[U-Boot] Trying to redirect console in Gumstix Overo
I would like to change the console from UART3 to UART2 on a Gumstix Overo platform. Here is what I have done thus far, which doesn't work (as explained below):
Made the following tweaks in include/configs/omap3_overo.h:
a. Changed the console definitions to be:
#define CONFIG_CONS_INDEX 2
#define CONFIG_SYS_NS16550_COM2 OMAP34XX_UART2
#define CONFIG_SERIAL2 2
b. Changed the console line in CONFIG_EXTRA_ENV_SETTINGS to be:
"console=ttyS1,115200n8\0"
This isn't quite working. When I initially boot the Overo, I get the following brief output (on ttyS2, not ttyS1), but then the computer doesn't boot further:
Texas Instruments X-Loader 1.4.3 (Feb 16 2010 - 10:36:47)
Reading boot sector
Loading u-boot.bin from mmc
What else do I need to change? Is there some default environment or NAND settings or anything else I need to change or get rid of before this will work? I am running of an SD card.
Any insight is very appreciated!
John
John P. Wilson Engineer Erigo Technologies LLC 64 Main St./P.O. Box 899 Enfield, NH 03748
P: 603.632.4156 C: 603.252.2087 F: 603.676.0162
www.erigo.com http://exchweb/bin/redir.asp?URL=http://www.erigo.com
Notice: This email (including attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. ยงยง 2510-2521, is confidential and may be legally privileged. If you are not the intended recipient, you are hereby notified that any retention dissemination, distribution, or copying of this communication is strictly prohibited. Please reply to the sender that you have received the message in error, and then delete it. Thank you.
a. Changed the console definitions to be: #define CONFIG_CONS_INDEX 2 #define CONFIG_SYS_NS16550_COM2 OMAP34XX_UART2 #define CONFIG_SERIAL2 2 b. Changed the console line in CONFIG_EXTRA_ENV_SETTINGS to be: "console=ttyS1,115200n8\0"
Texas Instruments X-Loader 1.4.3 (Feb 16 2010 - 10:36:47) Reading boot sector Loading u-boot.bin from mmc
Any insight on how to redirect the console output is very much appreciated. Any pointers from anyone who has changed the console output?
John
John Wilson
