[U-Boot-Users] u-boot on Memec P4/7-FG456 (w/ virtex II pro)?
hi,
has anyone done any u-boot porting work for the Memec Virtex-II Pro P4/7-FG456 evaluation board?
as you can see from the link below this is a development board which has the Virtex-II Pro (w/ single 405GP core) along with SDRAM, NV stroage via compact flash, and so forth.
http://www.memec.com/cgi-bin/bvutf8/memec/scripts/local/manuDetailArticle.js...
we are considering using this board as an R&D platfrom for an upcoming project.
thanks!
If memory serves me correctly, I was able to get PPCBoot 2.0.0 running on that very board with relatively little effort. I based it on the ML2 support that was already in there. It was just a proof of concept exercise so I didn't do anything with the flash or Ethernet (on the P160 comm module). Basically got it up to the command prompt and that was that.
I was also able to get PPCBoot 2.0.0 (yes, I know :-) running on our own V2Pro board (http://www.amirix.com/images/PCIPlatform.pdf) with moderate effort.
-Frank.
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of jds Sent: July 18, 2003 10:14 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] u-boot on Memec P4/7-FG456 (w/ virtex II pro)?
hi,
http://www.memec.com/cgi-bin/bvutf8/memec/scripts/local/manuDetail Article.jsp?catPath=/DESIGN/GENERICA/XILINXCT/MANUFACTURERS/MD_XIL INX/EVALUATION_KITS/Virtex%20Series%20Kits&Manu=10089&isDetailPage =true&EDOID=200910&Div=DESIGN&Reg=GENERICA&Country=XILINXCT&Lang=E N&PnACountry=XILINXCT
thanks!
-- Perfection is reached, not when there is no longer anything to add, but when there is no longer anything to take away. - Antoine de Saint-Exupery
This SF.net email is sponsored by: VM Ware With VMware you can run multiple operating systems on a single machine. WITHOUT REBOOTING! Mix Linux / Windows / Novell virtual machines at the same time. Free trial click here: http://www.vmware.com/wl/offer/345/0 _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
to those of you who have ported uboot to the Virtex II PRO P4/7, i have a nice, simple, straightforward question for you... :*)
what is your boot strategy?
do you load a minimal FPGA/uboot image (from flash) into the internal RAM (~80KBytes big) and then in turn download the OS and application code? OR do you have a very very simple FPGA/bootloader image which in turn loads uboot into EXTERNAL RAM and then uboot loads the OS and application code? OR yet some other way?
related to option 1 above... does uboot for the the Virtex II PRO P4/7 fit nicely into the 80KB?
thanks for any insight.
jim
-Frank.
hi,
thanks!
Frank Smith
jds
