[U-Boot] [PATCH v3] socfpga/dwmmc: Adding DesignWare MMC driver support for SOCFPGA
To add the DesignWare MMC driver support for Altera SOCFPGA. It required information such as clocks and bus width from platform specific files (SOCFPGA handoff files)
Signed-off-by: Chin Liang See clsee@altera.com Cc: Rajeshwari Shinde rajeshwari.s@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Wolfgang Denk wd@denx.de --- Changes for v3 - Used structure instead macro for the register access - Made drvsel and smpsel configurable - Used better macro names - Added a documentation on macro used to enable the driver Changes for v2 - Adding u-boot-mmc maintainer --- arch/arm/include/asm/arch-socfpga/dwmmc.h | 12 ++++ arch/arm/include/asm/arch-socfpga/system_manager.h | 65 +++++++++++++++++++ doc/README.socfpga | 53 +++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/socfpga_dw_mmc.c | 68 ++++++++++++++++++++ 5 files changed, 199 insertions(+) create mode 100644 arch/arm/include/asm/arch-socfpga/dwmmc.h create mode 100644 doc/README.socfpga create mode 100644 drivers/mmc/socfpga_dw_mmc.c
diff --git a/arch/arm/include/asm/arch-socfpga/dwmmc.h b/arch/arm/include/asm/arch-socfpga/dwmmc.h new file mode 100644 index 0000000..945eb64 --- /dev/null +++ b/arch/arm/include/asm/arch-socfpga/dwmmc.h @@ -0,0 +1,12 @@ +/* + * (C) Copyright 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SOCFPGA_DWMMC_H_ +#define _SOCFPGA_DWMMC_H_ + +extern int socfpga_dwmmc_init(u32 regbase, int bus_width, int index); + +#endif /* _SOCFPGA_SDMMC_H_ */ diff --git a/arch/arm/include/asm/arch-socfpga/system_manager.h b/arch/arm/include/asm/arch-socfpga/system_manager.h index d965d25..838d210 100644 --- a/arch/arm/include/asm/arch-socfpga/system_manager.h +++ b/arch/arm/include/asm/arch-socfpga/system_manager.h @@ -19,4 +19,69 @@ extern unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM];
#define CONFIG_SYSMGR_PINMUXGRP_OFFSET (0x400)
+#define SYSMGR_SDMMC_CTRL_SET(smplsel, drvsel) \ + ((((drvsel) << 0) & 0x7) | (((smplsel) << 3) & 0x38)) + +struct socfpga_system_manager { + u32 siliconid1; + u32 siliconid2; + u32 _pad_0x8_0xf[2]; + u32 wddbg; + u32 bootinfo; + u32 hpsinfo; + u32 parityinj; + u32 fpgaintfgrp_gbl; + u32 fpgaintfgrp_indiv; + u32 fpgaintfgrp_module; + u32 _pad_0x2c_0x2f; + u32 scanmgrgrp_ctrl; + u32 _pad_0x34_0x3f[3]; + u32 frzctrl_vioctrl; + u32 _pad_0x44_0x4f[3]; + u32 frzctrl_hioctrl; + u32 frzctrl_src; + u32 frzctrl_hwctrl; + u32 _pad_0x5c_0x5f; + u32 emacgrp_ctrl; + u32 emacgrp_l3master; + u32 _pad_0x68_0x6f[2]; + u32 dmagrp_ctrl; + u32 dmagrp_persecurity; + u32 _pad_0x78_0x7f[2]; + u32 iswgrp_handoff[8]; + u32 _pad_0xa0_0xbf[8]; + u32 romcodegrp_ctrl; + u32 romcodegrp_cpu1startaddr; + u32 romcodegrp_initswstate; + u32 romcodegrp_initswlastld; + u32 romcodegrp_bootromswstate; + u32 __pad_0xd4_0xdf[3]; + u32 romcodegrp_warmramgrp_enable; + u32 romcodegrp_warmramgrp_datastart; + u32 romcodegrp_warmramgrp_length; + u32 romcodegrp_warmramgrp_execution; + u32 romcodegrp_warmramgrp_crc; + u32 __pad_0xf4_0xff[3]; + u32 romhwgrp_ctrl; + u32 _pad_0x104_0x107; + u32 sdmmcgrp_ctrl; + u32 sdmmcgrp_l3master; + u32 nandgrp_bootstrap; + u32 nandgrp_l3master; + u32 usbgrp_l3master; + u32 _pad_0x11c_0x13f[9]; + u32 eccgrp_l2; + u32 eccgrp_ocram; + u32 eccgrp_usb0; + u32 eccgrp_usb1; + u32 eccgrp_emac0; + u32 eccgrp_emac1; + u32 eccgrp_dma; + u32 eccgrp_can0; + u32 eccgrp_can1; + u32 eccgrp_nand; + u32 eccgrp_qspi; + u32 eccgrp_sdmmc; +}; + #endif /* _SYSTEM_MANAGER_H_ */ diff --git a/doc/README.socfpga