[U-Boot] [PATCH 1/2] PXA: Add MMC driver using the generic MMC framework
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/include/asm/arch-pxa/regs-mmc.h | 155 +++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/pxa_mmc_gen.c | 442 ++++++++++++++++++++++++++++++ 3 files changed, 598 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-pxa/regs-mmc.h create mode 100644 drivers/mmc/pxa_mmc_gen.c
diff --git a/arch/arm/include/asm/arch-pxa/regs-mmc.h b/arch/arm/include/asm/arch-pxa/regs-mmc.h new file mode 100644 index 0000000..fd1eb1e --- /dev/null +++ b/arch/arm/include/asm/arch-pxa/regs-mmc.h @@ -0,0 +1,155 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __REGS_MMC_H__ +#define __REGS_MMC_H__ + +#define MMC0_BASE 0x41100000 +#define MMC1_BASE 0x42000000 + +int pxa_mmc_register(int card_index); + +struct pxa_mmc_regs { + uint32_t strpcl; + uint32_t stat; + uint32_t clkrt; + uint32_t spi; + uint32_t cmdat; + uint32_t resto; + uint32_t rdto; + uint32_t blklen; + uint32_t nob; + uint32_t prtbuf; + uint32_t i_mask; + uint32_t i_reg; + uint32_t cmd; + uint32_t argh; + uint32_t argl; + uint32_t res; + uint32_t rxfifo; + uint32_t txfifo; +}; + +/* MMC_STRPCL */ +#define MMC_STRPCL_STOP_CLK (1 << 0) +#define MMC_STRPCL_START_CLK (1 << 1) + +/* MMC_STAT */ +#define MMC_STAT_END_CMD_RES (1 << 13) +#define MMC_STAT_PRG_DONE (1 << 12) +#define MMC_STAT_DATA_TRAN_DONE (1 << 11) +#define MMC_STAT_CLK_EN (1 << 8) +#define MMC_STAT_RECV_FIFO_FULL (1 << 7) +#define MMC_STAT_XMIT_FIFO_EMPTY (1 << 6) +#define MMC_STAT_RES_CRC_ERROR (1 << 5) +#define MMC_STAT_SPI_READ_ERROR_TOKEN (1 << 4) +#define MMC_STAT_CRC_READ_ERROR (1 << 3) +#define MMC_STAT_CRC_WRITE_ERROR (1 << 2) +#define MMC_STAT_TIME_OUT_RESPONSE (1 << 1) +#define MMC_STAT_READ_TIME_OUT (1 << 0) + +/* MMC_CLKRT */ +#define MMC_CLKRT_20MHZ 0 +#define MMC_CLKRT_10MHZ 1 +#define MMC_CLKRT_5MHZ 2 +#define MMC_CLKRT_2_5MHZ 3 +#define MMC_CLKRT_1_25MHZ 4 +#define MMC_CLKRT_0_625MHZ 5 +#define MMC_CLKRT_0_3125MHZ 6 + +/* MMC_SPI */ +#define MMC_SPI_EN (1 << 0) +#define MMC_SPI_CS_EN (1 << 2) +#define MMC_SPI_CS_ADDRESS (1 << 3) +#define MMC_SPI_CRC_ON (1 << 1) + +/* MMC_CMDAT */ +#define MMC_CMDAT_SD_4DAT (1 << 8) +#define MMC_CMDAT_MMC_DMA_EN (1 << 7) +#define MMC_CMDAT_INIT (1 << 6) +#define MMC_CMDAT_BUSY (1 << 5) +#define MMC_CMDAT_BCR (MMC_CMDAT_BUSY | MMC_CMDAT_INIT) +#define MMC_CMDAT_STREAM (1 << 4) +#define MMC_CMDAT_WRITE (1 << 3) +#define MMC_CMDAT_DATA_EN (1 << 2) +#define MMC_CMDAT_R0 0 +#define MMC_CMDAT_R1 1 +#define MMC_CMDAT_R2 2 +#define MMC_CMDAT_R3 3 + +/* MMC_RESTO */ +#define MMC_RES_TO_MAX_MASK 0x7f + +/* MMC_RDTO */ +#define MMC_READ_TO_MAX_MASK 0xffff + +/* MMC_BLKLEN */ +#define MMC_BLK_LEN_MAX_MASK 0x3ff + +/* MMC_PRTBUF */ +#define MMC_PRTBUF_BUF_PART_FULL (1 << 0) + +/* MMC_I_MASK */ +#define MMC_I_MASK_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_MASK_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_MASK_CLK_IS_OFF (1 << 4) +#define MMC_I_MASK_STOP_CMD (1 << 3) +#define MMC_I_MASK_END_CMD_RES (1 << 2) +#define MMC_I_MASK_PRG_DONE (1 << 1) +#define MMC_I_MASK_DATA_TRAN_DONE (1 << 0) +#define MMC_I_MASK_ALL 0x7f + + +/* MMC_I_REG */ +#define MMC_I_REG_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_REG_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_REG_CLK_IS_OFF (1 << 4) +#define MMC_I_REG_STOP_CMD (1 << 3) +#define MMC_I_REG_END_CMD_RES (1 << 2) +#define MMC_I_REG_PRG_DONE (1 << 1) +#define MMC_I_REG_DATA_TRAN_DONE (1 << 0) + +/* MMC_CMD */ +#define MMC_CMD_INDEX_MAX 0x6f +#define CMD(x) (x) + +#define MMC_R1_IDLE_STATE 0x01 +#define MMC_R1_ERASE_STATE 0x02 +#define MMC_R1_ILLEGAL_CMD 0x04 +#define MMC_R1_COM_CRC_ERR 0x08 +#define MMC_R1_ERASE_SEQ_ERR 0x01 +#define MMC_R1_ADDR_ERR 0x02 +#define MMC_R1_PARAM_ERR 0x04 + +#define MMC_R1B_WP_ERASE_SKIP 0x0002 +#define MMC_R1B_ERR 0x0004 +#define MMC_R1B_CC_ERR 0x0008 +#define MMC_R1B_CARD_ECC_ERR 0x0010 +#define MMC_R1B_WP_VIOLATION 0x0020 +#define MMC_R1B_ERASE_PARAM 0x0040 +#define MMC_R1B_OOR 0x0080 +#define MMC_R1B_IDLE_STATE 0x0100 +#define MMC_R1B_ERASE_RESET 0x0200 +#define MMC_R1B_ILLEGAL_CMD 0x0400 +#define MMC_R1B_COM_CRC_ERR 0x0800 +#define MMC_R1B_ERASE_SEQ_ERR 0x1000 +#define MMC_R1B_ADDR_ERR 0x2000 +#define MMC_R1B_PARAM_ERR 0x4000 + +#endif /* __REGS_MMC_H__ */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3968c14..59bda49 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o COBJS-$(CONFIG_OMAP3_MMC) += omap3_mmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o +COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o diff --git a/drivers/mmc/pxa_mmc_gen.c b/drivers/mmc/pxa_mmc_gen.c new file mode 100644 index 0000000..aa475e5 --- /dev/null +++ b/drivers/mmc/pxa_mmc_gen.c @@ -0,0 +1,442 @@ +/* + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * Loosely based on the old code and Linux's PXA MMC driver + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> + +#include <mmc.