = <0x3>; };
- switch1phy4: switch1phy4@4 { + switch1phy4: ethernet-phy@4 { reg = <0x4>; };
- switch1phy5: switch1phy5@5 { + switch1phy5: ethernet-phy@5 { reg = <0x5>; };
- switch1phy6: switch1phy6@6 { + switch1phy6: ethernet-phy@6 { reg = <0x6>; };
- switch1phy7: switch1phy7@7 { + switch1phy7: ethernet-phy@7 { reg = <0x7>; };
- switch1phy8: switch1phy8@8 { + switch1phy8: ethernet-phy@8 { reg = <0x8>; }; }; @@ -618,9 +630,10 @@ }; };
+ /* NOTE: this node name is ABI, don't change it! */ switch1@2 { - compatible = "marvell,mv88e6085"; - reg = <0x2 0>; + compatible = "marvell,turris-mox-mv88e6085", "marvell,mv88e6085"; + reg = <0x2>; dsa,member = <0 1>; interrupt-parent = <&moxtet>; interrupts = <MOXTET_IRQ_TOPAZ>; @@ -630,19 +643,19 @@ #address-cells = <1>; #size-cells = <0>;
- switch1phy1_topaz: switch1phy1@11 { + switch1phy1_topaz: ethernet-phy@11 { reg = <0x11>; };
- switch1phy2_topaz: switch1phy2@12 { + switch1phy2_topaz: ethernet-phy@12 { reg = <0x12>; };
- switch1phy3_topaz: switch1phy3@13 { + switch1phy3_topaz: ethernet-phy@13 { reg = <0x13>; };
- switch1phy4_topaz: switch1phy4@14 { + switch1phy4_topaz: ethernet-phy@14 { reg = <0x14>; }; }; @@ -685,9 +698,10 @@ }; };
+ /* NOTE: this node name is ABI, don't change it! */ switch2@12 { - compatible = "marvell,mv88e6190"; - reg = <0x12 0>; + compatible = "marvell,turris-mox-mv88e6190", "marvell,mv88e6190"; + reg = <0x12>; dsa,member = <0 2>; interrupt-parent = <&moxtet>; interrupts = <MOXTET_IRQ_PERIDOT(2)>; @@ -697,35 +711,35 @@ #address-cells = <1>; #size-cells = <0>;
- switch2phy1: switch2phy1@1 { + switch2phy1: ethernet-phy@1 { reg = <0x1>; };
- switch2phy2: switch2phy2@2 { + switch2phy2: ethernet-phy@2 { reg = <0x2>; };
- switch2phy3: switch2phy3@3 { + switch2phy3: ethernet-phy@3 { reg = <0x3>; };
- switch2phy4: switch2phy4@4 { + switch2phy4: ethernet-phy@4 { reg = <0x4>; };
- switch2phy5: switch2phy5@5 { + switch2phy5: ethernet-phy@5 { reg = <0x5>; };
- switch2phy6: switch2phy6@6 { + switch2phy6: ethernet-phy@6 { reg = <0x6>; };
- switch2phy7: switch2phy7@7 { + switch2phy7: ethernet-phy@7 { reg = <0x7>; };
- switch2phy8: switch2phy8@8 { + switch2phy8: ethernet-phy@8 { reg = <0x8>; }; }; @@ -801,9 +815,10 @@ }; };
+ /* NOTE: this node name is ABI, don't change it! */ switch2@2 { - compatible = "marvell,mv88e6085"; - reg = <0x2 0>; + compatible = "marvell,turris-mox-mv88e6085", "marvell,mv88e6085"; + reg = <0x2>; dsa,member = <0 2>; interrupt-parent = <&moxtet>; interrupts = <MOXTET_IRQ_TOPAZ>; @@ -813,19 +828,19 @@ #address-cells = <1>; #size-cells = <0>;
- switch2phy1_topaz: switch2phy1@11 { + switch2phy1_topaz: ethernet-phy@11 { reg = <0x11>; };
- switch2phy2_topaz: switch2phy2@12 { + switch2phy2_topaz: ethernet-phy@12 { reg = <0x12>; };
- switch2phy3_topaz: switch2phy3@13 { + switch2phy3_topaz: ethernet-phy@13 { reg = <0x13>; };
