[PATCH v2 0/4] QEMU spike machine support for U-Boot
We can use same U-Boot binary compiled using qemu-riscv64_smode_defconfig on QEMU virt machine and QEMU spike machine. To achieve this, we need HTIF console support for U-Boot QEMU RISC-V board hence this series.
To test this series with latest OpenSBI, we can use the following command: qemu-system-riscv64 -M spike -m 256M -display none -serial stdio \ -bios opensbi/build/platform/generic/firmware/fw_jump.bin -kernel \ ./u-boot/u-boot.bin
These patch can be found in qemu_riscv_htif_v2 branch at: https://github.com/avpatel/u-boot.git
Changes since v1: - Use ofnode_by_compatible() in PATCH3 - Updated QEMU RISC-V documentation in PATCH4
Anup Patel (4): serial: Add RISC-V HTIF console driver riscv: qemu: Enable HTIF console support riscv: qemu: Implement is_flash_available() for MTD NOR doc: qemu-riscv: Update documentation for QEMU spike machine
board/emulation/qemu-riscv/Kconfig | 1 + board/emulation/qemu-riscv/qemu-riscv.c | 12 ++ doc/board/emulation/qemu-riscv.rst | 48 ++++--- drivers/serial/Kconfig | 8 ++ drivers/serial/Makefile | 1 + drivers/serial/serial_htif.c | 178 ++++++++++++++++++++++++ 6 files changed, 232 insertions(+), 16 deletions(-) create mode 100644 drivers/serial/serial_htif.c
Quite a few RISC-V emulators and ISS (including Spike) have host transfer interface (HTIF) based console. This patch adds HTIF based console driver for RISC-V platforms which depends totally on DT node for HTIF register base address.
Signed-off-by: Anup Patel apatel@ventanamicro.com Reviewed-by: Philipp Tomsich philipp.tomsich@vrull.eu Reviewed-by: Rick Chen rick@andestech.com --- drivers/serial/Kconfig | 8 ++ drivers/serial/Makefile | 1 + drivers/serial/serial_htif.c | 178 +++++++++++++++++++++++++++++++++++ 3 files changed, 187 insertions(+) create mode 100644 drivers/serial/serial_htif.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 6c8fdda9a0..345d1881f5 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -866,6 +866,14 @@ config PXA_SERIAL If you have a machine based on a Marvell XScale PXA2xx CPU you can enable its onboard serial ports by enabling this option.
+config HTIF_CONSOLE + bool "RISC-V HTIF console support" + depends on DM_SERIAL && 64BIT + help + Select this to enable host transfer interface (HTIF) based serial + console. The HTIF device is quite common in RISC-V emulators and + RISC-V ISS so this driver allows using U-Boot on such platforms. + config SIFIVE_SERIAL bool "SiFive UART support" depends on DM_SERIAL diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 8168af640f..52e70aa191 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -73,6 +73,7 @@ obj-$(CONFIG_OWL_SERIAL) += serial_owl.o obj-$(CONFIG_OMAP_SERIAL) += serial_omap.o obj-$(CONFIG_MTK_SERIAL) += serial_mtk.o obj-$(CONFIG_MT7620_SERIAL) += serial_mt7620.o +obj-$(CONFIG_HTIF_CONSOLE) += serial_htif.o obj-$(CONFIG_SIFIVE_SERIAL) += serial_sifive.o obj-$(CONFIG_XEN_SERIAL) += serial_xen.o
diff --git a/drivers/serial/serial_htif.c b/drivers/serial/serial_htif.c new file mode 100644 index 0000000000..5d2bf0aaeb --- /dev/null +++ b/drivers/serial/serial_htif.c @@ -0,0 +1,178 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Ventana Micro Systems Inc. + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <log.h> +#include <watchdog.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <serial.h> +#include <linux/err.