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/arch/regs-mmc.h> +#include <asm/io.h> + +/* PXAMMC Generic default config for various CPUs */ +#if defined(CONFIG_PXA250) +#define PXAMMC_FIFO_SIZE 1 +#define PXAMMC_MIN_SPEED 312500 +#define PXAMMC_MAX_SPEED 20000000 +#define PXAMMC_HOST_CAPS (0) +#elif defined(CONFIG_PXA27X) +#define PXAMMC_CRC_SKIP +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 19500000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT) +#elif defined(CONFIG_CPU_MONAHANS) +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 26000000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT | MMC_MODE_HS) +#else +#error "This CPU isn't supported by PXA MMC!" +#endif + +#define MMC_STAT_ERRORS \ + (MMC_STAT_RES_CRC_ERROR | MMC_STAT_SPI_READ_ERROR_TOKEN | \ + MMC_STAT_CRC_READ_ERROR | MMC_STAT_TIME_OUT_RESPONSE | \ + MMC_STAT_READ_TIME_OUT | MMC_STAT_CRC_WRITE_ERROR) + +/* 1 millisecond (in wait cycles below it's 100 x 10uS waits) */ +#define PXA_MMC_TIMEOUT 100 + +struct pxa_mmc_priv { + struct pxa_mmc_regs *regs; +}; + +/* Wait for bit to be set */ +static int pxa_mmc_wait(struct mmc *mmc, uint32_t mask) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* Wait for bit to be set */ + while (--timeout) { + if (readl(®s->stat) & mask) + break; + udelay(10); + } + + if (!timeout) + return -ETIMEDOUT; + + return 0; +} + +static int pxa_mmc_stop_clock(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* If the clock aren't running, exit */ + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + return 0; + + /* Tell the controller to turn off the clock */ + writel(MMC_STRPCL_STOP_CLK, ®s->strpcl); + + /* Wait until the clock are off */ + while (--timeout) { + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + break; + udelay(10); + } + + /* The clock refused to stop, scream and die a painful death */ + if (!timeout) + return -ETIMEDOUT; + + /* The clock stopped correctly */ + return 0; +} + +static int pxa_mmc_start_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + uint32_t cmdat) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + int ret; + + /* The card can send a "busy" response */ + if (cmd->flags & MMC_RSP_BUSY) + cmdat |= MMC_CMDAT_BUSY; + + /* Inform the controller about response type */ + switch (cmd->resp_type) { + case MMC_RSP_R1: + case MMC_RSP_R1b: + cmdat |= MMC_CMDAT_R1; + break; + case MMC_RSP_R2: + cmdat |= MMC_CMDAT_R2; + break; + case MMC_RSP_R3: + cmdat |= MMC_CMDAT_R3; + break; + default: + break; + } + + /* Load command and it's arguments into the controller */ + writel(cmd->cmdidx, ®s->cmd); + writel(cmd->cmdarg >> 16, ®s->argh); + writel(cmd->cmdarg & 0xffff, ®s->argl); + writel(cmdat, ®s->cmdat); + + /* Start the controller clock and wait until they are started */ + writel(MMC_STRPCL_START_CLK, ®s->strpcl); + + ret = pxa_mmc_wait(mmc, MMC_STAT_CLK_EN); + if (ret) + return ret; + + /* Correct and happy end */ + return 0; +} + +static int pxa_mmc_cmd_done(struct mmc *mmc, struct mmc_cmd *cmd) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t a, b, c; + int i; + int stat; + + /* Read the controller status */ + stat = readl(®s->stat); + + /* + * Linux says: + * Did I mention this is Sick. We always need to + * discard the upper 8 bits of the first 16-bit word. + */ + a = readl(®s->res) & 0xffff; + for (i = 0; i < 4; i++) { + b = readl(®s->res) & 0xffff; + c = readl(®s->res) & 0xffff; + cmd->response[i] = (a << 24) | (b << 8) | (c >> 8); + a = c; + } + + /* The command response didn't arrive */ + if (stat & MMC_STAT_TIME_OUT_RESPONSE) + return -ETIMEDOUT; + else if (stat & MMC_STAT_RES_CRC_ERROR && cmd->flags & MMC_RSP_CRC) { +#ifdef PXAMMC_CRC_SKIP + if (cmd->flags & MMC_RSP_136 && cmd->response[0] & (1 << 31)) + printf("Ignoring CRC, this may be dangerous!\n"); + else +#endif + return -EILSEQ; + } + + /* The command response was successfully read */ + return 0; +} + +static int pxa_mmc_do_read_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->dest; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller has data ready */ + if (readl(®s->i_reg) & MMC_I_REG_RXFIFO_RD_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + /* Read data into the buffer */ + while (size--) + *buf++ = readl(®s->rxfifo); + + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_do_write_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->src; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller is ready to receive data */ + if (readl(®s->i_reg) & MMC_I_REG_TXFIFO_WR_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + while (size--) + writel(*buf++, ®s->txfifo); + + if (min(len, PXAMMC_FIFO_SIZE) < 32) + writel(MMC_PRTBUF_BUF_PART_FULL, ®s->prtbuf); + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + /* Wait until the data are really written to the card */ + ret = pxa_mmc_wait(mmc, MMC_STAT_PRG_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_request(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t cmdat = 0; + int ret; + + /* Stop the controller */ + ret = pxa_mmc_stop_clock(mmc); + if (ret) + return ret; + + /* If we're doing data transfer, configure the controller accordingly */ + if (data) { + writel(data->blocks, ®s->nob); + writel(data->blocksize, ®s->blklen); + /* This delay can be optimized, but stick with max value */ + writel(0xffff, ®s->rdto); + cmdat |= MMC_CMDAT_DATA_EN; + if (data->flags & MMC_DATA_WRITE) + cmdat |= MMC_CMDAT_WRITE; + } + + /* Run in 4bit mode if the card can do it */ + if (mmc->bus_width == 4) + cmdat |= MMC_CMDAT_SD_4DAT; + + /* Execute the command */ + ret = pxa_mmc_start_cmd(mmc, cmd, cmdat); + if (ret) + return ret; + + /* Wait until the command completes */ + ret = pxa_mmc_wait(mmc, MMC_STAT_END_CMD_RES); + if (ret) + return ret; + + /* Read back the result */ + ret = pxa_mmc_cmd_done(mmc, cmd); + if (ret) + return ret; + + /* In case there was a data transfer scheduled, do it */ + if (data) { + if (data->flags & MMC_DATA_WRITE) + pxa_mmc_do_write_xfer(mmc, data); + else + pxa_mmc_do_read_xfer(mmc, data); + } + + return 0; +} + +static void pxa_mmc_set_ios(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t tmp; + uint32_t pxa_mmc_clock; + + if (!mmc->clock) { + pxa_mmc_stop_clock(mmc); + return; + } + + /* PXA3xx can do 26MHz with special settings. */ + if (mmc->clock == 