[U-Boot-Users] PCI access memory space
Hello
I'm using on my custom board (PPC 440GX) an ATI M6-C16H Mobility Radeon video card. I work with U-boot 1.1.2. I can access the configuration space of ATI with the functions: pci_read_config_dword(..) and pci_write_config_dword(.)
Now I have to access the memory space of the ATI. I use the functions: readl(.) and writel(..)
But when I start u-boot, it hangs. I can not access the memory base address of the ATI.
Can someone please give me information how U-Boot handles with PCI devices when accessing the memory space.
Thanks for any help,
Bashier
You can also test this using simple "md" and "mw" commands.
This is more or less to be expected.
This has nothing to do with U-Boot or PCI accesses. Your problem is most probably that the ATI graphics card expects that it's memory controller gets initialized - which is normally done by the (x86) BIOS code of the card. Without such initialization you simply cannot access the RAM on the card - which is what's causing your hang -- exactly like your system will hang if you try to access the on-board DRAm without proper initialization.
Bashier Machmur
