[PATCH] rockchip: boot_mode: find the saradc device name
adc_channel_single_shot() requires the full device name e.g. "saradc@ff100000", which differs between Rockchip SoC's, but they all share the prefix "saradc"; find the ADC device with this name prefix and use its full name.
Signed-off-by: Hugh Cole-Baker sigmaris@gmail.com --- I previously sent this on Jan. 11 as an RFC patch, since there were no comments on it previously I guess it can just be submitted as a patch as-is.
arch/arm/mach-rockchip/boot_mode.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/boot_mode.c b/arch/arm/mach-rockchip/boot_mode.c index 08f80bd91a..7598fe4c43 100644 --- a/arch/arm/mach-rockchip/boot_mode.c +++ b/arch/arm/mach-rockchip/boot_mode.c @@ -7,6 +7,8 @@ #include <adc.h> #include <asm/io.h> #include <asm/arch-rockchip/boot_mode.h> +#include <dm/device.h> +#include <dm/uclass.h>
#if (CONFIG_ROCKCHIP_BOOT_MODE_REG == 0)
@@ -35,8 +37,26 @@ void set_back_to_bootrom_dnl_flag(void) __weak int rockchip_dnl_key_pressed(void) { unsigned int val; + struct udevice *dev; + struct uclass *uc; + int ret;
- if (adc_channel_single_shot("saradc", 1, &val)) { + ret = uclass_get(UCLASS_ADC, &uc); + if (ret) + return false; + + ret = -ENODEV; + uclass_foreach_dev(dev, uc) { + if (!strncmp(dev->name, "saradc", 6)) { + ret = adc_channel_single_shot(dev->name, 1, &val); + break; + } + } + + if (ret == -ENODEV) { + pr_warn("%s: no saradc device found\n", __func__); + return false; + } else if (ret) { pr_err("%s: adc_channel_single_shot fail!\n", __func__); return false; }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- struct udevice *dev;
- struct uclass *uc;
- int ret;
- ret = uclass_get(UCLASS_ADC, &uc);
- if (ret)
return false;
- ret = -ENODEV;
- uclass_foreach_dev(dev, uc) {
break;
- if (ret == -ENODEV) {
return false;
- } else if (ret) { pr_err("%s: adc_channel_single_shot fail!\n", __func__); return false; }
Hugh Cole-Baker
Kever Yang
