[PATCH v2 1/3] dt-bindings: mtd: fixed-partitions: Add binman compatible
Add a compatible string for binman, so we can extend fixed-partitions in various ways.
Changes in v2: - Drop mention of 'enhanced features' in fixed-partitions.yaml - Mention Binman input and output properties - Use plain partition@xxx for the node name
.../bindings/mtd/partitions/binman.yaml | 61 +++++++++++++++++++ .../mtd/partitions/fixed-partitions.yaml | 3 + .../bindings/mtd/partitions/partitions.yaml | 1 + MAINTAINERS | 5 ++ 4 files changed, 70 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml new file mode 100644 index 000000000000..844f241feebf --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml @@ -0,0 +1,61 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +# Copyright 2023 Google LLC + +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Binman firmware layout + +maintainers: + - Simon Glass sjg@chromium.org + +select: false + +description: | + The binman node provides a layout for firmware, used when packaging firmware + from multiple projects. It is based on fixed-partitions, with some + extensions. + + Binman supports properties used as inputs to the firmware-packaging process, + such as those which control alignment of partitions. This binding addresses + these 'input' properties. For example, it is common for the 'reg' property + (an 'output' property) to be set by Binman, based on the alignment requested + in the input. + + Once processing is complete, input properties have mostly served their + purpose, at least until the firmware is repacked later, e.g. due to a + firmware update. The base 'fixed-partitions' binding should provide enough + information to read the firmware at runtime, including decompression if + needed. + + Documentation for Binman is available at: + + https://u-boot.readthedocs.io/en/latest/develop/package/binman.html + + with the current image-description format at: + + https://u-boot.readthedocs.io/en/latest/develop/package/binman.html#image-de... + +allOf: + - $ref: /schemas/mtd/partitions/fixed-partitions.yaml# + +properties: + compatible: + const: binman + +additionalProperties: false + +examples: + - | + partitions { + compatible = "binman", "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@100000 { + label = "u-boot"; + reg = <0x100000 0xf00000>; + }; + }; diff --git a/Documentation/devicetree/bindings/mtd/partitions/fixed-partitions.yaml b/Documentation/devicetree/bindings/mtd/partitions/fixed-partitions.yaml index 331e564f29dc..85aef1572967 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/fixed-partitions.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/fixed-partitions.yaml @@ -24,6 +24,9 @@ properties: - items: - const: sercomm,sc-partitions - const: fixed-partitions + - items: + - const: binman + - const: fixed-partitions
"#address-cells": true
diff --git a/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml b/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml index 1dda2c80747b..849fd15d085c 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml @@ -15,6 +15,7 @@ maintainers:
oneOf: - $ref: arm,arm-firmware-suite.yaml + - $ref: binman.yaml - $ref: brcm,bcm4908-partitions.yaml - $ref: brcm,bcm947xx-cfe-partitions.yaml - $ref: fixed-partitions.yaml diff --git a/MAINTAINERS b/MAINTAINERS index 5f18c6ba3c3c..367c843ec348 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -3517,6 +3517,11 @@ F: Documentation/filesystems/bfs.rst F: fs/bfs/ F: include/uapi/linux/bfs_fs.h
+BINMAN +M: Simon Glass sjg@chromium.org +S: Supported +F: Documentation/devicetree/bindings/mtd/partitions/binman* + BITMAP API M: Yury Norov yury.norov@gmail.com R: Andy Shevchenko andriy.shevchenko@linux.intel.com
Add two labels for binman entries, as a starting point for the schema.
Changes in v2: - Use plain partition@xxx for the node name
.../mtd/partitions/binman-partition.yaml | 48 +++++++++++++++++++ 1 file changed, 48 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml new file mode 100644 index 000000000000..406a8997d3e4 --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml @@ -0,0 +1,48 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +# Copyright 2023 Google LLC + +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/binman-partition.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Binman partition + +maintainers: + - Simon Glass sjg@chromium.org + +select: false + +description: | + This corresponds to a binman 'entry'. It is a single partition which holds + data of a defined type. + +allOf: + - $ref: /schemas/mtd/partitions/partition.yaml# + +properties: + label: + items: + enum: + - u-boot # u-boot.bin from U-Boot projec6t + - atf-bl31 # bl31.bin or bl31.elf from TF-A project + +additionalProperties: false + +examples: + - | + partitions { + compatible = "binman", "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@100000 { + label = "u-boot"; + reg = <0x100000 0xf00000>; + }; + + partition@200000 { + label = "atf-bl31"; + reg = <0x200000 0x100000>; + }; + };
Add three properties for controlling alignment of partitions, aka 'entries' in binman.