26000000) { + writel(0x7, ®s->clkrt); + return; + } + + /* Set clock to the card the usual way. */ + pxa_mmc_clock = 0; + tmp = mmc->f_max / mmc->clock; + tmp += tmp % 2; + + while (tmp > 1) { + pxa_mmc_clock++; + tmp >>= 1; + } + + writel(pxa_mmc_clock, ®s->clkrt); +} + +static int pxa_mmc_init(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + + /* Make sure the clock are stopped */ + pxa_mmc_stop_clock(mmc); + + /* Turn off SPI mode */ + writel(0, ®s->spi); + + /* Set up maximum timeout to wait for command response */ + writel(MMC_RES_TO_MAX_MASK, ®s->resto); + + /* Mask all interrupts */ + writel(~(MMC_I_MASK_TXFIFO_WR_REQ | MMC_I_MASK_RXFIFO_RD_REQ), + ®s->i_mask); + return 0; +} + +int pxa_mmc_register(int card_index) +{ + struct mmc *mmc; + struct pxa_mmc_priv *priv; + uint32_t reg; + int ret = -ENOMEM; + + mmc = malloc(sizeof(struct mmc)); + if (!mmc) + goto err0; + + priv = malloc(sizeof(struct pxa_mmc_priv)); + if (!priv) + goto err1; + + switch (card_index) { + case 0: + priv->regs = (struct pxa_mmc_regs *)MMC0_BASE; + break; + case 1: + priv->regs = (struct pxa_mmc_regs *)MMC1_BASE; + break; + default: + printf("PXA MMC: Invalid MMC controller ID (card_index = %d)\n", + card_index); + goto err2; + } + + mmc->priv = priv; + + sprintf(mmc->name, "PXA MMC"); + mmc->send_cmd = pxa_mmc_request; + mmc->set_ios = pxa_mmc_set_ios; + mmc->init = pxa_mmc_init; + + mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + mmc->f_max = PXAMMC_MAX_SPEED; + mmc->f_min = PXAMMC_MIN_SPEED; + mmc->host_caps = PXAMMC_HOST_CAPS; + + mmc->b_max = 0; + +#ifndef CONFIG_CPU_MONAHANS /* PXA2xx */ + reg = readl(CKEN); + reg |= CKEN12_MMC; + writel(reg, CKEN); +#else /* PXA3xx */ + reg = readl(CKENA); + reg |= CKENA_12_MMC0 | CKENA_13_MMC1; + writel(reg, CKENA); +#endif + + mmc_register(mmc); + + return 0; + +err2: + free(priv); +err1: + free(mmc); +err0: + return ret; +}
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- board/vpac270/vpac270.c | 8 ++++++++ include/configs/vpac270.h | 3 ++- 2 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 43bbdff..d3f03c0 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -21,6 +21,7 @@
#include <common.h> #include <asm/arch/hardware.h> +#include <asm/arch/regs-mmc.h> #include <netdev.h> #include <serial.h> #include <asm/io.h> @@ -72,6 +73,13 @@ void dram_init_banksize(void) #endif }
+#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); +} +#endif + #ifdef CONFIG_CMD_USB int usb_board_init(void) { diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index ea77971..9c3980d 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -108,7 +108,8 @@ */ #ifdef CONFIG_CMD_MMC #define CONFIG_MMC -#define CONFIG_PXA_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2
Hey Andy,
maybe you can pick this up now?
Cheers
Hi Marek,
- Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com
- MA 02111-1307 USA
- uint32_t strpcl;
- uint32_t stat;
- uint32_t clkrt;
- uint32_t spi;
- uint32_t cmdat;
- uint32_t resto;
- uint32_t rdto;
- uint32_t blklen;
- uint32_t nob;
- uint32_t prtbuf;
- uint32_t i_mask;
- uint32_t i_reg;
- uint32_t cmd;
- uint32_t argh;
- uint32_t argl;
- uint32_t res;
- uint32_t rxfifo;
- uint32_t txfifo;
Isn't space would be enough? I mean, they all the same type, so no alignment issues...
You've missed this one
All the above defines are really unnecessarily "tabbed"... The values are fine, but why the names?
- Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com
- Loosely based on the old code and Linux's PXA MMC driver
- MA 02111-1307 USA
Same here... and below... why?
- (MMC_STAT_RES_CRC_ERROR | MMC_STAT_SPI_READ_ERROR_TOKEN | \
- MMC_STAT_CRC_READ_ERROR | MMC_STAT_TIME_OUT_RESPONSE | \
- MMC_STAT_READ_TIME_OUT | MMC_STAT_CRC_WRITE_ERROR)
- struct pxa_mmc_regs *regs;
- struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv;
- struct pxa_mmc_regs *regs = priv->regs;
- unsigned int timeout = PXA_MMC_TIMEOUT;
- /* Wait for bit to be set */
- while (--timeout) {
break;
udelay(10);
- if (!timeout)
return -ETIMEDOUT;
- /* If the clock aren't running, exit */
- if (!(readl(®s->stat) & MMC_STAT_CLK_EN))
- /* Tell the controller to turn off the clock */
- writel(MMC_STRPCL_STOP_CLK, ®s->strpcl);
- /* Wait until the clock are off */
break;
udelay(10);
- /* The clock refused to stop, scream and die a painful death */
- if (!timeout)
return -ETIMEDOUT;
- /* The clock stopped correctly */
uint32_t cmdat)
- int ret;
- /* The card can send a "busy" response */
- if (cmd->flags & MMC_RSP_BUSY)
- /* Inform the controller about response type */
- switch (cmd->resp_type) {
- case MMC_RSP_R1:
- case MMC_RSP_R1b:
break;
- case MMC_RSP_R2:
break;
- case MMC_RSP_R3:
break;
- default:
break;
- /* Load command and it's arguments into the controller */
- writel(cmd->cmdidx, ®s->cmd);
- writel(cmd->cmdarg >> 16, ®s->argh);
- writel(cmd->cmdarg & 0xffff, ®s->argl);
- writel(cmdat, ®s->cmdat);
- /* Start the controller clock and wait until they are started */
- writel(MMC_STRPCL_START_CLK, ®s->strpcl);
- ret = pxa_mmc_wait(mmc, MMC_STAT_CLK_EN);
- if (ret)
return ret;
- /* Correct and happy end */
- uint32_t a, b, c;
- int i;
- int stat;
- /* Read the controller status */
- stat = readl(®s->stat);
* Linux says:
- a = readl(®s->res) & 0xffff;
- for (i = 0; i < 4; i++) {
a = c;
- /* The command response didn't arrive */
- if (stat & MMC_STAT_TIME_OUT_RESPONSE)
return -ETIMEDOUT;
- else if (stat & MMC_STAT_RES_CRC_ERROR && cmd->flags & MMC_RSP_CRC) {
else
return -EILSEQ;
- /* The command response was successfully read */
- uint32_t len;
- uint32_t *buf = (uint32_t *)data->dest;
- int size;
- int ret;
- len = data->blocks * data->blocksize;