b/doc/README.socfpga new file mode 100644 index 0000000..cfcbbfe --- /dev/null +++ b/doc/README.socfpga @@ -0,0 +1,53 @@ + +-------------------------------------------- +SOCFPGA Documentation for U-Boot and SPL +-------------------------------------------- + +This README is about U-Boot and SPL support for Altera's ARM Cortex-A9MPCore +based SOCFPGA. To know more about the hardware itself, please refer to +www.altera.com. + + +-------------------------------------------- +socfpga_dw_mmc +-------------------------------------------- +Here are macro and detailed configuration required to enable DesignWare SDMMC +controller support within SOCFPGA + +#define CONFIG_MMC +-> To enable the SD MMC framework support + +#define CONFIG_SDMMC_BASE (SOCFPGA_SDMMC_ADDRESS) +-> The base address of CSR register for DesignWare SDMMC controller + +#define CONFIG_GENERIC_MMC +-> Enable the generic MMC driver + +#define CONFIG_SYS_MMC_MAX_BLK_COUNT 256 +-> Using smaller max blk cnt to avoid flooding the limited stack in OCRAM + +#define CONFIG_DWMMC +-> Enable the common DesignWare SDMMC controller framework + +#define CONFIG_SOCFPGA_DWMMC +-> Enable the SOCFPGA specific driver for DesignWare SDMMC controller + +#define CONFIG_SOCFPGA_DWMMC_FIFO_DEPTH 1024 +-> The FIFO depth for SOCFPGA DesignWare SDMMC controller + +#define CONFIG_SOCFPGA_DWMMC_DRVSEL 3 +-> Phase-shifted clock of sdmmc_clk for controller to drive command and data to +the card to meet hold time requirements. SD clock is running at 50MHz and +drvsel is set to shift 135 degrees (3 * 45 degrees). With that, the hold time +is 135 / 360 * 20ns = 7.5ns. + +#define CONFIG_SOCFPGA_DWMMC_SMPSEL 0 +-> Phase-shifted clock of sdmmc_clk used to sample the command and data from +the card + +#define CONFIG_SOCFPGA_DWMMC_BUS_WIDTH 4 +-> Bus width of data line which either 1, 4 or 8 and based on board routing. + +#define CONFIG_SOCFPGA_DWMMC_BUS_HZ 50000000 +-> The clock rate to controller. Do note the controller have a wrapper which +divide the clock from PLL by 4. diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 1ed26ca..e793ed9 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -28,6 +28,7 @@ obj-$(CONFIG_TEGRA_MMC) += tegra_mmc.o obj-$(CONFIG_DWMMC) += dw_mmc.o obj-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o +obj-$(CONFIG_SOCFPGA_DWMMC) += socfpga_dw_mmc.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o else diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c new file mode 100644 index 0000000..bc53a5d --- /dev/null +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -0,0 +1,68 @@ +/* + * (C) Copyright 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <dwmmc.h> +#include <asm/arch/dwmmc.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/system_manager.h> + +static const struct socfpga_clock_manager *clock_manager_base = + (void *)SOCFPGA_CLKMGR_ADDRESS; +static const struct socfpga_system_manager *system_manager_base = + (void *)SOCFPGA_SYSMGR_ADDRESS; + +static char *SOCFPGA_NAME = "SOCFPGA DWMMC"; + +static void socfpga_dwmci_clksel(struct dwmci_host *host) +{ + unsigned int drvsel; + unsigned int smplsel; + + /* Disable SDMMC clock. */ + clrbits_le32(&clock_manager_base->per_pll_en, + CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK); + + /* Configures drv_sel and smpl_sel */ + drvsel = CONFIG_SOCFPGA_DWMMC_DRVSEL; + smplsel = CONFIG_SOCFPGA_DWMMC_SMPSEL; + + debug("%s: drvsel %d smplsel %d\n", __func__, drvsel, smplsel); + writel(SYSMGR_SDMMC_CTRL_SET(smplsel, drvsel), + &system_manager_base->sdmmcgrp_ctrl); + + debug("%s: SYSMGR_SDMMCGRP_CTRL_REG = 0x%x\n", __func__, + readl(&system_manager_base->sdmmcgrp_ctrl)); + + /* Enable SDMMC clock */ + setbits_le32(&clock_manager_base->per_pll_en, + CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK); +} + +int socfpga_dwmmc_init(u32 regbase, int bus_width, int index) +{ + struct dwmci_host *host = NULL; + host = calloc(sizeof(struct dwmci_host), 1); + if (!host) { + printf("dwmci_host calloc fail!