For now there is no explicit mention of hierarchy, so a 'section' is just the 'fixed-partitions' node.
These new properties are inputs to the packaging process, but are also needed if the firmware is repacked, to ensure that alignment constraints are not violated. Therefore they are provided as part of the schema.
Changes in v2: - Fix 'a' typo in commit message
.../mtd/partitions/binman-partition.yaml | 39 +++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml index 406a8997d3e4..be7273a4c9ac 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml @@ -27,6 +27,42 @@ properties: - u-boot # u-boot.bin from U-Boot projec6t - atf-bl31 # bl31.bin or bl31.elf from TF-A project
+ align: + $ref: /schemas/types.yaml#/definitions/uint32 + description: + This sets the alignment of the entry. The entry offset is adjusted + so that the entry starts on an aligned boundary within the containing + section or image. For example ‘align = <16>’ means that the entry will + start on a 16-byte boundary. This may mean that padding is added before + the entry. The padding is part of the containing section but is not + included in the entry, meaning that an empty space may be created before + the entry starts. Alignment should be a power of 2. If ‘align’ is not + provided, no alignment is performed. + + align-size: + $ref: /schemas/types.yaml#/definitions/uint32 + description: + This sets the alignment of the entry size. For example, to ensure + that the size of an entry is a multiple of 64 bytes, set this to 64. + While this does not affect the contents of the entry within binman + itself (the padding is performed only when its parent section is + assembled), the end result is that the entry ends with the padding + bytes, so may grow. If ‘align-size’ is not provided, no alignment is + performed. + + align-end: + $ref: /schemas/types.yaml#/definitions/uint32 + description: + This sets the alignment of the end of an entry with respect to the + containing section. Some entries require that they end on an alignment + boundary, regardless of where they start. This does not move the start + of the entry, so the contents of the entry will still start at the + beginning. But there may be padding at the end. While this does not + affect the contents of the entry within binman itself (the padding is + performed only when its parent section is assembled), the end result is + that the entry ends with the padding bytes, so may grow. If ‘align-end’ + is not provided, no alignment is performed. + additionalProperties: false
examples: @@ -39,10 +75,13 @@ examples: partition@100000 { label = "u-boot"; reg = <0x100000 0xf00000>; + align-size = <0x1000>; + align-end = <0x10000>; };
partition@200000 { label = "atf-bl31"; reg = <0x200000 0x100000>; + align = <0x4000>; }; };
Hi Simon,
sjg@chromium.org wrote on Mon, 2 Oct 2023 11:49:40 -0600:
I've been thinking at the proper way to describe the binman partitions. I am wondering if we should really extend the fixed-partitions schema. This description is really basic and kind of supposed to remain like that. Instead, I wonder if we should not just keep the binman compatible alone, like many others already. This way it would be very clear what is expected and allowed in both cases. I am thinking about something like that:
Documentation/devicetree/bindings/mtd/partitions/brcm,bcm4908-partitions.yaml
this file is also referenced there (but this patch does the same, which is what I'd expect):
I'll let the binding maintainers judge whether they think it's relevant, it's not a strong opposition.
+properties:
- compatible:
- const: binman
Right now this does not fit (I believe) the example. But if we no longer extend fixed-partitions but just create binman.yaml, this will probably be enough.
+examples:
- partitions {
#size-cells = <1>;
partition@100000 {
label = "u-boot";
Thanks, Miquèl
What is the overall goal here? To replace the current binman node which is usually contained in the -u-boot.dtsi files? If one is using binman to create an image, is it expected that one needs to adapt the DT in linux? Or will it still be a seperate -u-boot.dtsi? Because in the latter case I see that there will be conflicts because you have to overwrite the flash node. Or will it be a seperate node with all the information duplicated?
Maybe (a more complete) example would be helpful.