- while (len) {
len -= size;
size /= 4;
while (size--)
return -EIO;
- /* Wait for the transmission-done interrupt */
- ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE);
- if (ret)
return ret;
- uint32_t len;
- uint32_t *buf = (uint32_t *)data->src;
- int size;
- int ret;
- while (len) {
len -= size;
size /= 4;
while (size--)
return -EIO;
- if (ret)
return ret;
- /* Wait until the data are really written to the card */
- ret = pxa_mmc_wait(mmc, MMC_STAT_PRG_DONE);
- if (ret)
return ret;
- uint32_t cmdat = 0;
- int ret;
- /* Stop the controller */
- ret = pxa_mmc_stop_clock(mmc);
- if (ret)
return ret;
- /* If we're doing data transfer, configure the controller accordingly */
- if (data) {
- /* Run in 4bit mode if the card can do it */
- if (mmc->bus_width == 4)
- /* Execute the command */
- ret = pxa_mmc_start_cmd(mmc, cmd, cmdat);
- if (ret)
return ret;
- /* Wait until the command completes */
- ret = pxa_mmc_wait(mmc, MMC_STAT_END_CMD_RES);
- if (ret)
return ret;
- /* Read back the result */
- ret = pxa_mmc_cmd_done(mmc, cmd);
- if (ret)
return ret;
- /* In case there was a data transfer scheduled, do it */
- if (data) {
else
- uint32_t tmp;
- uint32_t pxa_mmc_clock;
- if (!mmc->clock) {
return;
- /* PXA3xx can do 26MHz with special settings. */
- if (mmc->clock == 26000000) {
return;
- /* Set clock to the card the usual way. */
- pxa_mmc_clock = 0;
- tmp = mmc->f_max / mmc->clock;
- tmp += tmp % 2;
- while (tmp > 1) {
pxa_mmc_clock++;
tmp >>= 1;
- writel(pxa_mmc_clock, ®s->clkrt);
- /* Make sure the clock are stopped */
- pxa_mmc_stop_clock(mmc);
- /* Turn off SPI mode */
- writel(0, ®s->spi);
- /* Set up maximum timeout to wait for command response */
- writel(MMC_RES_TO_MAX_MASK, ®s->resto);
- /* Mask all interrupts */
- writel(~(MMC_I_MASK_TXFIFO_WR_REQ | MMC_I_MASK_RXFIFO_RD_REQ),
®s->i_mask);
- struct mmc *mmc;
- struct pxa_mmc_priv *priv;
- uint32_t reg;
- int ret = -ENOMEM;
- mmc = malloc(sizeof(struct mmc));
- if (!mmc)
goto err0;
- priv = malloc(sizeof(struct pxa_mmc_priv));
- if (!priv)
goto err1;
- switch (card_index) {
- case 0:
break;
- case 1:
break;
- default:
card_index);
goto err2;
- mmc->priv = priv;
- sprintf(mmc->name, "PXA MMC");
- mmc->send_cmd = pxa_mmc_request;
- mmc->set_ios = pxa_mmc_set_ios;
- mmc->init = pxa_mmc_init;
- mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34;
- mmc->f_max = PXAMMC_MAX_SPEED;
- mmc->f_min = PXAMMC_MIN_SPEED;
- mmc->host_caps = PXAMMC_HOST_CAPS;
- mmc->b_max = 0;
- reg = readl(CKEN);
- reg |= CKEN12_MMC;
- writel(reg, CKEN);
+#else /* PXA3xx */
- reg = readl(CKENA);
- reg |= CKENA_12_MMC0 | CKENA_13_MMC1;
- writel(reg, CKENA);
- mmc_register(mmc);
+err2:
- free(priv);
+err1:
- free(mmc);
+err0:
- return ret;
Hi Marek,
Hi Igor,
- MA 02111-1307 USA
- uint32_t strpcl;
- uint32_t stat;
- uint32_t clkrt;
- uint32_t spi;
- uint32_t cmdat;
- uint32_t resto;
- uint32_t rdto;
- uint32_t blklen;
- uint32_t nob;
- uint32_t prtbuf;
- uint32_t i_mask;
- uint32_t i_reg;
- uint32_t cmd;
- uint32_t argh;
- uint32_t argl;
- uint32_t res;
- uint32_t rxfifo;
- uint32_t txfifo;
It's more readable like this, though that's likely an issue of personal taste.
MMC_CMDAT_INIT)
Thanks
I'm used to put tabs there ... is there actually any rule against that ? Checkpatch doesn't complain.
Cheers
On 11/01/11 14:20, Marek Vasut wrote:
Hi Marek,
Hi Igor,
- MA 02111-1307 USA
- uint32_t strpcl;
- uint32_t stat;
- uint32_t clkrt;
- uint32_t spi;
- uint32_t cmdat;
- uint32_t resto;
- uint32_t rdto;
- uint32_t blklen;
- uint32_t nob;
- uint32_t prtbuf;
- uint32_t i_mask;
- uint32_t i_reg;
- uint32_t cmd;
- uint32_t argh;
- uint32_t argl;
- uint32_t res;
- uint32_t rxfifo;
- uint32_t txfifo;
Agreed, it is personal taste.
MMC_CMDAT_INIT)
Thanks
There is no rule, but it seems redundant, especially with the 80 characters limit (though it is not a hard limit).
Cheers
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/include/asm/arch-pxa/regs-mmc.h | 154 +++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/pxa_mmc_gen.c | 442 ++++++++++++++++++++++++++++++ 3 files changed, 597 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-pxa/regs-mmc.h create mode 100644 drivers/mmc/pxa_mmc_gen.c
V2: Squash CMD(x) and use #define[space]
diff --git a/arch/arm/include/asm/arch-pxa/regs-mmc.h b/arch/arm/include/asm/arch-pxa/regs-mmc.h new file mode 100644 index 0000000..6b7dfd3 --- /dev/null +++ b/arch/arm/include/asm/arch-pxa/regs-mmc.h @@ -0,0 +1,154 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __REGS_MMC_H__ +#define __REGS_MMC_H__ + +#define MMC0_BASE 0x41100000 +#define MMC1_BASE 0x42000000 + +int pxa_mmc_register(int card_index); + +struct pxa_mmc_regs { + uint32_t strpcl; + uint32_t stat; + uint32_t clkrt; + uint32_t spi; + uint32_t cmdat; + uint32_t resto; + uint32_t rdto; + uint32_t blklen; + uint32_t nob; + uint32_t prtbuf; + uint32_t i_mask; + uint32_t i_reg; + uint32_t cmd; + uint32_t argh; + uint32_t argl; + uint32_t res; + uint32_t rxfifo; + uint32_t txfifo; +}; + +/* MMC_STRPCL */ +#define MMC_STRPCL_STOP_CLK (1 << 0) +#define MMC_STRPCL_START_CLK (1 << 1) + +/* MMC_STAT */ +#define MMC_STAT_END_CMD_RES (1 << 13) +#define MMC_STAT_PRG_DONE (1 << 12) +#define MMC_STAT_DATA_TRAN_DONE (1 << 11) +#define MMC_STAT_CLK_EN (1 << 8) +#define MMC_STAT_RECV_FIFO_FULL (1 << 7) +#define MMC_STAT_XMIT_FIFO_EMPTY (1 << 6) +#define MMC_STAT_RES_CRC_ERROR (1 << 5) +#define MMC_STAT_SPI_READ_ERROR_TOKEN (1 << 4) +#define MMC_STAT_CRC_READ_ERROR (1 << 3) +#define MMC_STAT_CRC_WRITE_ERROR (1 << 2) +#define MMC_STAT_TIME_OUT_RESPONSE (1 << 1) +#define MMC_STAT_READ_TIME_OUT (1 << 0) + +/* MMC_CLKRT */ +#define