[U-Boot] [PATCH] tools/netconsole: new script for working with netconsole over UDP
While the doc/README.NetConsole does have a snippet for people to create their own netcat script, it's a lot easier to make a simple dedicated script and tell people to use it.
Also spruce it up a bit to make it user friendly.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- doc/README.NetConsole | 18 ++++-------------- tools/netconsole | 42 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 46 insertions(+), 14 deletions(-) create mode 100755 tools/netconsole
diff --git a/doc/README.NetConsole b/doc/README.NetConsole index fea8e33..94c8816 100644 --- a/doc/README.NetConsole +++ b/doc/README.NetConsole @@ -22,21 +22,11 @@ For example, if your server IP is 192.168.1.1, you could use:
On the host side, please use this script to access the console:
-+++++++++++++++++++++++++++++++++++++++++++ -#! /bin/bash - -[ $# = 1 ] || { echo "Usage: $0 target_ip" >&2 ; exit 1 ; } -TARGET_IP=$1 + tools/netconsole <ip> [port]
-stty -icanon -echo intr ^T -nc -u -l -p 6666 < /dev/null & -nc -u ${TARGET_IP} 6666 -stty icanon echo intr ^C -+++++++++++++++++++++++++++++++++++++++++++ - -The script expects exactly one argument, which is interpreted as the -target IP address (or host name, assuming DNS is working). The script -can be interrupted by pressing ^T (CTRL-T). +The script uses netcat to talk to the board over UDP. It requires you to +specify the target IP address (or host name, assuming DNS is working). The +script can be interrupted by pressing ^T (CTRL-T).
Be aware that in some distributives (Fedora Core 5 at least) usage of nc has been changed and -l and -p options are considered diff --git a/tools/netconsole b/tools/netconsole new file mode 100755 index 0000000..09c8981 --- /dev/null +++ b/tools/netconsole @@ -0,0 +1,42 @@ +#!/bin/sh + +usage() { + ( + echo "Usage: $0 <board IP> [board port]" + echo "" + echo "If port is not specified, '6666' will be used" + [ -z "$*" ] && exit 0 + echo "" + echo "ERROR: $*" + exit 1 + ) 1>&2 + exit $? +} + +while [ -n "$1" ] ; do + case $1 in + -h|--help) usage;; + --) break;; + -*) usage "Invalid option $1";; + *) break;; + esac + shift +done + +ip=$1 +port=${2:-6666} + +if [ -z "${ip}" ] || [ -n "$3" ] ; then + usage "Invalid number of arguments" +fi + +for nc in netcat nc ; do + type ${nc} >/dev/null && break +done + +trap "stty icanon echo intr ^C" 0 2 3 5 10 13 15 +echo "NOTE: the interrupt signal (normally ^C) has been remapped to ^T" + +stty -icanon -echo intr ^T +${nc} -u -l -p ${port} < /dev/null & +exec ${nc} -u ${ip} ${port}
Dear Mike Frysinger,
Could you please restrict the line length to some 70+ characters? Thanks.
Applied, thanks.
i'm assuming you're talking about the commit message ... it's already restricted to 77 characters ... -mike
Mike Frysinger
