[U-Boot] [PATCH v1 1/1] arm64: dt: poplar: add optee node
As Poplar supports running TF-A with OP-TEE as BL32 payload, add op-tee node in DT, which enables usage of OP-TEE driver (which provides an interface for requesting services from OP-TEE).
Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org --- arch/arm/dts/hi3798cv200-poplar.dts | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/hi3798cv200-poplar.dts b/arch/arm/dts/hi3798cv200-poplar.dts index 964326e..6bc2a23 100644 --- a/arch/arm/dts/hi3798cv200-poplar.dts +++ b/arch/arm/dts/hi3798cv200-poplar.dts @@ -28,6 +28,13 @@ reg = <0x0 0x0 0x0 0x80000000>; };
+ firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; + leds { compatible = "gpio-leds";
Hi Igor,
I'm fine with the change. But rather than pushing changes to u-boot, can you please push it to kernel repository, which is the DTS upstream right now? We sync DTS changes from kernel when needed, and only maintains u-boot specific changes in hi3798cv200-u-boot.dtsi.
Shawn
- firmware {
optee {
method = "smc";
- leds { compatible = "gpio-leds";
-- 2.7.4
Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org Reviewed-by: Simon Glass sjg@chromium.org
Igor Opaniuk
Shawn Guo