MMC_CLKRT_20MHZ 0 +#define MMC_CLKRT_10MHZ 1 +#define MMC_CLKRT_5MHZ 2 +#define MMC_CLKRT_2_5MHZ 3 +#define MMC_CLKRT_1_25MHZ 4 +#define MMC_CLKRT_0_625MHZ 5 +#define MMC_CLKRT_0_3125MHZ 6 + +/* MMC_SPI */ +#define MMC_SPI_EN (1 << 0) +#define MMC_SPI_CS_EN (1 << 2) +#define MMC_SPI_CS_ADDRESS (1 << 3) +#define MMC_SPI_CRC_ON (1 << 1) + +/* MMC_CMDAT */ +#define MMC_CMDAT_SD_4DAT (1 << 8) +#define MMC_CMDAT_MMC_DMA_EN (1 << 7) +#define MMC_CMDAT_INIT (1 << 6) +#define MMC_CMDAT_BUSY (1 << 5) +#define MMC_CMDAT_BCR (MMC_CMDAT_BUSY | MMC_CMDAT_INIT) +#define MMC_CMDAT_STREAM (1 << 4) +#define MMC_CMDAT_WRITE (1 << 3) +#define MMC_CMDAT_DATA_EN (1 << 2) +#define MMC_CMDAT_R0 0 +#define MMC_CMDAT_R1 1 +#define MMC_CMDAT_R2 2 +#define MMC_CMDAT_R3 3 + +/* MMC_RESTO */ +#define MMC_RES_TO_MAX_MASK 0x7f + +/* MMC_RDTO */ +#define MMC_READ_TO_MAX_MASK 0xffff + +/* MMC_BLKLEN */ +#define MMC_BLK_LEN_MAX_MASK 0x3ff + +/* MMC_PRTBUF */ +#define MMC_PRTBUF_BUF_PART_FULL (1 << 0) + +/* MMC_I_MASK */ +#define MMC_I_MASK_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_MASK_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_MASK_CLK_IS_OFF (1 << 4) +#define MMC_I_MASK_STOP_CMD (1 << 3) +#define MMC_I_MASK_END_CMD_RES (1 << 2) +#define MMC_I_MASK_PRG_DONE (1 << 1) +#define MMC_I_MASK_DATA_TRAN_DONE (1 << 0) +#define MMC_I_MASK_ALL 0x7f + + +/* MMC_I_REG */ +#define MMC_I_REG_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_REG_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_REG_CLK_IS_OFF (1 << 4) +#define MMC_I_REG_STOP_CMD (1 << 3) +#define MMC_I_REG_END_CMD_RES (1 << 2) +#define MMC_I_REG_PRG_DONE (1 << 1) +#define MMC_I_REG_DATA_TRAN_DONE (1 << 0) + +/* MMC_CMD */ +#define MMC_CMD_INDEX_MAX 0x6f + +#define MMC_R1_IDLE_STATE 0x01 +#define MMC_R1_ERASE_STATE 0x02 +#define MMC_R1_ILLEGAL_CMD 0x04 +#define MMC_R1_COM_CRC_ERR 0x08 +#define MMC_R1_ERASE_SEQ_ERR 0x01 +#define MMC_R1_ADDR_ERR 0x02 +#define MMC_R1_PARAM_ERR 0x04 + +#define MMC_R1B_WP_ERASE_SKIP 0x0002 +#define MMC_R1B_ERR 0x0004 +#define MMC_R1B_CC_ERR 0x0008 +#define MMC_R1B_CARD_ECC_ERR 0x0010 +#define MMC_R1B_WP_VIOLATION 0x0020 +#define MMC_R1B_ERASE_PARAM 0x0040 +#define MMC_R1B_OOR 0x0080 +#define MMC_R1B_IDLE_STATE 0x0100 +#define MMC_R1B_ERASE_RESET 0x0200 +#define MMC_R1B_ILLEGAL_CMD 0x0400 +#define MMC_R1B_COM_CRC_ERR 0x0800 +#define MMC_R1B_ERASE_SEQ_ERR 0x1000 +#define MMC_R1B_ADDR_ERR 0x2000 +#define MMC_R1B_PARAM_ERR 0x4000 + +#endif /* __REGS_MMC_H__ */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 6e94860..9f9db75 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o +COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o diff --git a/drivers/mmc/pxa_mmc_gen.c b/drivers/mmc/pxa_mmc_gen.c new file mode 100644 index 0000000..28e37b4 --- /dev/null +++ b/drivers/mmc/pxa_mmc_gen.c @@ -0,0 +1,442 @@ +/* + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * Loosely based on the old code and Linux's PXA MMC driver + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> + +#include <mmc.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/arch/regs-mmc.h> +#include <asm/io.h> + +/* PXAMMC Generic default config for various CPUs */ +#if defined(CONFIG_PXA250) +#define PXAMMC_FIFO_SIZE 1 +#define PXAMMC_MIN_SPEED 312500 +#define PXAMMC_MAX_SPEED 20000000 +#define PXAMMC_HOST_CAPS (0) +#elif defined(CONFIG_PXA27X) +#define PXAMMC_CRC_SKIP +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 19500000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT) +#elif defined(CONFIG_CPU_MONAHANS) +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 26000000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT | MMC_MODE_HS) +#else +#error "This CPU isn't supported by PXA MMC!" +#endif + +#define MMC_STAT_ERRORS \ + (MMC_STAT_RES_CRC_ERROR | MMC_STAT_SPI_READ_ERROR_TOKEN | \ + MMC_STAT_CRC_READ_ERROR | MMC_STAT_TIME_OUT_RESPONSE | \ + MMC_STAT_READ_TIME_OUT | MMC_STAT_CRC_WRITE_ERROR) + +/* 1 millisecond (in wait cycles below it's 100 x 10uS waits) */ +#define PXA_MMC_TIMEOUT 100 + +struct pxa_mmc_priv { + struct pxa_mmc_regs *regs; +}; + +/* Wait for bit to be set */ +static int pxa_mmc_wait(struct mmc *mmc, uint32_t mask) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* Wait for bit to be set */ + while (--timeout) { + if (readl(®s->stat) & mask) + break; + udelay(10); + } + + if (!timeout) + return -ETIMEDOUT; + + return 0; +} + +static int pxa_mmc_stop_clock(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* If the clock aren't running, exit */ + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + return 0; + + /* Tell the controller to turn off the clock */ + writel(MMC_STRPCL_STOP_CLK, ®s->strpcl); + + /* Wait until the clock are off */ + while (--timeout) { + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + break; + udelay(10); + } + + /* The clock refused to stop, scream and die a painful death */ + if (!timeout) + return -ETIMEDOUT; + + /* The clock stopped correctly */ + return 0; +} + +static int pxa_mmc_start_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + uint32_t cmdat) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + int ret; + + /* The card can send a "busy" response */ + if (cmd->flags & MMC_RSP_BUSY) + cmdat |= MMC_CMDAT_BUSY; + + /* Inform the controller about response type */ + switch (cmd->resp_type) { + case MMC_RSP_R1: + case MMC_RSP_R1b: + cmdat |= MMC_CMDAT_R1; + break; + case MMC_RSP_R2: + cmdat |= MMC_CMDAT_R2; + break; + case MMC_RSP_R3: + cmdat |= MMC_CMDAT_R3; + break; + default: + break; + } + + /* Load command and it's arguments into the controller */ + writel(cmd->cmdidx, ®s->cmd); + writel(cmd->cmdarg >> 16, ®s->argh); + writel(cmd->cmdarg & 0xffff, ®s->argl); + writel(cmdat, ®s->cmdat); + + /* Start the controller clock and wait until they are started */ + writel(MMC_STRPCL_START_CLK, ®s->strpcl); + + ret = pxa_mmc_wait(mmc, MMC_STAT_CLK_EN); + if (ret) + return ret; + + /* Correct and happy end */ + return 0; +} + +static int pxa_mmc_cmd_done(struct mmc *mmc, struct mmc_cmd *cmd) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t a, b, c; + int i; + int stat; + + /* Read the controller status */ + stat = readl(®s->stat); + + /* + * Linux says: + * Did I mention this is Sick. We always need to + * discard the upper 8 bits of the first 16-bit word. + */ + a = readl(®s->res) & 0xffff; + for (i = 0; i < 4; i++) { + b = readl(®s->res) & 0xffff; + c = readl(®s->res) & 0xffff; + cmd->response[i] = (a << 24) | (b << 8) | (c >> 8); + a = c; + } + + /* The command response didn't arrive */ + if (stat & MMC_STAT_TIME_OUT_RESPONSE) + return -ETIMEDOUT; + else if (stat & MMC_STAT_RES_CRC_ERROR && cmd->flags & MMC_RSP_CRC) { +#ifdef PXAMMC_CRC_SKIP + if (cmd->flags & MMC_RSP_136 && cmd->response[0] & (1 << 31)) + printf("Ignoring CRC, this may be dangerous!\n"); + else +#endif + return -EILSEQ; + } + + /* The command response was successfully read */ + return 0; +} + +static int pxa_mmc_do_read_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->dest; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller has data ready */ + if (readl(®s->i_reg) & MMC_I_REG_RXFIFO_RD_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + /* Read data into the buffer */ + while (size--) + *buf++ = readl(®s->rxfifo); + + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_do_write_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->src; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller is ready to receive data */ + if (readl(®s->i_reg) & MMC_I_REG_TXFIFO_WR_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + while (size--) + writel(*buf++, ®s->txfifo); + + if (min(len, PXAMMC_FIFO_SIZE) < 32) + writel(MMC_PRTBUF_BUF_PART_FULL, ®s->prtbuf); + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + /* Wait until the data are really written to the card */ + ret = pxa_mmc_wait(mmc, MMC_STAT_PRG_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_request(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t cmdat = 0; + int ret; + + /* Stop the controller */ + ret = pxa_mmc_stop_clock(mmc); + if (ret) + return ret; + + /* If we're doing data transfer, configure the controller accordingly */ + if (data) { + writel(data->blocks, ®s->nob); + writel(data->blocksize, ®s->blklen); + /* This delay can be optimized, but stick with max value */ + writel(0xffff, ®s->rdto); + cmdat |= MMC_CMDAT_DATA_EN; + if (data->flags & MMC_DATA_WRITE) + cmdat |= MMC_CMDAT_WRITE; + } + + /* Run in 4bit mode if the card can do it */ + if (mmc->bus_width == 4) + cmdat |= MMC_CMDAT_SD_4DAT; + + /* Execute the command */ + ret = pxa_mmc_start_cmd(mmc, cmd, cmdat); + if (ret) + return ret; + + /* Wait until the command completes */ + ret = pxa_mmc_wait(mmc, MMC_STAT_END_CMD_RES); + if (ret) + return ret; + + /* Read back the result */ + ret = pxa_mmc_cmd_done(mmc, cmd); + if (ret) + return ret; + + /* In case there was a data transfer scheduled, do it */ + if (data) { + if (data->flags & MMC_DATA_WRITE) + pxa_mmc_do_write_xfer(mmc, data); + else + pxa_mmc_do_read_xfer(mmc, data); + } + + return 0; +} + +static void pxa_mmc_set_ios(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t tmp; + uint32_t pxa_mmc_clock; + + if (!mmc->clock) { + pxa_mmc_stop_clock(mmc); + return; + } + + /* PXA3xx can do 26MHz with special settings. */ + if (mmc->clock == 26000000) { + writel(0x7, ®s->clkrt); + return; + } + + /* Set clock to the card the usual way. */ + pxa_mmc_clock = 0; + tmp = mmc->f_max / mmc->clock; + tmp += tmp % 2; + + while (tmp > 1) { + pxa_mmc_clock++; + tmp >>= 1; + } + + writel(pxa_mmc_clock, ®s->clkrt); +} + +static int pxa_mmc_init(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + + /* Make sure the clock are stopped */ + pxa_mmc_stop_clock(mmc); + + /* Turn off SPI mode */ + writel(0, ®s->spi); + + /* Set up maximum timeout to wait for command response */ + writel(MMC_RES_TO_MAX_MASK, ®s->resto); + + /* Mask all interrupts */ + writel(~(MMC_I_MASK_TXFIFO_WR_REQ | MMC_I_MASK_RXFIFO_RD_REQ), + ®s->i_mask); + return 0; +} + +int pxa_mmc_register(int card_index) +{ + struct mmc *mmc; + struct pxa_mmc_priv *priv; + uint32_t reg; + int ret = -ENOMEM; + + mmc = malloc(sizeof(struct mmc)); + if (!mmc) + goto err0; + + priv = malloc(sizeof(struct pxa_mmc_priv)); + if (!priv) + goto err1; + + switch (card_index) { + case 0: + priv->regs = (struct pxa_mmc_regs *)MMC0_BASE; + break; + case 1: + priv->regs = (struct pxa_mmc_regs *)MMC1_BASE; + break; + default: + printf("PXA MMC: Invalid MMC controller ID (card_index = %d)\n", + card_index); + goto err2; + } + + mmc->priv = priv; + + sprintf(mmc->name, "PXA MMC"); + mmc->send_cmd = pxa_mmc_request; + mmc->set_ios = pxa_mmc_set_ios; + mmc->init = pxa_mmc_init; + + mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + mmc->f_max = PXAMMC_MAX_SPEED; + mmc->f_min = PXAMMC_MIN_SPEED; + mmc->host_caps = PXAMMC_HOST_CAPS; + + mmc->b_max = 0; + +#ifndef CONFIG_CPU_MONAHANS /* PXA2xx */ + reg = readl(CKEN); + reg |= CKEN12_MMC; + writel(reg, CKEN); +#else /* PXA3xx */ + reg = readl(CKENA); + reg |= CKENA_12_MMC0 | CKENA_13_MMC1; + writel(reg, CKENA); +#endif + + mmc_register(mmc); + + return 0; + +err2: + free(priv); +err1: + free(mmc); +err0: + return ret; +}
You have 3 spaces here while all other lines use tab.