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define HTIF_DATA_BITS 48 +#define HTIF_DATA_MASK ((1ULL << HTIF_DATA_BITS) - 1) +#define HTIF_DATA_SHIFT 0 +#define HTIF_CMD_BITS 8 +#define HTIF_CMD_MASK ((1ULL << HTIF_CMD_BITS) - 1) +#define HTIF_CMD_SHIFT 48 +#define HTIF_DEV_BITS 8 +#define HTIF_DEV_MASK ((1ULL << HTIF_DEV_BITS) - 1) +#define HTIF_DEV_SHIFT 56 + +#define HTIF_DEV_SYSTEM 0 +#define HTIF_DEV_CONSOLE 1 + +#define HTIF_CONSOLE_CMD_GETC 0 +#define HTIF_CONSOLE_CMD_PUTC 1 + +#if __riscv_xlen == 64 +# define TOHOST_CMD(dev, cmd, payload) \ + (((u64)(dev) << HTIF_DEV_SHIFT) | \ + ((u64)(cmd) << HTIF_CMD_SHIFT) | \ + (u64)(payload)) +#else +# define TOHOST_CMD(dev, cmd, payload) ({ \ + if ((dev) || (cmd)) \ + __builtin_trap(); \ + (payload); }) +#endif +#define FROMHOST_DEV(fromhost_value) \ + ((u64)((fromhost_value) >> HTIF_DEV_SHIFT) & HTIF_DEV_MASK) +#define FROMHOST_CMD(fromhost_value) \ + ((u64)((fromhost_value) >> HTIF_CMD_SHIFT) & HTIF_CMD_MASK) +#define FROMHOST_DATA(fromhost_value) \ + ((u64)((fromhost_value) >> HTIF_DATA_SHIFT) & HTIF_DATA_MASK) + +struct htif_plat { + void *fromhost; + void *tohost; + int console_char; +}; + +static void __check_fromhost(struct htif_plat *plat) +{ + u64 fh = readq(plat->fromhost); + + if (!fh) + return; + writeq(0, plat->fromhost); + + /* this should be from the console */ + if (FROMHOST_DEV(fh) != HTIF_DEV_CONSOLE) + __builtin_trap(); + switch (FROMHOST_CMD(fh)) { + case HTIF_CONSOLE_CMD_GETC: + plat->console_char = 1 + (u8)FROMHOST_DATA(fh); + break; + case HTIF_CONSOLE_CMD_PUTC: + break; + default: + __builtin_trap(); + } +} + +static void __set_tohost(struct htif_plat *plat, + u64 dev, u64 cmd, u64 data) +{ + while (readq(plat->tohost)) + __check_fromhost(plat); + writeq(TOHOST_CMD(dev, cmd, data), plat->tohost); +} + +static int htif_serial_putc(struct udevice *dev, const char ch) +{ + struct htif_plat *plat = dev_get_plat(dev); + + __set_tohost(plat, HTIF_DEV_CONSOLE, HTIF_CONSOLE_CMD_PUTC, ch); + return 0; +} + +static int htif_serial_getc(struct udevice *dev) +{ + int ch; + struct htif_plat *plat = dev_get_plat(dev); + + if (plat->console_char < 0) + __check_fromhost(plat); + + if (plat->console_char >= 0) { + ch = plat->console_char; + plat->console_char = -1; + __set_tohost(plat, HTIF_DEV_CONSOLE, HTIF_CONSOLE_CMD_GETC, 0); + return (ch) ? ch - 1 : -EAGAIN; + } + + return -EAGAIN; +} + +static int htif_serial_pending(struct udevice *dev, bool input) +{ + struct htif_plat *plat = dev_get_plat(dev); + + if (!input) + return 0; + + if (plat->console_char < 0) + __check_fromhost(plat); + + return (plat->console_char >= 0) ? 1 : 0; +} + +static int htif_serial_probe(struct udevice *dev) +{ + struct htif_plat *plat = dev_get_plat(dev); + + /* Queue first getc request */ + __set_tohost(plat, HTIF_DEV_CONSOLE, HTIF_CONSOLE_CMD_GETC, 0); + + return 0; +} + +static int htif_serial_of_to_plat(struct udevice *dev) +{ + fdt_addr_t addr; + struct htif_plat *plat = dev_get_plat(dev); + + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -ENODEV; + plat->fromhost = (void *)(uintptr_t)addr; + plat->tohost = plat->fromhost + sizeof(u64); + + addr = dev_read_addr_index(dev, 1); + if (addr != FDT_ADDR_T_NONE) + plat->tohost = (void *)(uintptr_t)addr; + + plat->console_char = -1; + + return 0; +} + +static const struct dm_serial_ops htif_serial_ops = { + .putc = htif_serial_putc, + .getc = htif_serial_getc, + .pending = htif_serial_pending, +}; + +static const struct udevice_id htif_serial_ids[] = { + { .compatible = "ucb,htif0" }, + { } +}; + +U_BOOT_DRIVER(serial_htif) = { + .name = "serial_htif", + .id = UCLASS_SERIAL, + .of_match = htif_serial_ids, + .of_to_plat = htif_serial_of_to_plat, + .plat_auto = sizeof(struct htif_plat), + .probe = htif_serial_probe, + .ops = &htif_serial_ops, +};
Tested-by: Bin Meng bmeng.cn@gmail.com
Enable support for HTIF console so that we can use QEMU RISC-V U-Boot on RISC-V emulators and ISS having it.