-michael
Hi Michael,
What is the overall goal here? To replace the current binman node which is usually contained in the -u-boot.dtsi files? If one is using binman to create an image, is it expected that one needs to adapt the DT in linux? Or will it still be a seperate -u-boot.dtsi? > Because in the latter case I see that there will be conflicts because you have to overwrite the flash node. Or will it be a seperate node with all the information duplicated?
The goal is simply to have a full binding for firmware layout, such that firmware images can be created, examined and updated. The -u-boot.dtsi files are a stopgap while we sort out a real binding. They should eventually go away.
Can you please be a bit more specific? What is missing from the example?
You haven't answered whether this node should be a seperate binman node - or if you'll reuse the existing flash (partitions) node(s) and add any missing property there. If it's the latter, I don't think compatible = "binman", "fixed-partitions"; is correct.
Like a complete (stripped) DTS. Right now I just see how the individual node looks like. But with a complete example DTS, my question from above would have been answered.
What if a board uses eMMC to store the firmware binaries? Will that then be a subnode to the eMMC device?
-michael
Hi Michael,
My intent is to make it compatible, so wouldn't it make sense to have binman as the first compatible, then falling back to fixed-partitions as the second?
I thought there was a way to link the partition nodes and the device using a property, without having the partition info as a subnode of the device. But I may have imagined it as I cannot find it now. So yes, it will be a subnode of the eMMC device.
As far as I know, the compatibles should get more specific with each string. But "binman" seems to be used as a kind of tag which could be added to any compatible under the flash node. What if one wants to build an image which isn't compatible = "fixed-partitions"? E.g. "linksys,ns-partitions", will it then have compatible = "binman", "linksys,ns-partitions"?
So to give an example myself, please correct it if it's wrong. From our board (kontron-sl28):
&fspi { status = "okay";
flash@0 { compatible = "jedec,spi-nor"; m25p,fast-read; spi-max-frequency = <133000000>; reg = <0>; /* The following setting enables 1-1-2 (CMD-ADDR-DATA) mode */ spi-rx-bus-width = <2>; /* 2 SPI Rx lines */ spi-tx-bus-width = <1>; /* 1 SPI Tx line */
partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>;
partition@0 { reg = <0x000000 0x010000>; label = "rcw"; read-only; };
partition@10000 { reg = <0x010000 0x1d0000>; label = "failsafe bootloader"; read-only; };
partition@200000 { reg = <0x200000 0x010000>; label = "configuration store"; };
partition@210000 { reg = <0x210000 0x1d0000>; label = "bootloader"; };
partition@3e0000 { reg = <0x3e0000 0x020000>; label = "bootloader environment"; }; }; }; };
In u-boot we use binman, see arch/arm/dts/fsl-ls1028a-kontron-sl28-u-boot.dtsi in the u-boot repository.
Now to use the new method, am I expected to adapt the dts in the linux kernel? As far as I understand that is the case. So that node from above would look something like the following:
partitions { compatible = "binman", "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; [..] partition@210000 { reg = <0x210000 0x1d0000>; label = "u-boot"; /* or "u-boot+atf" ? */ };
I'm still not sure why that compatible is needed. Also I'd need to change the label which might break user space apps looking for that specific name.
Also, our board might have u-boot/spl or u-boot/spl/bl31/bl32, right now that's something which depends on an u-boot configuration variable, which then enables or disables binman nodes in the -u-boot.dtsi. So in linux we only have that "bootloader" partition, but there might be either u-boot+spl or u-boot+spl+bl31+bl32.
Honestly, I'm really not sure this should go into a device tree.
Not sure if that will fly.
-michael
Hi Michael,
On Thu, 5 Oct 2023 at 02:54, Michael Walle mwalle@kernel.org wrote:
> Add a compatible string for binman, so we can extend fixed-partitions > in various ways.
That's the opposite to what I understood.
I suppose so.
partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; partition@0 { reg = <0x000000 0x010000>; label = "rcw"; read-only; }; partition@10000 { reg = <0x010000 0x1d0000>; label = "failsafe bootloader"; read-only; }; partition@200000 { reg = <0x200000 0x010000>; label = "configuration store"; }; partition@210000 { reg = <0x210000 0x1d0000>; label = "bootloader"; }; partition@3e0000 { reg = <0x3e0000 0x020000>; label = "bootloader environment"; }; }; };
I think we might be getting a bit ahead of ourselves here. I thought that the decision was that the label should indicate the contents. If you have multiple things in a partition then it would become a 'section' in Binman's terminology. Either the label programmatically describes what is inside or it doesn't. We can't have it both ways. What do you suggest?
