[PATCH v2 0/3] arm64: layerscape: Various small size reductions for SPL
This series groups a few small size reductions I found while trying to reduce my SPL size. They are all independent of each other.
Changes in v2: - Fix using || instead of && for ARCH_LS1043
Sean Anderson (3): arm: layerscape: Don't select FSL_IFC when booting from SD card arm: layerscape: Disable unused parts of ICID tables arm: fsl: csu: Reduce size of ns_dev
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++-- arch/arm/cpu/armv8/fsl-layerscape/icid.c | 2 ++ .../include/asm/arch-fsl-layerscape/fsl_icid.h | 16 ++++++++++++++-- include/fsl_csu.h | 4 ++-- 4 files changed, 20 insertions(+), 6 deletions(-)
FSL_IFC should only be selected when booting from NAND flash (or when NAND_FSL_IFC is enabled). The existing logic does this correctly when QSPI is also enabled, but not when just booting from SD.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 80a1642447d..9f76c18feaa 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -62,7 +62,7 @@ config ARCH_LS1043A bool select ARMV8_SET_SMPEN select ARM_ERRATA_855873 if !TFABOOT - select FSL_IFC if TFABOOT || (!QSPI_BOOT && !SD_BOOT_QSPI) + select FSL_IFC if TFABOOT || (!QSPI_BOOT && !SD_BOOT_QSPI && !SD_BOOT) select FSL_LAYERSCAPE select FSL_LSCH2 select GICV2 @@ -98,7 +98,7 @@ config ARCH_LS1043A config ARCH_LS1046A bool select ARMV8_SET_SMPEN - select FSL_IFC if TFABOOT || (!QSPI_BOOT && !SD_BOOT_QSPI) + select FSL_IFC if TFABOOT || (!QSPI_BOOT && !SD_BOOT_QSPI && !SD_BOOT) select FSL_LAYERSCAPE select FSL_LSCH2 select GICV2
Several parts of the ICID table are only necessary for U-Boot proper. Disable them in SPL. This saves around 500 bytes.
Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Peng Fan peng.fan@nxp.com ---
(no changes since v1)
arch/arm/cpu/armv8/fsl-layerscape/icid.c | 2 ++ .../include/asm/arch-fsl-layerscape/fsl_icid.h | 16 ++++++++++++++-- 2 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c index 25cd82f16eb..2d87281ec21 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/icid.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -46,6 +46,7 @@ void set_icids(void) #endif }
+#ifndef CONFIG_SPL_BUILD int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids) { int i, ret; @@ -190,3 +191,4 @@ void fdt_fixup_icid(void *blob) fdt_fixup_fman_icids(blob, smmu_ph); #endif } +#endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index 3c06a55cb85..8af0d35d27b 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -12,11 +12,15 @@ #include <asm/armv8/sec_firmware.h>
struct icid_id_table { +#ifndef CONFIG_SPL_BUILD const char *compat; - u32 id; - u32 reg; phys_addr_t compat_addr; +#endif phys_addr_t reg_addr; + u32 reg; +#ifndef CONFIG_SPL_BUILD + u32 id; +#endif bool le; };
@@ -31,6 +35,13 @@ int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids); void set_icids(void); void fdt_fixup_icid(void *blob);
+#ifdef CONFIG_SPL_BUILD +#define SET_ICID_ENTRY(name, idA, regA, addr, compataddr, _le) \ + { .reg = regA, \ + .reg_addr = addr, \ + .le = _le \ + } +#else #define SET_ICID_ENTRY(name, idA, regA, addr, compataddr, _le) \ { .compat = name, \ .id = idA, \ @@ -39,6 +50,7 @@ void fdt_fixup_icid(void *blob); .reg_addr = addr, \ .le = _le \ } +#endif
#ifdef CONFIG_SYS_FSL_SEC_LE #define SEC_IS_LE true
None of the values in this struct are larger than 256, so we can reduce the members to u8s. This saves around 1K.
include/fsl_csu.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/fsl_csu.h b/include/fsl_csu.h index 0e59ac3c324..40c29687979 100644 --- a/include/fsl_csu.h +++ b/include/fsl_csu.h @@ -24,8 +24,8 @@ enum csu_cslx_access { };
struct csu_ns_dev { - unsigned long ind; - uint32_t val; + u8 ind; + u8 val; };
void enable_layerscape_ns_access(void);
Sean Anderson