Signed-off-by: Anup Patel apatel@ventanamicro.com Reviewed-by: Philipp Tomsich philipp.tomsich@vrull.eu Reviewed-by: Rick Chen rick@andestech.com --- board/emulation/qemu-riscv/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/emulation/qemu-riscv/Kconfig b/board/emulation/qemu-riscv/Kconfig index 1bbf1bc84a..f7538bc496 100644 --- a/board/emulation/qemu-riscv/Kconfig +++ b/board/emulation/qemu-riscv/Kconfig @@ -56,6 +56,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply DM_SCSI imply SYS_NS16550 imply SIFIVE_SERIAL + imply HTIF_CONSOLE if 64BIT imply SYSRESET imply SYSRESET_CMD_POWEROFF imply SYSRESET_SYSCON
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Currently, if MTD NOR is enabled then U-Boot tries to issue flash commands even when CFI flash DT node is not present. This causes access fault on RISC-V emulators or ISS which do not emulate CFI flash. To handle this issue, we implement is_flash_available() for qemu-riscv board which will return 1 only if CFI flash DT node is present.
Fixes: d248627f9d42 ("riscv: qemu: Enable MTD NOR flash support") Signed-off-by: Anup Patel apatel@ventanamicro.com Reviewed-by: Rick Chen rick@andestech.com --- board/emulation/qemu-riscv/qemu-riscv.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/board/emulation/qemu-riscv/qemu-riscv.c b/board/emulation/qemu-riscv/qemu-riscv.c index b0d9dd59b1..ae3b7a3295 100644 --- a/board/emulation/qemu-riscv/qemu-riscv.c +++ b/board/emulation/qemu-riscv/qemu-riscv.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <dm/ofnode.h> #include <env.h> #include <fdtdec.h> #include <image.h> @@ -16,6 +17,17 @@
+#if IS_ENABLED(CONFIG_MTD_NOR_FLASH) +int is_flash_available(void) +{ + if (!ofnode_equal(ofnode_by_compatible(ofnode_null(), "cfi-flash"), + ofnode_null())) + return 1; + + return 0; +} +#endif + int board_init(void) { /*
I do not think that we need an #if here. The weak function is only defined and called if CONFIG_MTD_NOR_FLASH=y (cf. common/board_r.c). Without the #if the linker will detect that this function is not needed and will eliminate it if CONFIG_MTD_NOR_FLASH=n.
As this ensures that the function is always compiled this is the preferred way of implementation.
Currently there is no include defining the is_flash_available(). This needs to be fixed.
Best regards
Heinrich
- if (!ofnode_equal(ofnode_by_compatible(ofnode_null(), "cfi-flash"),
ofnode_null()))
return 1;
+} +#endif
- int board_init(void) { /*
We can now use same U-Boot images on both QEMU virt machine and QEMU spike machine so let's update the QEMU RISC-V documentation.
Signed-off-by: Anup Patel apatel@ventanamicro.com --- doc/board/emulation/qemu-riscv.rst | 48 ++++++++++++++++++++---------- 1 file changed, 32 insertions(+), 16 deletions(-)
diff --git a/doc/board/emulation/qemu-riscv.rst b/doc/board/emulation/qemu-riscv.rst index 4b8e104a21..0a4b121687 100644 --- a/doc/board/emulation/qemu-riscv.rst +++ b/doc/board/emulation/qemu-riscv.rst @@ -4,16 +4,21 @@ QEMU RISC-V ===========
-QEMU for RISC-V supports a special 'virt' machine designed for emulation and -virtualization purposes. This document describes how to run U-Boot under it. -Both 32-bit and 64-bit targets are supported, running in either machine or -supervisor mode. +QEMU for RISC-V supports a special 'virt' machine and 'spike' machine designed +for emulation and virtualization purposes. This document describes how to run +U-Boot under it. Both 32-bit and 64-bit targets are supported, running in +either machine or supervisor mode.
