[U-Boot] [PATCH] TQM8260: environment in flash instead EEPROM, baudrate 115k
Several customers have reported problems with the environment in EEPROM, including corrupted content after board reset. Probably the code to prevent I2C Enge Conditions is not working sufficiently.
We move the environment to flash now, which allows to have a backup copy plus gives much faster boot times.
Also, change the default console initialization to 115200 bps as used on most other boards.
Signed-off-by: Wolfgang Denk wd@denx.de --- board/tqc/tqm8260/flash.c | 13 +++++++++++-- include/configs/TQM8260.h | 30 ++++++++++-------------------- 2 files changed, 21 insertions(+), 22 deletions(-)
diff --git a/board/tqc/tqm8260/flash.c b/board/tqc/tqm8260/flash.c index 4a6d538..cabc818 100644 --- a/board/tqc/tqm8260/flash.c +++ b/board/tqc/tqm8260/flash.c @@ -204,7 +204,8 @@ unsigned long flash_init (void) #if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH0_BASE flash_protect (FLAG_PROTECT_SET, CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, &flash_info[0]); + CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, + &flash_info[0]); #endif
#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) @@ -213,7 +214,15 @@ unsigned long flash_init (void) # endif flash_protect (FLAG_PROTECT_SET, CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); + CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, + &flash_info[0]); +#endif + +#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR_REDUND) + flash_protect (FLAG_PROTECT_SET, + CONFIG_ENV_ADDR_REDUND, + CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SIZE_REDUND - 1, + &flash_info[0]); #endif
return (size_b0); diff --git a/include/configs/TQM8260.h b/include/configs/TQM8260.h index 54f4b31..533c7ad 100644 --- a/include/configs/TQM8260.h +++ b/include/configs/TQM8260.h @@ -60,11 +60,7 @@
#define CONFIG_BOOTCOUNT_LIMIT
-#if defined(CONFIG_CONS_NONE) || defined(CONFIG_CONS_USE_EXTC) -#define CONFIG_BAUDRATE 230400 -#else -#define CONFIG_BAUDRATE 9600 -#endif +#define CONFIG_BAUDRATE 115200
#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo"
@@ -83,10 +79,10 @@ "flash_self=run ramargs addip;" \ "bootm ${kernel_addr} ${ramdisk_addr}\0" \ "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_82xx\0" \ - "bootfile=/tftpboot/TQM8260/uImage\0" \ - "kernel_addr=40040000\0" \ - "ramdisk_addr=40100000\0" \ + "rootpath=/opt/eldk/ppc_6xx\0" \ + "bootfile=tqm8260/uImage\0" \ + "kernel_addr=40080000\0" \ + "ramdisk_addr=40200000\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
@@ -304,18 +300,12 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */
-#if 0 -/* Start port with environment in flash; switch to EEPROM later */ #define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+0x40000) -#define CONFIG_ENV_SIZE 0x40000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) +#define CONFIG_ENV_SIZE 0x08000 #define CONFIG_ENV_SECT_SIZE 0x40000 -#else -/* Final version: environment in EEPROM */ -#define CONFIG_ENV_IS_IN_EEPROM 1 -#define CONFIG_ENV_OFFSET 0 -#define CONFIG_ENV_SIZE 2048 -#endif +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
/*----------------------------------------------------------------------- * Hardware Information Block @@ -380,7 +370,7 @@ #define CONFIG_SYS_FLASH_BASE CONFIG_SYS_FLASH0_BASE #define CONFIG_SYS_MONITOR_BASE TEXT_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc()*/ +#define CONFIG_SYS_MALLOC_LEN (512 << 10) /* Reserve 512 kB for malloc()*/
/* * Internal Definitions
Dear Wolfgang Denk,
Applied.
