[U-Boot] [PATCH] siemens,at91: enable features for smartweb
New features for smartweb: * switch to hush command parser * change autoboot stop to <ESC><ESC> * allow to write ethaddr
Signed-off-by: Matthias Michel matthias.michel@siemens.com Reviewed-by: Samuel Egli samuel.egli@siemens.com Cc: Roger Meier r.meier@siemens.com Cc: Heiko Schocher hs@denx.de --- configs/smartweb_defconfig | 5 ++++- include/configs/smartweb.h | 14 ++++++++++---- 2 files changed, 14 insertions(+), 5 deletions(-)
diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index ee4340f..654bb4b 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -3,4 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SMARTWEB=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" -CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_SYS_PROMPT="U-Boot# " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" +CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 44d1d5a..de7b6bc 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -49,10 +49,18 @@ #define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */ #define CONFIG_DISPLAY_CPUINFO /* display CPU Info at startup */
+/* We set the max number of command args high to avoid HUSH bugs. */ +#define CONFIG_SYS_MAXARGS 32 + /* setting board specific options */ -# define CONFIG_MACH_TYPE MACH_TYPE_SMARTWEB -#define CONFIG_CMDLINE_EDITING +#define CONFIG_MACH_TYPE MACH_TYPE_SMARTWEB +#define CONFIG_AUTO_COMPLETE +#define CONFIG_ENV_OVERWRITE 1 /* Overwrite ethaddr / serial# */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_AUTOLOAD "yes" +#define CONFIG_RESET_TO_RETRY
/* The LED PINs */ #define CONFIG_RED_LED AT91_PIN_PA9 @@ -184,9 +192,7 @@ /* General Boot Parameter */ #define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTCOMMAND "run flashboot" -#define CONFIG_BOOT_RETRY_TIME 30 #define CONFIG_SYS_CBSIZE 512 -#define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP
Hello Samuel,
Am 27.01.2016 um 15:56 schrieb Samuel Egli:
- switch to hush command parser
- change autoboot stop to <ESC><ESC>
- allow to write ethaddr
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
- /* setting board specific options */
Signed-off-by: Matthias Michel matthias.michel@siemens.com Reviewed-by: Samuel Egli samuel.egli@siemens.com Cc: Roger Meier r.meier@siemens.com Cc: Heiko Schocher hs@denx.de Reviewed-by: Heiko Schocher hs@denx.de
Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Andreas Bießmann
Heiko Schocher
Samuel Egli