The QEMU virt machine models a generic RISC-V virtual machine with support for the VirtIO standard networking and block storage devices. It has CLINT, PLIC, 16550A UART devices in addition to VirtIO and it also uses device-tree to pass -configuration information to guest software. It implements RISC-V privileged -architecture spec v1.10. +configuration information to guest software. It implements the latest RISC-V +privileged architecture. + +The QEMU spike machine models a minimalistic RISC-V virtual machine with +only CLINT and HTIF devices. It also uses device-tree to pass configuration +information to guest software and implements the latest RISC-V privileged +architecture.
Building U-Boot --------------- @@ -38,13 +43,17 @@ Running U-Boot -------------- The minimal QEMU command line to get U-Boot up and running is:
-- For 32-bit RISC-V:: +- For 32-bit RISC-V virt machine::
- qemu-system-riscv32 -nographic -machine virt -bios u-boot + qemu-system-riscv32 -nographic -machine virt -bios u-boot.bin
-- For 64-bit RISC-V:: +- For 64-bit RISC-V virt machine:: + + qemu-system-riscv64 -nographic -machine virt -bios u-boot.bin + +- For 64-bit RISC-V spike machine::
- qemu-system-riscv64 -nographic -machine virt -bios u-boot + qemu-system-riscv64 -nographic -machine spike -bios u-boot.bin
The commands above create targets with 128MiB memory by default. A freely configurable amount of RAM can be created via the '-m' @@ -55,6 +64,7 @@ the new setting. For instructions on how to run U-Boot in supervisor mode on QEMU with OpenSBI, see the documentation available with OpenSBI: https://github.com/riscv/opensbi/blob/master/docs/platform/qemu_virt.md +https://github.com/riscv/opensbi/blob/master/docs/platform/spike.md
These have been tested in QEMU 5.0.0.
@@ -77,8 +87,9 @@ supported by U-Boot. Clone the OpenSBI repository and run the following command.
See the OpenSBI documentation for full details: https://github.com/riscv/opensbi/blob/master/docs/platform/qemu_virt.md +https://github.com/riscv/opensbi/blob/master/docs/platform/spike.md
-To make the FW_DYNAMIC binary (build/platform/qemu/virt/firmware/fw_dynamic.bin) +To make the FW_DYNAMIC binary (build/platform/generic/firmware/fw_dynamic.bin) available to U-Boot, either copy it into the U-Boot root directory or specify its location with the OPENSBI environment variable. Afterwards, compile U-Boot with the following commands. @@ -96,17 +107,22 @@ with the following commands. The minimal QEMU commands to run U-Boot SPL in both 32-bit and 64-bit configurations are:
- qemu-system-riscv32 -nographic -machine virt -bios spl/u-boot-spl \ + qemu-system-riscv32 -nographic -machine virt -bios spl/u-boot-spl.bin \ -device loader,file=u-boot.itb,addr=0x80200000
-- For 64-bit RISC-V:: +- For 64-bit RISC-V virt machine:: + + qemu-system-riscv64 -nographic -machine virt -bios spl/u-boot-spl.bin \ + -device loader,file=u-boot.itb,addr=0x80200000 + +- For 64-bit RISC-V spike machine::
- qemu-system-riscv64 -nographic -machine virt -bios spl/u-boot-spl \ + qemu-system-riscv64 -nographic -machine spike -bios spl/u-boot-spl.bin \ -device loader,file=u-boot.itb,addr=0x80200000
-An attached disk can be emulated by adding:: +An attached disk can be emulated in RISC-V virt machine by adding::
-device ich9-ahci,id=ahci \ -drive if=none,file=riscv64.img,format=raw,id=mydisk \
Hi Rick,
Changes since v1:
Can this series be considered for the upcoming v2022.04 release ?
Best Regards, Anup
-- 2.25.1
Anup Patel
Anup Patel
Bin Meng
