[U-Boot] [PATCH v1 0/2] MIPS: refactor machine setup
Refactor machine setup like it is done on ARM. While on it, also support "include <mach/file.h" for machine specific header files. Also move au1x00 specific header files to new location.
Daniel Schwierzeck (2): MIPS: Kconfig: refactor machine setup MIPS: au1x00: move SoC header files to arch/mips/mach-au1x00/include/mach/
arch/mips/Makefile | 7 ++++++- arch/mips/mach-au1x00/au1x00_eth.c | 2 +- arch/mips/mach-au1x00/au1x00_serial.c | 2 +- arch/mips/mach-au1x00/au1x00_usb_ohci.c | 2 +- arch/mips/{include/asm => mach-au1x00/include/mach}/au1x00.h | 0 board/dbau1x00/dbau1x00.c | 2 +- board/dbau1x00/lowlevel_init.S | 2 +- board/pb1x00/lowlevel_init.S | 2 +- board/pb1x00/pb1x00.c | 2 +- 9 files changed, 13 insertions(+), 8 deletions(-) rename arch/mips/{include/asm => mach-au1x00/include/mach}/au1x00.h (100%)
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
arch/mips/Makefile | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 43f0f5c..6a9f798 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -7,4 +7,9 @@ head-y := arch/mips/cpu/start.o libs-y += arch/mips/cpu/ libs-y += arch/mips/lib/
-libs-$(CONFIG_SOC_AU1X00) += arch/mips/mach-au1x00/ +machine-$(CONFIG_SOC_AU1X00) += au1x00 + +machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) +libs-y += $(machdirs) + +PLATFORM_CPPFLAGS += $(patsubst %,-I$(srctree)/%include,$(machdirs))
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
arch/mips/mach-au1x00/au1x00_eth.c | 2 +- arch/mips/mach-au1x00/au1x00_serial.c | 2 +- arch/mips/mach-au1x00/au1x00_usb_ohci.c | 2 +- arch/mips/{include/asm => mach-au1x00/include/mach}/au1x00.h | 0 board/dbau1x00/dbau1x00.c | 2 +- board/dbau1x00/lowlevel_init.S | 2 +- board/pb1x00/lowlevel_init.S | 2 +- board/pb1x00/pb1x00.c | 2 +- 8 files changed, 7 insertions(+), 7 deletions(-) rename arch/mips/{include/asm => mach-au1x00/include/mach}/au1x00.h (100%)
diff --git a/arch/mips/mach-au1x00/au1x00_eth.c b/arch/mips/mach-au1x00/au1x00_eth.c index d6ebe07..3e8e8c1 100644 --- a/arch/mips/mach-au1x00/au1x00_eth.c +++ b/arch/mips/mach-au1x00/au1x00_eth.c @@ -43,7 +43,7 @@ #include <net.h> #include <command.h> #include <asm/io.h> -#include <asm/au1x00.h> +#include <mach/au1x00.h>
#if defined(CONFIG_CMD_MII) #include <miiphy.h> diff --git a/arch/mips/mach-au1x00/au1x00_serial.c b/arch/mips/mach-au1x00/au1x00_serial.c index 0463508..4784504 100644 --- a/arch/mips/mach-au1x00/au1x00_serial.c +++ b/arch/mips/mach-au1x00/au1x00_serial.c @@ -11,7 +11,7 @@
#include <config.h> #include <common.h> -#include <asm/au1x00.h> +#include <mach/au1x00.h> #include <serial.h> #include <linux/compiler.h>
diff --git a/arch/mips/mach-au1x00/au1x00_usb_ohci.c b/arch/mips/mach-au1x00/au1x00_usb_ohci.c index 74bdb77..42484e5 100644 --- a/arch/mips/mach-au1x00/au1x00_usb_ohci.c +++ b/arch/mips/mach-au1x00/au1x00_usb_ohci.c @@ -23,7 +23,7 @@ #include <common.h> #include <malloc.h> #include <asm/io.h> -#include <asm/au1x00.h> +#include <mach/au1x00.h> #include <usb.h> #include "au1x00_usb_ohci.h"
diff --git a/arch/mips/include/asm/au1x00.h b/arch/mips/mach-au1x00/include/mach/au1x00.h similarity index 100% rename from arch/mips/include/asm/au1x00.h rename to arch/mips/mach-au1x00/include/mach/au1x00.h diff --git a/board/dbau1x00/dbau1x00.c b/board/dbau1x00/dbau1x00.c index bd20f6e..75e6f0e 100644 --- a/board/dbau1x00/dbau1x00.c +++ b/board/dbau1x00/dbau1x00.c @@ -7,7 +7,7 @@
#include <common.h> #include <command.h> -#include <asm/au1x00.h> +#include <mach/au1x00.h> #include <asm/mipsregs.h> #include <asm/io.h>
diff --git a/board/dbau1x00/lowlevel_init.S b/board/dbau1x00/lowlevel_init.S index 842fb76..409f8ee 100644 --- a/board/dbau1x00/lowlevel_init.S +++ b/board/dbau1x00/lowlevel_init.S @@ -1,8 +1,8 @@ /* Memory sub-system initialization code */
#include <config.h> +#include <mach/au1x00.h> #include <asm/regdef.h> -#include <asm/au1x00.h> #include <asm/mipsregs.h>
#define AU1500_SYS_ADDR 0xB1900000 diff --git a/board/pb1x00/lowlevel_init.S b/board/pb1x00/lowlevel_init.S index b145e43..98d9536 100644 --- a/board/pb1x00/lowlevel_init.S +++ b/board/pb1x00/lowlevel_init.S @@ -1,8 +1,8 @@ /* Memory sub-system initialization code */
#define AU1500_SYS_ADDR 0xB1900000 diff --git a/board/pb1x00/pb1x00.c b/board/pb1x00/pb1x00.c index 34814c4..eb92914 100644 --- a/board/pb1x00/pb1x00.c +++ b/board/pb1x00/pb1x00.c @@ -7,7 +7,7 @@
Daniel Schwierzeck
