[U-Boot] [PATCH 1/9] ARM: zynq: Remove memory division by 2 for ECC case
For ECC case u-boot divided memory by 2 because one u-boot could be used for both cases when ECC is off or on. Remove this division and make sure that dts file contain the correct memory size when ECC is enabled.
arch/arm/mach-zynq/ddrc.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/mach-zynq/ddrc.c b/arch/arm/mach-zynq/ddrc.c index 5b20accbcb17..d74f8dbbc45d 100644 --- a/arch/arm/mach-zynq/ddrc.c +++ b/arch/arm/mach-zynq/ddrc.c @@ -42,8 +42,6 @@ void zynq_ddrc_init(void) */ /* cppcheck-suppress nullPointer */ memset((void *)0, 0, 1 * 1024 * 1024); - - gd->ram_size /= 2; } else { puts("ECC disabled "); }
Zynq setups some default options for SPL but not all targets are enabling SPL.
arch/arm/Kconfig | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 9bd6cf1d807d..8c6c35bb0f43 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -551,15 +551,15 @@ config ARCH_ZYNQ select CPU_V7 select SUPPORT_SPL select OF_CONTROL - select SPL_OF_CONTROL + select SPL_OF_CONTROL if SPL select DM select DM_ETH - select SPL_DM + select SPL_DM if SPL select DM_MMC select DM_SPI select DM_SERIAL select DM_SPI_FLASH - select SPL_SEPARATE_BSS + select SPL_SEPARATE_BSS if SPL
config ARCH_ZYNQMP bool "Support Xilinx ZynqMP Platform"
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Define CONFIG_SYS_PROMPT for all Zynq boards
It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6)
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + 10 files changed, 10 insertions(+)
diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index e577c931735e..221c5a88d1bc 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 7d52d8e941b7..302d17f96885 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ZYNQ=y CONFIG_TARGET_ZYNQ_PICOZED=y CONFIG_DEFAULT_DEVICE_TREE="zynq-picozed" CONFIG_SPL=y +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 9d1b40d76ef6..0ae6c1b13017 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index bba91dfdfa78..7ce067a0e4b1 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 96f0a794a382..4519abcae738 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM010" +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index b0c535e88e19..371241f0e08b 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM011" +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 7fb03eb0491b..e08220b69449 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM012" +CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 67665127b5ba..c906af9cb9a8 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM013" +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 058bb05ba658..074c6430e3ce 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 231483e3dbd3..b51a6779a1db 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y
Enable SPI flash.
Signed-off-by: Michal Simek monstr@monstr.eu Signed-off-by: Michal Simek michal.simek@xilinx.com ---
configs/zynq_zc770_xm013_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index c906af9cb9a8..f3401af94b53 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -13,4 +13,5 @@ CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y CONFIG_ZYNQ_GEM=y
Clean up config and use Kconfig more.
configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + include/configs/zynq-common.h | 1 - 6 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 0ae6c1b13017..0ede96f4405b 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 7ce067a0e4b1..4a8c7de7294f 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 4519abcae738..0b583c3850ab 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index f3401af94b53..b1de8efdec54 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 074c6430e3ce..9ba4d0ea5c54 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 0ab60839b6cf..e8c3ef0c3872 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -66,7 +66,6 @@ #ifdef CONFIG_ZYNQ_QSPI # define CONFIG_SF_DEFAULT_SPEED 30000000 # define CONFIG_SPI_FLASH_ISSI -# define CONFIG_SPI_FLASH_BAR # define CONFIG_CMD_SF #endif
Fix minor indentation problems.
arch/arm/dts/zynq-7000.dtsi | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index 83be51ae9df6..2d786f0fd15d 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -234,7 +234,7 @@ interrupt-parent = <&intc>; interrupts = <0 24 4>; reg = <0xe0100000 0x1000>; - } ; + };
sdhci1: sdhci@e0101000 { compatible = "arasan,sdhci-8.9a"; @@ -244,7 +244,7 @@ interrupt-parent = <&intc>; interrupts = <0 47 4>; reg = <0xe0101000 0x1000>; - } ; + };
slcr: slcr@f8000000 { #address-cells = <1>; @@ -326,11 +326,11 @@
scutimer: timer@f8f00600 { interrupt-parent = <&intc>; - interrupts = < 1 13 0x301 >; + interrupts = <1 13 0x301>; compatible = "arm,cortex-a9-twd-timer"; - reg = < 0xf8f00600 0x20 >; + reg = <0xf8f00600 0x20>; clocks = <&clkc 4>; - } ; + };
usb0: usb@e0002000 { compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
Reviewed-by: Sören Brinkmann soren.brinkmann@xilinx.com
Sören
On Thu, Jan 14, 2016 at 7:48 AM, Sören Brinkmann soren.brinkmann@xilinx.com wrote:
Reviewed-by: Moritz Fischer moritz.fischer@ettus.com
Fix console setup for all remaining zynq boards.