spaces instead before the parenthesis
MMC_CMDAT_INIT)
Thanks! I need better old-crap-linting tool now :)
V2: Squash CMD(x) and use #define[space] V3: Fix whitespace issues
diff --git a/arch/arm/include/asm/arch-pxa/regs-mmc.h b/arch/arm/include/asm/arch-pxa/regs-mmc.h new file mode 100644 index 0000000..b5c9b3b --- /dev/null +++ b/arch/arm/include/asm/arch-pxa/regs-mmc.h @@ -0,0 +1,154 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __REGS_MMC_H__ +#define __REGS_MMC_H__ + +#define MMC0_BASE 0x41100000 +#define MMC1_BASE 0x42000000 + +int pxa_mmc_register(int card_index); + +struct pxa_mmc_regs { + uint32_t strpcl; + uint32_t stat; + uint32_t clkrt; + uint32_t spi; + uint32_t cmdat; + uint32_t resto; + uint32_t rdto; + uint32_t blklen; + uint32_t nob; + uint32_t prtbuf; + uint32_t i_mask; + uint32_t i_reg; + uint32_t cmd; + uint32_t argh; + uint32_t argl; + uint32_t res; + uint32_t rxfifo; + uint32_t txfifo; +}; + +/* MMC_STRPCL */ +#define MMC_STRPCL_STOP_CLK (1 << 0) +#define MMC_STRPCL_START_CLK (1 << 1) + +/* MMC_STAT */ +#define MMC_STAT_END_CMD_RES (1 << 13) +#define MMC_STAT_PRG_DONE (1 << 12) +#define MMC_STAT_DATA_TRAN_DONE (1 << 11) +#define MMC_STAT_CLK_EN (1 << 8) +#define MMC_STAT_RECV_FIFO_FULL (1 << 7) +#define MMC_STAT_XMIT_FIFO_EMPTY (1 << 6) +#define MMC_STAT_RES_CRC_ERROR (1 << 5) +#define MMC_STAT_SPI_READ_ERROR_TOKEN (1 << 4) +#define MMC_STAT_CRC_READ_ERROR (1 << 3) +#define MMC_STAT_CRC_WRITE_ERROR (1 << 2) +#define MMC_STAT_TIME_OUT_RESPONSE (1 << 1) +#define MMC_STAT_READ_TIME_OUT (1 << 0) + +/* MMC_CLKRT */ +#define MMC_CLKRT_20MHZ 0 +#define MMC_CLKRT_10MHZ 1 +#define MMC_CLKRT_5MHZ 2 +#define MMC_CLKRT_2_5MHZ 3 +#define MMC_CLKRT_1_25MHZ 4 +#define MMC_CLKRT_0_625MHZ 5 +#define MMC_CLKRT_0_3125MHZ 6 + +/* MMC_SPI */ +#define MMC_SPI_EN (1 << 0) +#define MMC_SPI_CS_EN (1 << 2) +#define MMC_SPI_CS_ADDRESS (1 << 3) +#define MMC_SPI_CRC_ON (1 << 1) + +/* MMC_CMDAT */ +#define MMC_CMDAT_SD_4DAT (1 << 8) +#define MMC_CMDAT_MMC_DMA_EN (1 << 7) +#define MMC_CMDAT_INIT (1 << 6) +#define MMC_CMDAT_BUSY (1 << 5) +#define MMC_CMDAT_BCR (MMC_CMDAT_BUSY | MMC_CMDAT_INIT) +#define MMC_CMDAT_STREAM (1 << 4) +#define MMC_CMDAT_WRITE (1 << 3) +#define MMC_CMDAT_DATA_EN (1 << 2) +#define MMC_CMDAT_R0 0 +#define MMC_CMDAT_R1 1 +#define MMC_CMDAT_R2 2 +#define MMC_CMDAT_R3 3 + +/* MMC_RESTO */ +#define MMC_RES_TO_MAX_MASK 0x7f + +/* MMC_RDTO */ +#define MMC_READ_TO_MAX_MASK 0xffff + +/* MMC_BLKLEN */ +#define MMC_BLK_LEN_MAX_MASK 0x3ff + +/* MMC_PRTBUF */ +#define MMC_PRTBUF_BUF_PART_FULL (1 << 0) + +/* MMC_I_MASK */ +#define MMC_I_MASK_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_MASK_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_MASK_CLK_IS_OFF (1 << 4) +#define MMC_I_MASK_STOP_CMD (1 << 3) +#define MMC_I_MASK_END_CMD_RES (1 << 2) +#define MMC_I_MASK_PRG_DONE (1 << 1) +#define MMC_I_MASK_DATA_TRAN_DONE (1 << 0) +#define MMC_I_MASK_ALL 0x7f + + +/* MMC_I_REG */ +#define MMC_I_REG_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_REG_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_REG_CLK_IS_OFF (1 << 4) +#define MMC_I_REG_STOP_CMD (1 << 3) +#define MMC_I_REG_END_CMD_RES (1 << 2) +#define MMC_I_REG_PRG_DONE (1 << 1) +#define MMC_I_REG_DATA_TRAN_DONE (1 << 0) + +/* MMC_CMD */ +#define MMC_CMD_INDEX_MAX 0x6f + +#define MMC_R1_IDLE_STATE 0x01 +#define MMC_R1_ERASE_STATE 0x02 +#define MMC_R1_ILLEGAL_CMD 0x04 +#define MMC_R1_COM_CRC_ERR 0x08 +#define MMC_R1_ERASE_SEQ_ERR 0x01 +#define MMC_R1_ADDR_ERR 0x02 +#define MMC_R1_PARAM_ERR 0x04 + +#define MMC_R1B_WP_ERASE_SKIP 0x0002 +#define MMC_R1B_ERR 0x0004 +#define MMC_R1B_CC_ERR 0x0008 +#define MMC_R1B_CARD_ECC_ERR 0x0010 +#define MMC_R1B_WP_VIOLATION 0x0020 +#define MMC_R1B_ERASE_PARAM 0x0040 +#define MMC_R1B_OOR 0x0080 +#define MMC_R1B_IDLE_STATE 0x0100 +#define MMC_R1B_ERASE_RESET 0x0200 +#define MMC_R1B_ILLEGAL_CMD 0x0400 +#define MMC_R1B_COM_CRC_ERR 0x0800 +#define MMC_R1B_ERASE_SEQ_ERR 0x1000 +#define MMC_R1B_ADDR_ERR 0x2000 +#define MMC_R1B_PARAM_ERR 0x4000 + +#endif /* __REGS_MMC_H__ */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 6e94860..9f9db75 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o +COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o diff --git a/drivers/mmc/pxa_mmc_gen.c b/drivers/mmc/pxa_mmc_gen.c new file mode 100644 index 0000000..28e37b4 --- /dev/null +++ b/drivers/mmc/pxa_mmc_gen.c @@ -0,0 +1,442 @@ +/* + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * Loosely based on the old code and Linux's PXA MMC driver + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> + +#include <mmc.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/arch/regs-mmc.h> +#include <asm/io.h> + +/* PXAMMC Generic default config for various CPUs */ +#if defined(CONFIG_PXA250) +#define PXAMMC_FIFO_SIZE 1 +#define PXAMMC_MIN_SPEED 312500 +#define PXAMMC_MAX_SPEED 20000000 +#define PXAMMC_HOST_CAPS (0) +#elif defined(CONFIG_PXA27X) +#define PXAMMC_CRC_SKIP +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 19500000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT) +#elif defined(CONFIG_CPU_MONAHANS) +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 26000000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT | MMC_MODE_HS) +#else +#error "This CPU isn't supported by PXA MMC!" +#endif + +#define MMC_STAT_ERRORS \ + (MMC_STAT_RES_CRC_ERROR | MMC_STAT_SPI_READ_ERROR_TOKEN | \ + MMC_STAT_CRC_READ_ERROR | MMC_STAT_TIME_OUT_RESPONSE | \ + MMC_STAT_READ_TIME_OUT | MMC_STAT_CRC_WRITE_ERROR) + +/* 1 millisecond (in wait cycles below it's 100 x 10uS waits) */ +#define PXA_MMC_TIMEOUT 100 + +struct pxa_mmc_priv { + struct pxa_mmc_regs *regs; +}; + +/* Wait for bit to be set */ +static int pxa_mmc_wait(struct mmc *mmc, uint32_t mask) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* Wait for bit to be set */ + while (--timeout) { + if (readl(®s->stat) & mask) + break; + udelay(10); + } + + if (!timeout) + return -ETIMEDOUT; + + return 0; +} + +static int pxa_mmc_stop_clock(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* If the clock aren't running, exit */ + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + return 0; + + /* Tell the controller to turn off the clock */ + writel(MMC_STRPCL_STOP_CLK, ®s->strpcl); + + /* Wait until the clock are off */ + while (--timeout) { + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + break; + udelay(10); + } + + /* The