\n"); + return -1; + } + + host->name = SOCFPGA_NAME; + host->ioaddr = (void *)regbase; + host->buswidth = bus_width; + host->clksel = socfpga_dwmci_clksel; + host->dev_index = index; + /* fixed clock divide by 4 which due to the SDMMC wrapper */ + host->bus_hz = CONFIG_SOCFPGA_DWMMC_BUS_HZ; + host->fifoth_val = MSIZE(0x2) | + RX_WMARK(CONFIG_SOCFPGA_DWMMC_FIFO_DEPTH / 2 - 1) | + TX_WMARK(CONFIG_SOCFPGA_DWMMC_FIFO_DEPTH / 2); + + return add_dwmci(host, host->bus_hz, 400000); +} +
Hi Chin,
Changes for v3
Changes for v2
- (C) Copyright 2013 Altera Corporation <www.altera.com>
- ((((drvsel) << 0) & 0x7) | (((smplsel) << 3) & 0x38))
- u32 siliconid1;
- u32 siliconid2;
- u32 _pad_0x8_0xf[2];
- u32 wddbg;
- u32 bootinfo;
- u32 hpsinfo;
- u32 parityinj;
- u32 fpgaintfgrp_gbl;
- u32 fpgaintfgrp_indiv;
- u32 fpgaintfgrp_module;
- u32 _pad_0x2c_0x2f;
- u32 scanmgrgrp_ctrl;
- u32 _pad_0x34_0x3f[3];
- u32 frzctrl_vioctrl;
- u32 _pad_0x44_0x4f[3];
- u32 frzctrl_hioctrl;
- u32 frzctrl_src;
- u32 frzctrl_hwctrl;
- u32 _pad_0x5c_0x5f;
- u32 emacgrp_ctrl;
- u32 emacgrp_l3master;
- u32 _pad_0x68_0x6f[2];
- u32 dmagrp_ctrl;
- u32 dmagrp_persecurity;
- u32 _pad_0x78_0x7f[2];
- u32 iswgrp_handoff[8];
- u32 _pad_0xa0_0xbf[8];
- u32 romcodegrp_ctrl;
- u32 romcodegrp_cpu1startaddr;
- u32 romcodegrp_initswstate;
- u32 romcodegrp_initswlastld;
- u32 romcodegrp_bootromswstate;
- u32 __pad_0xd4_0xdf[3];
- u32 romcodegrp_warmramgrp_enable;
- u32 romcodegrp_warmramgrp_datastart;
- u32 romcodegrp_warmramgrp_length;
- u32 romcodegrp_warmramgrp_execution;
- u32 romcodegrp_warmramgrp_crc;
- u32 __pad_0xf4_0xff[3];
- u32 romhwgrp_ctrl;
- u32 _pad_0x104_0x107;
- u32 sdmmcgrp_ctrl;
- u32 sdmmcgrp_l3master;
- u32 nandgrp_bootstrap;
- u32 nandgrp_l3master;
- u32 usbgrp_l3master;
- u32 _pad_0x11c_0x13f[9];
- u32 eccgrp_l2;
- u32 eccgrp_ocram;
- u32 eccgrp_usb0;
- u32 eccgrp_usb1;
- u32 eccgrp_emac0;
- u32 eccgrp_emac1;
- u32 eccgrp_dma;
- u32 eccgrp_can0;
- u32 eccgrp_can1;
- u32 eccgrp_nand;
- u32 eccgrp_qspi;
- u32 eccgrp_sdmmc;
- unsigned int drvsel;
- unsigned int smplsel;
- /* Disable SDMMC clock. */
- clrbits_le32(&clock_manager_base->per_pll_en,
- /* Configures drv_sel and smpl_sel */
- drvsel = CONFIG_SOCFPGA_DWMMC_DRVSEL;
- smplsel = CONFIG_SOCFPGA_DWMMC_SMPSEL;
- debug("%s: drvsel %d smplsel %d\n", __func__, drvsel, smplsel);
- writel(SYSMGR_SDMMC_CTRL_SET(smplsel, drvsel),
- debug("%s: SYSMGR_SDMMCGRP_CTRL_REG = 0x%x\n", __func__,
- /* Enable SDMMC clock */
- setbits_le32(&clock_manager_base->per_pll_en,
- struct dwmci_host *host = NULL;
- host = calloc(sizeof(struct dwmci_host), 1);
- if (!host) {
return -1;
- host->name = SOCFPGA_NAME;
- host->ioaddr = (void *)regbase;
- host->buswidth = bus_width;
- host->clksel = socfpga_dwmci_clksel;
- host->dev_index = index;
- /* fixed clock divide by 4 which due to the SDMMC wrapper */
- host->bus_hz = CONFIG_SOCFPGA_DWMMC_BUS_HZ;
- host->fifoth_val = MSIZE(0x2) |
- return add_dwmci(host, host->bus_hz, 400000);
-- 1.7.9.5
Applied, thanks
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Chin Liang See
Pantelis Antoniou