- switch2phy4_topaz: switch2phy4@14 { + switch2phy4_topaz: ethernet-phy@14 { reg = <0x14>; }; }; diff --git a/arch/arm/dts/armada-3720-uDPU.dts b/arch/arm/dts/armada-3720-uDPU.dts index a75734d88a..c76eceabd3 100644 --- a/arch/arm/dts/armada-3720-uDPU.dts +++ b/arch/arm/dts/armada-3720-uDPU.dts @@ -11,10 +11,10 @@ sfp_eth0: sfp-eth0 { compatible = "sff,sfp"; i2c-bus = <&i2c0>; - los-gpio = <&gpiosb 2 GPIO_ACTIVE_HIGH>; - mod-def0-gpio = <&gpiosb 3 GPIO_ACTIVE_LOW>; - tx-disable-gpio = <&gpiosb 4 GPIO_ACTIVE_HIGH>; - tx-fault-gpio = <&gpiosb 5 GPIO_ACTIVE_HIGH>; + los-gpios = <&gpiosb 2 GPIO_ACTIVE_HIGH>; + mod-def0-gpios = <&gpiosb 3 GPIO_ACTIVE_LOW>; + tx-disable-gpios = <&gpiosb 4 GPIO_ACTIVE_HIGH>; + tx-fault-gpios = <&gpiosb 5 GPIO_ACTIVE_HIGH>; maximum-power-milliwatt = <3000>; }; }; diff --git a/arch/arm/dts/armada-3720-uDPU.dtsi b/arch/arm/dts/armada-3720-uDPU.dtsi index 3f79923376..3a9b690718 100644 --- a/arch/arm/dts/armada-3720-uDPU.dtsi +++ b/arch/arm/dts/armada-3720-uDPU.dtsi @@ -61,10 +61,10 @@ sfp_eth1: sfp-eth1 { compatible = "sff,sfp"; i2c-bus = <&i2c1>; - los-gpio = <&gpiosb 7 GPIO_ACTIVE_HIGH>; - mod-def0-gpio = <&gpiosb 8 GPIO_ACTIVE_LOW>; - tx-disable-gpio = <&gpiosb 9 GPIO_ACTIVE_HIGH>; - tx-fault-gpio = <&gpiosb 10 GPIO_ACTIVE_HIGH>; + los-gpios = <&gpiosb 7 GPIO_ACTIVE_HIGH>; + mod-def0-gpios = <&gpiosb 8 GPIO_ACTIVE_LOW>; + tx-disable-gpios = <&gpiosb 9 GPIO_ACTIVE_HIGH>; + tx-fault-gpios = <&gpiosb 10 GPIO_ACTIVE_HIGH>; maximum-power-milliwatt = <3000>; }; }; diff --git a/arch/arm/dts/armada-372x.dtsi b/arch/arm/dts/armada-372x.dtsi index 5ce55bdbb9..02ae1e1532 100644 --- a/arch/arm/dts/armada-372x.dtsi +++ b/arch/arm/dts/armada-372x.dtsi @@ -13,7 +13,7 @@
/ { model = "Marvell Armada 3720 SoC"; - compatible = "marvell,armada3720", "marvell,armada3710"; + compatible = "marvell,armada3720", "marvell,armada3700";
cpus { cpu1: cpu@1 { diff --git a/arch/arm/dts/armada-37xx.dtsi b/arch/arm/dts/armada-37xx.dtsi index 0bb4f60763..923bea5c1c 100644 --- a/arch/arm/dts/armada-37xx.dtsi +++ b/arch/arm/dts/armada-37xx.dtsi @@ -35,6 +35,11 @@ reg = <0 0x4000000 0 0x200000>; no-map; }; + + tee@4400000 { + reg = <0 0x4400000 0 0x1000000>; + no-map; + }; };
cpus { @@ -132,10 +137,20 @@ reg = <0x11500 0x40>; };
+ uartclk: clock-controller@12010 { + compatible = "marvell,armada-3700-uart-clock"; + reg = <0x12010 0x4>, <0x12210 0x4>; + clocks = <&tbg 0>, <&tbg 1>, <&tbg 2>, + <&tbg 3>, <&xtalclk>; + clock-names = "TBG-A-P", "TBG-B-P", "TBG-A-S", + "TBG-B-S", "xtal"; + #clock-cells = <1>; + }; + uart0: serial@12000 { compatible = "marvell,armada-3700-uart"; reg = <0x12000 0x18>; - clocks = <&xtalclk>; + clocks = <&uartclk 0>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, @@ -147,7 +162,7 @@ uart1: serial@12200 { compatible = "marvell,armada-3700-uart-ext"; reg = <0x12200 0x30>; - clocks = <&xtalclk>; + clocks = <&uartclk 1>; interrupts = <GIC_SPI 30 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 31 IRQ_TYPE_EDGE_RISING>; @@ -434,7 +449,7 @@ #mbox-cells = <1>; };
- sdhci1: sdhci@d0000 { + sdhci1: mmc@d0000 { compatible = "marvell,armada-3700-sdhci", "marvell,sdhci-xenon"; reg = <0xd0000 0x300>, @@ -445,7 +460,7 @@ status = "disabled"; };
- sdhci0: sdhci@d8000 { + sdhci0: mmc@d8000 { compatible = "marvell,armada-3700-sdhci", "marvell,sdhci-xenon"; reg = <0xd8000 0x300>, @@ -489,6 +504,7 @@ bus-range = <0x00 0xff>; interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>; + clocks = <&sb_periph_clk 13>; msi-parent = <&pcie0>; msi-controller; /*
Benjamin Schneider