clock refused to stop, scream and die a painful death */ + if (!timeout) + return -ETIMEDOUT; + + /* The clock stopped correctly */ + return 0; +} + +static int pxa_mmc_start_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + uint32_t cmdat) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + int ret; + + /* The card can send a "busy" response */ + if (cmd->flags & MMC_RSP_BUSY) + cmdat |= MMC_CMDAT_BUSY; + + /* Inform the controller about response type */ + switch (cmd->resp_type) { + case MMC_RSP_R1: + case MMC_RSP_R1b: + cmdat |= MMC_CMDAT_R1; + break; + case MMC_RSP_R2: + cmdat |= MMC_CMDAT_R2; + break; + case MMC_RSP_R3: + cmdat |= MMC_CMDAT_R3; + break; + default: + break; + } + + /* Load command and it's arguments into the controller */ + writel(cmd->cmdidx, ®s->cmd); + writel(cmd->cmdarg >> 16, ®s->argh); + writel(cmd->cmdarg & 0xffff, ®s->argl); + writel(cmdat, ®s->cmdat); + + /* Start the controller clock and wait until they are started */ + writel(MMC_STRPCL_START_CLK, ®s->strpcl); + + ret = pxa_mmc_wait(mmc, MMC_STAT_CLK_EN); + if (ret) + return ret; + + /* Correct and happy end */ + return 0; +} + +static int pxa_mmc_cmd_done(struct mmc *mmc, struct mmc_cmd *cmd) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t a, b, c; + int i; + int stat; + + /* Read the controller status */ + stat = readl(®s->stat); + + /* + * Linux says: + * Did I mention this is Sick. We always need to + * discard the upper 8 bits of the first 16-bit word. + */ + a = readl(®s->res) & 0xffff; + for (i = 0; i < 4; i++) { + b = readl(®s->res) & 0xffff; + c = readl(®s->res) & 0xffff; + cmd->response[i] = (a << 24) | (b << 8) | (c >> 8); + a = c; + } + + /* The command response didn't arrive */ + if (stat & MMC_STAT_TIME_OUT_RESPONSE) + return -ETIMEDOUT; + else if (stat & MMC_STAT_RES_CRC_ERROR && cmd->flags & MMC_RSP_CRC) { +#ifdef PXAMMC_CRC_SKIP + if (cmd->flags & MMC_RSP_136 && cmd->response[0] & (1 << 31)) + printf("Ignoring CRC, this may be dangerous!\n"); + else +#endif + return -EILSEQ; + } + + /* The command response was successfully read */ + return 0; +} + +static int pxa_mmc_do_read_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->dest; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller has data ready */ + if (readl(®s->i_reg) & MMC_I_REG_RXFIFO_RD_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + /* Read data into the buffer */ + while (size--) + *buf++ = readl(®s->rxfifo); + + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_do_write_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->src; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller is ready to receive data */ + if (readl(®s->i_reg) & MMC_I_REG_TXFIFO_WR_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + while (size--) + writel(*buf++, ®s->txfifo); + + if (min(len, PXAMMC_FIFO_SIZE) < 32) + writel(MMC_PRTBUF_BUF_PART_FULL, ®s->prtbuf); + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + /* Wait until the data are really written to the card */ + ret = pxa_mmc_wait(mmc, MMC_STAT_PRG_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_request(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t cmdat = 0; + int ret; + + /* Stop the controller */ + ret = pxa_mmc_stop_clock(mmc); + if (ret) + return ret; + + /* If we're doing data transfer, configure the controller accordingly */ + if (data) { + writel(data->blocks, ®s->nob); + writel(data->blocksize, ®s->blklen); + /* This delay can be optimized, but stick with max value */ + writel(0xffff, ®s->rdto); + cmdat |= MMC_CMDAT_DATA_EN; + if (data->flags & MMC_DATA_WRITE) + cmdat |= MMC_CMDAT_WRITE; + } + + /* Run in 4bit mode if the card can do it */ + if (mmc->bus_width == 4) + cmdat |= MMC_CMDAT_SD_4DAT; + + /* Execute the command */ + ret = pxa_mmc_start_cmd(mmc, cmd, cmdat); + if (ret) + return ret; + + /* Wait until the command completes */ + ret = pxa_mmc_wait(mmc, MMC_STAT_END_CMD_RES); + if (ret) + return ret; + + /* Read back the result */ + ret = pxa_mmc_cmd_done(mmc, cmd); + if (ret) + return ret; + + /* In case there was a data transfer scheduled, do it */ + if (data) { + if (data->flags & MMC_DATA_WRITE) + pxa_mmc_do_write_xfer(mmc, data); + else + pxa_mmc_do_read_xfer(mmc, data); + } + + return 0; +} + +static void pxa_mmc_set_ios(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t tmp; + uint32_t pxa_mmc_clock; + + if (!mmc->clock) { + pxa_mmc_stop_clock(mmc); + return; + } + + /* PXA3xx can do 26MHz with special settings. */ + if (mmc->clock == 26000000) { + writel(0x7, ®s->clkrt); + return; + } + + /* Set clock to the card the usual way. */ + pxa_mmc_clock = 0; + tmp = mmc->f_max / mmc->clock; + tmp += tmp % 2; + + while (tmp > 1) { + pxa_mmc_clock++; + tmp >>= 1; + } + + writel(pxa_mmc_clock, ®s->clkrt); +} + +static int pxa_mmc_init(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + + /* Make sure the clock are stopped */ + pxa_mmc_stop_clock(mmc); + + /* Turn off SPI mode */ + writel(0, ®s->spi); + + /* Set up maximum timeout to wait for command response */ + writel(MMC_RES_TO_MAX_MASK, ®s->resto); + + /* Mask all interrupts */ + writel(~(MMC_I_MASK_TXFIFO_WR_REQ | MMC_I_MASK_RXFIFO_RD_REQ), + ®s->i_mask); + return 0; +} + +int pxa_mmc_register(int card_index) +{ + struct mmc *mmc; + struct pxa_mmc_priv *priv; + uint32_t reg; + int ret = -ENOMEM; + + mmc = malloc(sizeof(struct mmc)); + if (!mmc) + goto err0; + + priv = malloc(sizeof(struct pxa_mmc_priv)); + if (!priv) + goto err1; + + switch (card_index) { + case 0: + priv->regs = (struct pxa_mmc_regs *)MMC0_BASE; + break; + case 1: + priv->regs = (struct pxa_mmc_regs *)MMC1_BASE; + break; + default: + printf("PXA MMC: Invalid MMC controller ID (card_index = %d)\n", + card_index); + goto err2; + } + + mmc->priv = priv; + + sprintf(mmc->name, "PXA MMC"); + mmc->send_cmd = pxa_mmc_request; + mmc->set_ios = pxa_mmc_set_ios; + mmc->init = pxa_mmc_init; + + mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + mmc->f_max = PXAMMC_MAX_SPEED; + mmc->f_min = PXAMMC_MIN_SPEED; + mmc->host_caps = PXAMMC_HOST_CAPS; + + mmc->b_max = 0; + +#ifndef CONFIG_CPU_MONAHANS /* PXA2xx */ + reg = readl(CKEN); + reg |= CKEN12_MMC; + writel(reg, CKEN); +#else /* PXA3xx */ + reg = readl(CKENA); + reg |= CKENA_12_MMC0 | CKENA_13_MMC1; + writel(reg, CKENA); +#endif + + mmc_register(mmc); + + return 0; + +err2: + free(priv); +err1: + free(mmc); +err0: + return ret; +}
Igor Grinberg
