[U-Boot] [PATCH] net: fec_mxc: add support for i.MX8X
Add compatible property and enable the FEC ipg clock when probing on i.MX8X. Add specific function for reading FEC clock rate via clock driver when configuring MII speed register. Allow FEC_MXC selection for i.MX8.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/Kconfig | 2 +- drivers/net/fec_mxc.c | 59 ++++++++++++++++++++++++++++++++++++++++--- drivers/net/fec_mxc.h | 4 +++ 3 files changed, 61 insertions(+), 4 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index f1f0e2d94e..39687431fb 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -176,7 +176,7 @@ config FEC_MXC_MDIO_BASE
config FEC_MXC bool "FEC Ethernet controller" - depends on MX5 || MX6 || MX7 + depends on MX5 || MX6 || MX7 || IMX8 help This driver supports the 10/100 Fast Ethernet controller for NXP i.MX processors. diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 5a1a8bc897..96fc733116 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -122,6 +122,32 @@ static int fec_mdio_read(struct ethernet_regs *eth, uint8_t phyaddr, return val; }
+static int fec_get_clk_rate(void *udev, int idx) +{ +#if IS_ENABLED(CONFIG_IMX8) + struct fec_priv *fec; + struct udevice *dev; + int ret; + + dev = udev; + if (!dev) { + ret = uclass_get_device(UCLASS_ETH, idx, &dev); + if (ret < 0) { + debug("Can't get FEC udev: %d\n", ret); + return ret; + } + } + + fec = dev_get_priv(dev); + if (fec) + return fec->clk_rate; + + return -EINVAL; +#else + return imx_get_fecclk(); +#endif +} + static void fec_mii_setspeed(struct ethernet_regs *eth) { /* @@ -139,9 +165,20 @@ static void fec_mii_setspeed(struct ethernet_regs *eth) * Given that ceil(clkrate / 5000000) <= 64, the calculation for * holdtime cannot result in a value greater than 3. */ - u32 pclk = imx_get_fecclk(); - u32 speed = DIV_ROUND_UP(pclk, 5000000); - u32 hold = DIV_ROUND_UP(pclk, 100000000) - 1; + u32 pclk; + u32 speed; + u32 hold; + int ret; + + ret = fec_get_clk_rate(NULL, 0); + if (ret < 0) { + printf("Can't find FEC0 clk rate: %d\n", ret); + return; + } + pclk = ret; + speed = DIV_ROUND_UP(pclk, 5000000); + hold = DIV_ROUND_UP(pclk, 100000000) - 1; + #ifdef FEC_QUIRK_ENET_MAC speed--; #endif @@ -1268,6 +1305,21 @@ static int fecmxc_probe(struct udevice *dev) uint32_t start; int ret;
+ if (IS_ENABLED(CONFIG_IMX8)) { + ret = clk_get_by_name(dev, "ipg", &priv->ipg_clk); + if (ret < 0) { + debug("Can't get FEC ipg clk: %d\n", ret); + return ret; + } + ret = clk_enable(&priv->ipg_clk); + if (ret < 0) { + debug("Can't enable FEC ipg clk: %d\n", ret); + return ret; + } + + priv->clk_rate = clk_get_rate(&priv->ipg_clk); + } + ret = fec_alloc_descs(priv); if (ret) return ret; @@ -1372,6 +1424,7 @@ static const struct udevice_id fecmxc_ids[] = { { .compatible = "fsl,imx6sx-fec" }, { .compatible = "fsl,imx6ul-fec" }, { .compatible = "fsl,imx53-fec" }, + { .compatible = "fsl,imx7d-fec" }, { } };
diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index fd89443205..75ba55b69f 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -16,6 +16,8 @@ #ifndef __FEC_MXC_H #define __FEC_MXC_H
+#include <clk.h> + /* Layout description of the FEC */ struct ethernet_regs { /* [10:2]addr = 00 */ @@ -257,6 +259,8 @@ struct fec_priv { #ifdef CONFIG_DM_ETH u32 interface; #endif + struct clk ipg_clk; + u32 clk_rate; };
void imx_get_mac_from_fuse(int dev_id, unsigned char *mac);
Hi Joe,
On Mon, Oct 22, 2018 at 6:07 PM Joe Hershberger joe.hershberger@ni.com wrote:
A bit off topic, but I notice that your replies are sent two or three times to the mailing list.
On Mon, Oct 22, 2018 at 5:08 PM Fabio Estevam festevam@gmail.com wrote:
Hi Joe,
I've noticed that as well... it seems something has been screwed up on the Google servers I use to send emails to the list. I've reported the issue and have gotten no response. I'll report it again. Oddly the messages get uniquified in the archives, presumably because the message IDs are the same.
Apologies, -Joe
Hi Anatolij,
https://patchwork.ozlabs.org/patch/985918/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Anatolij Gustschin
Fabio Estevam
Joe Hershberger
