[U-Boot] [PATCH 1/1] doc: README.commands: sub-commands
Describe the implementation of sub-commands.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/README.commands | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/doc/README.commands b/doc/README.commands index 1d29c4d91d..05504092f7 100644 --- a/doc/README.commands +++ b/doc/README.commands @@ -28,6 +28,42 @@ comp: Pointer to the completion function. May be NULL. entering the command arguments to complete the entry. Command completion is only available if CONFIG_AUTO_COMPLETE is defined.
+Sub-command definition +---------------------- + +Likewise an array of cmd_tbl_t holding sub-commands can be created using either +of the following macros: + +* U_BOOT_CMD_MKENT(name, maxargs, repeatable, command, "usage", "help") +* U_BOOT_CMD_MKENTCOMPLETE(name, maxargs, repeatable, command, "usage, "help", + comp) + +This table has to be evaluated in the command function of the main command, e.g. + + static cmd_tbl_t cmd_sub[] = { + U_BOOT_CMD_MKENT(foo, CONFIG_SYS_MAXARGS, 1, do_foo, "", ""), + U_BOOT_CMD_MKENT(bar, CONFIG_SYS_MAXARGS, 1, do_bar, "", ""), + }; + + static int do_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) + { + cmd_tbl_t *cp; + + if (argc < 2) + return CMD_RET_USAGE; + + /* drop sub-command argument */ + argc--; + argv++; + + cp = find_cmd_tbl(argv[0], cmd_ut_sub, ARRAY_SIZE(cmd_sub)); + + if (cp) + return cp->cmd(cmdtp, flag, argc, argv); + + return CMD_RET_USAGE; + } + Command function ----------------
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org