At present it seems you have the image described in two places - one is the binman node and the other is the partitions node. I would like to unify these.
What does user space do with the partition labels?
I can't find it anyway. There is somelike like that in simple-framebuffer with the 'display' property.
Regards, SImon
Hi Michael,
On Thu, 5 Oct 2023 at 07:28, Simon Glass sjg@chromium.org wrote:
Hi Michael,
>> Add a compatible string for binman, so we can extend fixed-partitions >> in various ways. > > I've been thinking at the proper way to describe the binman partitions. > I am wondering if we should really extend the fixed-partitions > schema. This description is really basic and kind of supposed to remain > like that. Instead, I wonder if we should not just keep the binman > compatible alone, like many others already. This way it would be very clear > what is expected and allowed in both cases. I am thinking about > something like that: > > Documentation/devicetree/bindings/mtd/partitions/brcm,bcm4908-partitions.yaml > > this file is also referenced there (but this patch does the same, which > is what I'd expect): > > Documentation/devicetree/bindings/mtd/partitions/partitions.yaml > > I'll let the binding maintainers judge whether they think it's > relevant, it's not a strong opposition.
I suppose so.
I should also mention that I originally proposed a binman in the /firmware node, but Rob indicated that the /firmware node is not for that sort of purpose.
As Rob pointed out earlier, it's just a user-facing string. I'm a bit reluctant to use it programatically. Taking my example again, the string "bootloader" is sufficient for a user. He doesn't care if it's u-boot with spl or u-boot with tfa, or even coreboot. It just says, "in this partition is the bootloader". If you have an "bootloader" image you can flash it there.
If it has a label "u-boot" and I want to switch to coreboot, will it have to change to "coreboot"? I really don't think this is practical, you are really putting software configuration into the device tree.
And I'm not sure that will work for all the corner cases :/
If you keep the binman section seperate from the flash partition definition you don't have any of these problems, although there is some redundancy: - you only have compatible = "binman", "fixed-partition", no further compatibles are required - you don't have any conflicts with the current partition descriptions - you could even use the labels, because binman is the (only?) user
But of course you need to find a place where to put your node.
I'm not sure. Also I'm not sure if it really matters, I just wanted to point out, that you'll force users to change it.
-michael
Regards, SImon
Hi Michael,
I thought Rob changed his mind on that?
I agree that compatible would make things easier. We could then continue to use 'label' for whatever it currently has.
Note that some kernel drivers or user space will want to look at what is there, e.g. to provide a way to extract, check or update a particular part of the firmware.
Sure, but I was pointed to partitions as the place where this should live.
OK I'll send a version that uses compatible strings and see if that makes any progress.
-michael
Regards, SImon
In general, yes, but the partition stuff has long (and still) uses label. As long as the values the tools understand are documented (which we don't normally do for label), I don't care so much. That's my opinion as long as this is shared with fixed-partitions. If it is not and there's little reason to use label, then absolutely, I think 'compatible' makes more sense.
These days, there's generally not just 1 bootloader in the boot flow. Maybe there's 1 image, maybe not. Being more specific is hardly ever a bad thing. Only when the number of specific things becomes multiple 10s or 100s of them does it become a problem.
On the input side (to binman), yes it is config, but on the output side (to the running system) we are saying what's there.
And remove it. We don't need 2 sources of truth in the DTB.
Rob
Hi Rob,
OK I will try to drop the sharing with fixed-partitions
I would certainly prefer to have one...I think using 'label' for the existing case and 'compatible' for the new one could be a reasonable compromise, so I will send v3.
Hi Miquel,
On Wed, 4 Oct 2023 at 01:36, Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Simon,
OK, yes I can do that. I suppose they would still remain backwards compatible, due to the use of '$ref: partition.yaml#'
+properties:
- compatible:
- const: binman
OK
+examples:
- partitions {
#size-cells = <1>;
partition@100000 {
label = "u-boot";
Michael Walle
Miquel Raynal
Rob Herring
