[U-Boot] [PATCH][v2] powerpc/t104xrdb: Update DDR initialization related settings
Update following DDR related settings for T1040RDB, T1042RDB_PI -Correct number of chip selects to two as t1040 supports two Chip selects. -Update board_specific_parameters udimm structure with settings derived via calibration. -Update ddr_raw_timing sructure corresponding to DIMM. -Set ODT to off. Typically on FSL board, ODT is set to 75 ohm, but on T104xRDB, on setting this , DDR instability is observed. Board-level debugging is in progress.
Verified the updated settings to be working fine with dual-ranked Micron, MT18KSF51272AZ-1G6 DIMM at data rate 1600MT/s.
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- Changes for v2: Udpated description related to ODT off, Removed cpo, write_data_delay, force_2t parameters as they are not longer used.
board/freescale/t104xrdb/ddr.c | 13 +++---------- board/freescale/t104xrdb/ddr.h | 38 ++++++++++++++++++++------------------ include/configs/T1040RDB.h | 2 +- include/configs/T1042RDB_PI.h | 2 +- 4 files changed, 25 insertions(+), 30 deletions(-)
diff --git a/board/freescale/t104xrdb/ddr.c b/board/freescale/t104xrdb/ddr.c index 9009afa..57d0f9c 100644 --- a/board/freescale/t104xrdb/ddr.c +++ b/board/freescale/t104xrdb/ddr.c @@ -46,7 +46,7 @@ void fsl_ddr_board_options(memctl_options_t *popts,
pbsp = udimms[0];
- /* Get clk_adjust, cpo, write_data_delay,2t, according to the board ddr + /* Get clk_adjust according to the board ddr * freqency and n_banks specified in board_specific_parameters table. */ ddr_freq = get_ddr_freq(0) / 1000000; @@ -54,14 +54,10 @@ void fsl_ddr_board_options(memctl_options_t *popts, if (pbsp->n_ranks == pdimm->n_ranks && (pdimm->rank_density >> 30) >= pbsp->rank_gb) { if (ddr_freq <= pbsp->datarate_mhz_high) { - popts->cpo_override = pbsp->cpo; - popts->write_data_delay = - pbsp->write_data_delay; popts->clk_adjust = pbsp->clk_adjust; popts->wrlvl_start = pbsp->wrlvl_start; popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - popts->twot_en = pbsp->force_2t; goto found; } pbsp_highest = pbsp; @@ -74,13 +70,10 @@ void fsl_ddr_board_options(memctl_options_t *popts, printf("for data rate %lu MT/s\n", ddr_freq); printf("Trying to use the highest speed (%u) parameters\n", pbsp_highest->datarate_mhz_high); - popts->cpo_override = pbsp_highest->cpo; - popts->write_data_delay = pbsp_highest->write_data_delay; popts->clk_adjust = pbsp_highest->clk_adjust; popts->wrlvl_start = pbsp_highest->wrlvl_start; popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - popts->twot_en = pbsp_highest->force_2t; } else { panic("DIMM is not supported by this board"); } @@ -112,8 +105,8 @@ found: popts->zq_en = 1;
/* DHC_EN =1, ODT = 75 Ohm */ - popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); - popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_OFF); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_OFF); }
phys_size_t initdram(int board_type) diff --git a/board/freescale/t104xrdb/ddr.h b/board/freescale/t104xrdb/ddr.h index 9276b59..09b30b9 100644 --- a/board/freescale/t104xrdb/ddr.h +++ b/board/freescale/t104xrdb/ddr.h @@ -6,7 +6,6 @@
#ifndef __DDR_H__ #define __DDR_H__ - dimm_params_t ddr_raw_timing = { .n_ranks = 2, .rank_density = 2147483648u, @@ -14,22 +13,21 @@ dimm_params_t ddr_raw_timing = { .primary_sdram_width = 64, .ec_sdram_width = 8, .registered_dimm = 0, - .mirrored_dimm = 1, + .mirrored_dimm = 0, .n_row_addr = 15, .n_col_addr = 10, .n_banks_per_sdram_device = 8, .edc_config = 2, /* ECC */ .burst_lengths_bitmask = 0x0c, - .tckmin_x_ps = 1071, - .caslat_x = 0x2fe << 4, /* 5,6,7,8,9,10,11,13 */ - .taa_ps = 13910, + .caslat_x = 0xfe << 4, /* 5,6,7,8,9,10,11 */ + .taa_ps = 13125, .twr_ps = 15000, - .trcd_ps = 13910, + .trcd_ps = 13125, .trrd_ps = 6000, - .trp_ps = 13910, + .trp_ps = 13125, .tras_ps = 34000, - .trc_ps = 48910, + .trc_ps = 48125, .trfc_ps = 260000, .twtr_ps = 7500, .trtp_ps = 7500, @@ -45,9 +43,6 @@ struct board_specific_parameters { u32 wrlvl_start; u32 wrlvl_ctl_2; u32 wrlvl_ctl_3; - u32 cpo; - u32 write_data_delay; - u32 force_2t; };
/* @@ -59,14 +54,21 @@ struct board_specific_parameters { static const struct board_specific_parameters udimm0[] = { /* * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + * num| hi| rank| clk| wrlvl | wrlvl + * ranks| mhz| GB |adjst| start | ctl2 */ - {2, 1066, 4, 8, 4, 0x05070609, 0x08090a08, 0xff, 2, 0}, - {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, - {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, + {2, 833, 4, 4, 6, 0x06060607, 0x08080807}, + {2, 833, 0, 4, 6, 0x06060607, 0x08080807}, + {2, 1350, 4, 4, 7, 0x0708080A, 0x0A0B0C09}, + {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09}, + {2, 1666, 4, 4, 7, 0x0808090B, 0x0C0D0E0A}, + {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A}, + {1, 833, 4, 4, 6, 0x06060607, 0x08080807}, + {1, 833, 0, 4, 6, 0x06060607, 0x08080807}, + {1, 1350, 4, 4, 7, 0x0708080A, 0x0A0B0C09}, + {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09}, + {1, 1666, 4, 4, 7, 0x0808090B, 0x0C0D0E0A}, + {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A}, {} };
diff --git a/include/configs/T1040RDB.h b/include/configs/T1040RDB.h index 7cfda50..c6c214c 100644 --- a/include/configs/T1040RDB.h +++ b/include/configs/T1040RDB.h @@ -147,7 +147,7 @@
/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ #define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR)
#define CONFIG_DDR_SPD #define CONFIG_SYS_DDR_RAW_TIMING diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h index ed9ca8a..5102d49 100644 --- a/include/configs/T1042RDB_PI.h +++ b/include/configs/T1042RDB_PI.h @@ -147,7 +147,7 @@
Applied to u-boot-mpc85xx/master. Thanks.
York
Priyanka Jain
York Sun
