[PATCH] ns16650: Correct CONFIG_SYS_NS16550_MEM32 platforms
There are currently no platform that are both CONFIG_SYS_NS16550_MEM32 and not (per how the logic was prior to being broken in 0478dac62a9a ("kbuild: Remove uncmd_spl logic")) enabled in CONFIG_DM_SERIAL. We drop this line out now so that platforms which do use CONFIG_SYS_NS16550_MEM32 and depending on stage may or may not have DM_SERIAL set.
Fixes: 0478dac62a9a ("kbuild: Remove uncmd_spl logic") Reported-by: Quentin Schulz quentin.schulz@theobroma-systems.com Signed-off-by: Tom Rini trini@konsulko.com --- include/ns16550.h | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/include/ns16550.h b/include/ns16550.h index f45fc8cecc56..243226fc3d94 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -34,12 +34,10 @@ #define CONFIG_SYS_NS16550_REG_SIZE (-1) #endif
-#ifdef CONFIG_NS16550_DYNAMIC +#if defined(CONFIG_NS16550_DYNAMIC) || defined(CONFIG_DEBUG_UART) #define UART_REG(x) unsigned char x #else -#if defined(CONFIG_SYS_NS16550_MEM32) && !CONFIG_IS_ENABLED(DM_SERIAL) -#define UART_REG(x) u32 x -#elif !defined(CONFIG_SYS_NS16550_REG_SIZE) || (CONFIG_SYS_NS16550_REG_SIZE == 0) +#if !defined(CONFIG_SYS_NS16550_REG_SIZE) || (CONFIG_SYS_NS16550_REG_SIZE == 0) #error "Please define NS16550 registers size." #elif (CONFIG_SYS_NS16550_REG_SIZE > 0) #define UART_REG(x) \
Hi Tom,
This means though that we assume all ns16550 implementations have their register value stored in a byte only, either LSB or MSB of a 1-4 byte-wide register (which can (sometimes) be configured with CONFIG_SYS_NS16550_REG_SIZE).
In any case, Tested-by: Quentin Schulz quentin.schulz@theobroma-systems.com #on Ringneck PX30, Puma RK3399
I really appreciate you taking the time to debug and suggest a patch, thanks a ton.
Cheers, Quentin
Fixes: 0478dac62a9a ("kbuild: Remove uncmd_spl logic") Reported-by: Quentin Schulz quentin.schulz@theobroma-systems.com Signed-off-by: Tom Rini trini@konsulko.com Tested-by: Quentin Schulz quentin.schulz@theobroma-systems.com #on Ringneck PX30, Puma RK3399
