[PATCH] board/include: ti/env: j721e.env/ti_common: Fix cpsw0_qsgmii_phyinit
The command "main_cpsw0_qsgmii_phyinit" has to be run depending on whether or not the "do_main_cpsw0_qsgmii_phyinit" variable is set. However, there is no support for the cases where the environment variable "do_main_cpsw0_qsgmii_phyinit" is updated at runtime. On J721E, the value of "do_main_cpsw0_qsgmii_phyinit" is updated at runtime.
Fix the existing implementation in order to handle the case where the value of "do_main_cpsw0_qsgmii_phyinit" is updated at runtime. Do so by introducing the environment variable "update_do_main_cpsw0_qsgmii_phyinit" which defaults to setting "do_main_cpsw0_qsgmii_phyinit" to zero, but at the same time, it allows the board to update the value at runtime.
Fixes: 0d72b0f2f83b ("include: env: ti: ti_common: Run main_cpsw0_qsgmii_phyinit conditionally") Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com ---
Hello,
This patch is based on commit 899b088674 Merge patch series "pxe: Add debugging for booting" of U-Boot's next branch.
Regards, Siddharth.
board/ti/j721e/j721e.env | 9 +++++---- include/env/ti/ti_common.env | 3 ++- 2 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/board/ti/j721e/j721e.env b/board/ti/j721e/j721e.env index 38bfd7d496..03d7e81aa8 100644 --- a/board/ti/j721e/j721e.env +++ b/board/ti/j721e/j721e.env @@ -29,7 +29,7 @@ bootdir=/boot rd_spec=-
#if CONFIG_TARGET_J7200_A72_EVM -do_main_cpsw0_qsgmii_phyinit=1 +update_do_main_cpsw0_qsgmii_phyinit=setenv do_main_cpsw0_qsgmii_phyinit 1; init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17; gpio clear gpio@22_16 main_cpsw0_qsgmii_phyinit= @@ -39,10 +39,11 @@ main_cpsw0_qsgmii_phyinit= #elif CONFIG_TARGET_J721E_A72_EVM init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17; gpio clear gpio@22_16 -main_cpsw0_qsgmii_phyinit= +update_do_main_cpsw0_qsgmii_phyinit= if test $board_name = J721EX-PM1-SOM || test $board_name = J721EX-PM2-SOM || test $board_name = j721e; then - do_main_cpsw0_qsgmii_phyinit=1; else - do_main_cpsw0_qsgmii_phyinit=0; fi; + setenv do_main_cpsw0_qsgmii_phyinit 1; else + setenv do_main_cpsw0_qsgmii_phyinit 0; fi; +main_cpsw0_qsgmii_phyinit= if test ${do_main_cpsw0_qsgmii_phyinit} -eq 1 && test ${dorprocboot} -eq 1 && test ${boot} = mmc; then run init_main_cpsw0_qsgmii_phy; \ fi; diff --git a/include/env/ti/ti_common.env b/include/env/ti/ti_common.env index c5c3642177..d0b3d698a0 100644 --- a/include/env/ti/ti_common.env +++ b/include/env/ti/ti_common.env @@ -23,9 +23,10 @@ get_fit_overlaystring= done; get_fit_config=setexpr name_fit_config gsub / _ conf-${fdtfile} run_fit=run get_fit_config; bootm ${addr_fit}#${name_fit_config}${overlaystring} -do_main_cpsw0_qsgmii_phyinit=0 +update_do_main_cpsw0_qsgmii_phyinit=setenv do_main_cpsw0_qsgmii_phyinit 0; bootcmd_ti_mmc= run findfdt; run init_${boot}; + run update_do_main_cpsw0_qsgmii_phyinit; #if CONFIG_CMD_REMOTEPROC if test ${do_main_cpsw0_qsgmii_phyinit} -eq 1; then run main_cpsw0_qsgmii_phyinit;
Why cant we do this entirely in board files? we do the board detection there anyways..
Hello,
Regards, Siddharth.
- run update_do_main_cpsw0_qsgmii_phyinit;
#if CONFIG_CMD_REMOTEPROC if test ${do_main_cpsw0_qsgmii_phyinit} -eq 1; then run main_cpsw0_qsgmii_phyinit; -- 2.40.1
Nishanth Menon
Siddharth Vadapalli