arch/arm/dts/zynq-zc770-xm010.dts | 5 ++--- arch/arm/dts/zynq-zc770-xm011.dts | 5 ++--- arch/arm/dts/zynq-zc770-xm012.dts | 5 ++--- arch/arm/dts/zynq-zc770-xm013.dts | 5 ++--- 4 files changed, 8 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/zynq-zc770-xm010.dts b/arch/arm/dts/zynq-zc770-xm010.dts index 07e2b7a7387d..b6982c0c45da 100644 --- a/arch/arm/dts/zynq-zc770-xm010.dts +++ b/arch/arm/dts/zynq-zc770-xm010.dts @@ -21,9 +21,8 @@ };
chosen { - bootargs = "console=ttyPS0,115200 root=/dev/ram rw earlyprintk"; - linux,stdout-path = &uart1; - stdout-path = &uart1; + bootargs = "root=/dev/ram rw earlyprintk"; + stdout-path = "serial0:115200n8"; };
memory { diff --git a/arch/arm/dts/zynq-zc770-xm011.dts b/arch/arm/dts/zynq-zc770-xm011.dts index 77e3bb0e6310..ae54519630bf 100644 --- a/arch/arm/dts/zynq-zc770-xm011.dts +++ b/arch/arm/dts/zynq-zc770-xm011.dts @@ -18,9 +18,8 @@ };
memory { diff --git a/arch/arm/dts/zynq-zc770-xm012.dts b/arch/arm/dts/zynq-zc770-xm012.dts index 3e1769acb51f..3c50b99933fe 100644 --- a/arch/arm/dts/zynq-zc770-xm012.dts +++ b/arch/arm/dts/zynq-zc770-xm012.dts @@ -20,9 +20,8 @@ };
memory { diff --git a/arch/arm/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts index 288e24837479..5077cdbc3e46 100644 --- a/arch/arm/dts/zynq-zc770-xm013.dts +++ b/arch/arm/dts/zynq-zc770-xm013.dts @@ -20,9 +20,8 @@ };
chosen { - bootargs = "console=ttyPS0,115200 root=/dev/ram rw earlyprintk"; - linux,stdout-path = &uart0; - stdout-path = &uart0; + bootargs = "root=/dev/ram rw earlyprintk"; + stdout-path = "serial0:115200n8"; };
memory {
Change possition of SPI_FLASH to by align with savedefconfig.
configs/zynq_zybo_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index b51a6779a1db..83149eb22565 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -12,11 +12,11 @@ CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_ZYNQ_GEM=y CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xe0001000 CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_ZYNQ_QSPI=y
Keep nodes aligned.
arch/arm/dts/zynq-zc770-xm011.dts | 12 ++++++------ arch/arm/dts/zynq-zc770-xm012.dts | 12 ++++++------ arch/arm/dts/zynq-zc770-xm013.dts | 30 +++++++++++++++--------------- 3 files changed, 27 insertions(+), 27 deletions(-)
diff --git a/arch/arm/dts/zynq-zc770-xm011.dts b/arch/arm/dts/zynq-zc770-xm011.dts index ae54519630bf..4fed2215365c 100644 --- a/arch/arm/dts/zynq-zc770-xm011.dts +++ b/arch/arm/dts/zynq-zc770-xm011.dts @@ -33,12 +33,6 @@ }; };
-&spi0 { - status = "okay"; - num-cs = <4>; - is-decoded-cs = <0>; -}; - &can0 { status = "okay"; }; @@ -53,6 +47,12 @@ }; };
+&spi0 { + status = "okay"; + num-cs = <4>; + is-decoded-cs = <0>; +}; + &uart1 { u-boot,dm-pre-reloc; status = "okay"; diff --git a/arch/arm/dts/zynq-zc770-xm012.dts b/arch/arm/dts/zynq-zc770-xm012.dts index 3c50b99933fe..8d69f0e0f5ef 100644 --- a/arch/arm/dts/zynq-zc770-xm012.dts +++ b/arch/arm/dts/zynq-zc770-xm012.dts @@ -30,12 +30,6 @@ }; };
-&spi1 { - status = "okay"; - num-cs = <4>; - is-decoded-cs = <0>; -}; - &can1 { status = "okay"; }; @@ -60,6 +54,12 @@ }; };
+&spi1 { + status = "okay"; + num-cs = <4>; + is-decoded-cs = <0>; +}; + &uart1 { u-boot,dm-pre-reloc; status = "okay"; diff --git a/arch/arm/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts index 5077cdbc3e46..77fdfcc00947 100644 --- a/arch/arm/dts/zynq-zc770-xm013.dts +++ b/arch/arm/dts/zynq-zc770-xm013.dts @@ -30,21 +30,6 @@ }; };
-&spi0 { - status = "okay"; - num-cs = <4>; - is-decoded-cs = <0>; - eeprom: at25@0 { - at25,byte-len = <8192>; - at25,addr-mode = <2>; - at25,page-size = <32>; - - compatible = "atmel,at25"; - reg = <2>; - spi-max-frequency = <1000000>; - }; -}; - &can1 { status = "okay"; }; @@ -73,6 +58,21 @@ }; };
+&spi0 { + status = "okay"; + num-cs = <4>; + is-decoded-cs = <0>; + eeprom: at25@0 { + at25,byte-len = <8192>; + at25,addr-mode = <2>; + at25,page-size = <32>; + + compatible = "atmel,at25"; + reg = <2>; + spi-max-frequency = <1000000>; + }; +}; + &uart0 { u-boot,dm-pre-reloc; status = "okay";
Michal Simek
Moritz Fischer
Sören Brinkmann
