[U-Boot] [PATCH 4/4] test/fs: replace deprecated "sb" command with "host"
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- test/fs/fs-test.sh | 40 ++++++++++++++++++++-------------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/test/fs/fs-test.sh b/test/fs/fs-test.sh index 171b1de..82e91b0 100755 --- a/test/fs/fs-test.sh +++ b/test/fs/fs-test.sh @@ -6,14 +6,14 @@ #
# Invoke this test script from U-Boot base directory as ./test/fs/fs-test.sh -# It currently tests the fs/sb and native commands for ext4 and fat partitions +# It currently tests the host and native commands for ext4 and fat partitions # Expected results are as follows: # EXT4 tests: -# fs-test.sb.ext4.out: Summary: PASS: 17 FAIL: 2 +# fs-test.host.ext4.out: Summary: PASS: 19 FAIL: 0 # fs-test.ext4.out: Summary: PASS: 10 FAIL: 9 # fs-test.fs.ext4.out: Summary: PASS: 10 FAIL: 9 # FAT tests: -# fs-test.sb.fat.out: Summary: PASS: 17 FAIL: 2 +# fs-test.host.fat.out: Summary: PASS: 19 FAIL: 0 # fs-test.fat.out: Summary: PASS: 19 FAIL: 0 # fs-test.fs.fat.out: Summary: PASS: 19 FAIL: 0 # Total Summary: TOTAL PASS: 92 TOTAL FAIL: 22 @@ -155,10 +155,10 @@ function fname_for_write() { # 2nd parameter is file system type - fat/ext4 # 3rd parameter is name of small file # 4th parameter is name of big file -# 5th parameter is fs/nonfs/sb - to dictate generic fs commands or -# otherwise or sb hostfs +# 5th parameter is fs/nonfs/host - to dictate generic fs commands or +# otherwise or host # 6th parameter is the directory path for the files. Its "" for generic -# fs and ext4/fat and full patch for sb hostfs +# fs and ext4/fat and full path for host # UBOOT is set in env function test_image() { addr="0x01000008" @@ -192,8 +192,8 @@ function test_image() { SUFFIX=" 0:0" ;;
- sb) - PREFIX="sb " + host) + PREFIX="host " WRITE="save" SUFFIX="fs -" ;; @@ -217,17 +217,17 @@ function test_image() {
# In u-boot commands, <interface> stands for host or hostfs # hostfs maps to the host fs. - # host maps to the "sb bind" that we do + # host maps to the "host bind" that we do
$UBOOT << EOF -sb=$5 -setenv bind 'if test "$sb" != sb; then sb bind 0 "$1"; fi' +host=$5 +setenv bind 'if test "$host" != host; then host bind 0 "$1"; fi' run bind # Test Case 1 - ls ${PREFIX}ls host${SUFFIX} $6 # -# We want ${PREFIX}size host 0:0 $3 for host commands and -# sb size hostfs - $3 for hostfs commands. +# We want ${PREFIX}size host 0:0 $3 for fs/nonfs commands and +# host size hostfs - $3 for host commands. # 1MB is 0x0010 0000 # Test Case 2 - size of small file ${PREFIX}size host${SUFFIX} $FILE_SMALL @@ -521,9 +521,9 @@ prepare_env TOTAL_FAIL=0 TOTAL_PASS=0
-# In each loop, for a given file system image, we test both the -# fs command, like load/size/write, the file system specific command -# like: ext4load/ext4size/ext4write and the sb load/ls/save commands. +# In each loop, for a given file system image, we test both the fs command, +# like ls/size/load/save, the file system specific command, like +# ext4ls/ext4size/ext4load/ext4write and the host ls/size/load/save commands. for fs in ext4 fat; do
echo "Creating $fs image if not already present." @@ -531,11 +531,11 @@ for fs in ext4 fat; do MD5_FILE_FS="${MD5_FILE}.${fs}" create_image $IMAGE $fs
- # sb commands test + # host commands test echo "Creating files in $fs image if not already present." create_files $IMAGE $MD5_FILE_FS
- # Lets mount the image and test sb hostfs commands + # Lets mount the image and test host commands mkdir -p "$MOUNT_DIR" if [ "$fs" = "fat" ]; then uid="uid=`id -u`" @@ -545,8 +545,8 @@ for fs in ext4 fat; do sudo mount -o loop,rw,$uid "$IMAGE" "$MOUNT_DIR" sudo chmod 777 "$MOUNT_DIR"
- OUT_FILE="${OUT}.sb.${fs}.out" - test_image $IMAGE $fs $SMALL_FILE $BIG_FILE sb `pwd`/$MOUNT_DIR \ + OUT_FILE="${OUT}.host.${fs}.out" + test_image $IMAGE $fs $SMALL_FILE $BIG_FILE host `pwd`/$MOUNT_DIR \ > ${OUT_FILE} 2>&1 sudo umount "$MOUNT_DIR" rmdir "$MOUNT_DIR"
I'd like to convert this test to pytest. If you are able to give that a crack, please see 8729d582 (test: Convert the vboot test to test/py) for an example
Stefan Brüns
