[U-Boot] [PATCH] rockchip: rk3399-puma: Move ENV_OFFSET to end of SPI NOR.
Puma SoMs have a 4 MB SPI NOR flash. Therefore we can move the environment to the end of the flash (4 MiB - 16 kiB) in order to not overlap with SPL.
Reported-by: Jakob Unterwurzacher jakob.unterwurzacher@theobroma-systems.com Signed-off-by: Christoph Muellner christoph.muellner@theobroma-systems.com ---
board/theobroma-systems/puma_rk3399/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/theobroma-systems/puma_rk3399/Kconfig b/board/theobroma-systems/puma_rk3399/Kconfig index 8a94cbd9ed..9e23252754 100644 --- a/board/theobroma-systems/puma_rk3399/Kconfig +++ b/board/theobroma-systems/puma_rk3399/Kconfig @@ -16,6 +16,6 @@ config ENV_SIZE default 0x2000
config ENV_OFFSET - default 0x3c000 if ENV_IS_IN_SPI_FLASH + default 0x3fc000 if ENV_IS_IN_SPI_FLASH
endif
On Tue, 7 May 2019 at 02:37, Christoph Muellner christoph.muellner@theobroma-systems.com wrote:
Hi Christoph,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
config ENV_OFFSET
- default 0x3fc000 if ENV_IS_IN_SPI_FLASH
endif
On 05/28/2019 08:46 PM, Kever Yang wrote:
Hi Christoph,
Applied to u-boot-rockchip/master, thanks!
Thanks,
- Kever
config ENV_OFFSET
endif
Christoph Muellner
Kever Yang
