[U-Boot] [PATCH 1/2][v3] board: freescale: ls2080ardb: Update QIXIS code
Update QIXIS related code to be executed only if CONFIG_FSL_QIXIS flag is enabled
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- board/freescale/ls2080ardb/ls2080ardb.c | 19 ++++++++++++++++--- 1 files changed, 16 insertions(+), 3 deletions(-)
diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index ea05ec6..1de5058 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -22,8 +22,10 @@ #include <asm/arch/ppa.h> #include <fsl_sec.h>
+#ifdef CONFIG_FSL_QIXIS #include "../common/qixis.h" #include "ls2080ardb_qixis.h" +#endif #include "../common/vid.h"
#define PIN_MUX_SEL_SDHC 0x00 @@ -57,12 +59,15 @@ unsigned long long get_qixis_addr(void)
int checkboard(void) { +#ifdef CONFIG_FSL_QIXIS u8 sw; +#endif char buf[15];
cpu_name(buf); printf("Board: %s-RDB, ", buf);
+#ifdef CONFIG_FSL_QIXIS sw = QIXIS_READ(arch); printf("Board Arch: V%d, ", sw >> 4); printf("Board version: %c, boot from ", (sw & 0xf) + 'A'); @@ -78,7 +83,7 @@ int checkboard(void) printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH);
printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); - +#endif puts("SERDES1 Reference : "); printf("Clock1 = 156.25MHz "); printf("Clock2 = 156.25MHz"); @@ -92,6 +97,7 @@ int checkboard(void)
unsigned long get_board_sys_clk(void) { +#ifdef CONFIG_FSL_QIXIS u8 sysclk_conf = QIXIS_READ(brdcfg[1]);
switch (sysclk_conf & 0x0F) { @@ -110,6 +116,7 @@ unsigned long get_board_sys_clk(void) case QIXIS_SYSCLK_166: return 166666666; } +#endif return 66666666; }
@@ -133,6 +140,7 @@ int i2c_multiplexer_select_vid_channel(u8 channel)
int config_board_mux(int ctrl_type) { +#ifdef CONFIG_FSL_QIXIS u8 reg5;
reg5 = QIXIS_READ(brdcfg[5]); @@ -150,7 +158,7 @@ int config_board_mux(int ctrl_type) }
QIXIS_WRITE(brdcfg[5], reg5); - +#endif return 0; }
@@ -180,8 +188,9 @@ int board_init(void) #endif select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT);
+#ifdef CONFIG_FSL_QIXIS QIXIS_WRITE(rst_ctl, QIXIS_RST_CTL_RESET_EN); - +#endif #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif @@ -301,6 +310,7 @@ int ft_board_setup(void *blob, bd_t *bd)
void qixis_dump_switch(void) { +#ifdef CONFIG_FSL_QIXIS int i, nr_of_cfgsw;
QIXIS_WRITE(cms[0], 0x00); @@ -311,6 +321,7 @@ void qixis_dump_switch(void) QIXIS_WRITE(cms[0], i); printf("SW%d = (0x%02x)\n", i, QIXIS_READ(cms[1])); } +#endif }
/* @@ -321,6 +332,7 @@ void update_spd_address(unsigned int ctrl_num, unsigned int slot, unsigned int *addr) { +#ifdef CONFIG_FSL_QIXIS u8 sw;
sw = QIXIS_READ(arch); @@ -330,4 +342,5 @@ void update_spd_address(unsigned int ctrl_num, else if (ctrl_num == 1 && slot == 1) *addr = SPD_EEPROM_ADDRESS3; } +#endif }
Priyanka Jain
