[U-Boot] [PATCH v7 00/11] rockchip: Add gmac Ethernet support
From Romain:
This is a resent of Simon's v4 series. I have changed what was suggested by David Wu about the driver name (rename gmac_rk3288 to gmac_rockchip). I have also tested the whole series on a rock2 square board, updated the configuration files for rock2 board. I have fixed a build failure caused by recent changes in config_distro_defaults (CMD_PXE is no longer enabled, so I enabled DISTRO_DEFAULTS for Rockchip platforms by default). I have also added few Signed-off-by tags.
From Simon:
This v3 patch is an update on Sjoerd's original v2 series from Feburary. I have dealt with the changes requested at the time, and adjusted the way that the speed change is handled.
Tested on firefly-rk3288, rock2.
Original cover letter: To add support I've taken a slightly different approach then some of the other boards with a designware IP block, by creating a new driver to take care of the platfrom glue which subclasses the main designware driver instead of adding the compatibility string the designware driver directly and doing the SoC specific setup in the board files. This seems quite a bit more elegant in a device model based world.
I've only tested this series on a Radxa Rock 2 board, it would be great if someone could test this on other boards with the designware IP especially for those with the reset GPIO in devicetree (e.g. some of the Allwinner boards).
Compared to the first one round the pinctrl related bits were dropped as RK3288 now has a full pinctrl driver. Furthermore the started hook in the designware driver was renamed to fix_mac_speed in line with what linux uses and moved to the dw_link_adjust function.
Changes in v7: - Fixed build failure caused by recent changes in config_distro_defaults.h (CMD_PXE is no longer enabled so BOOTENV_DEV_PXE is expanded to BOOT_TARGET_DEVICES_references_PXE_without_CONFIG_CMD_DHCP_or_PXE). The fix itself consists in enabling DISTRO_DEFAULTS by default for Rockchip platforms. - Added a new commit for enabling ETH address randomization on the rock2, otherwise we cannot use ethernet interface and we get an error at bootup.
Changes in v6: - Changed Acked-by to Signed-off-by for Romain in commits from [PATCH 01/09] to [PATCH 06/09]
Changes in v5: - Changed the name of the driver gmac_rk3288 to gmac_rockchip, as suggested by David Wu. Also I rewrote the commit message - Added my Acked-by to commits from [PATCH 01/09] to [PATCH 06/09] - Updated configuration files for rock2 and firefly with the new Kconfig symbol
Changes in v4: - Fix commit message to say 'rk3399'
Changes in v3: - Add a few new patches - Add comments for struct gmac_rk3288_platdata - Add new patch to adjust dw_adjust_link() to return an error - Add new patch to enable networking on evb-rk3399 - Add new patch to export the operation functions - Add new patch to split the link init into a separate function - Adjust binding to use r/tx-delay instead of r/tx_delay - Drop the 'net: designware: Add a fix_mac_speed hook' patch - Sort includes - Use debug() instead of printf() for error - Use function calls instead of fix_mac_speed() hook - Use new clk interface
Changes in v2: - Adjust to new hook name - Fix various coding style nits
Romain Perier (2): Enable DISTRO_DEFAULTS for Rockchip platforms rockchip: Enable ETH address randomization for the rock2
Simon Glass (4): net: designware: Adjust dw_adjust_link() to return an error net: designware: Split the link init into a separate function net: designware: Export the operation functions rockchip: evb-rk3339: Enable DHCP
Sjoerd Simons (5): net: designware: Export various functions/struct to allow subclassing net: gmac_rockchip: Add Rockchip GMAC driver rockchip: Enable networking support on rock2 and firefly rockchip: Add PXE and DHCP to the default boot targets rockchip: Drop Ethernet from the TODO
Kconfig | 1 + configs/evb-rk3399_defconfig | 3 + configs/firefly-rk3288_defconfig | 4 + configs/rock2_defconfig | 5 ++ doc/README.rockchip | 1 - drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/designware.c | 57 ++++++++++---- drivers/net/designware.h | 13 ++++ drivers/net/gmac_rockchip.c | 154 ++++++++++++++++++++++++++++++++++++++ include/configs/rockchip-common.h | 4 +- 11 files changed, 232 insertions(+), 18 deletions(-) create mode 100644 drivers/net/gmac_rockchip.c
To allow other DM drivers to subclass the designware driver various functions and structures need to be exported. Export these.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Signed-off-by: Romain Perier romain.perier@collabora.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v7: NONE
Changes in v6: - Acked-by -> Signed-off-by for Romain
Changes in v5: - Added Acked-by for Romain
drivers/net/designware.c | 6 +++--- drivers/net/designware.h | 4 ++++ 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 9e6d726..6ef36bc 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -628,7 +628,7 @@ static int designware_eth_bind(struct udevice *dev) return 0; }
-static int designware_eth_probe(struct udevice *dev) +int designware_eth_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct dw_eth_dev *priv = dev_get_priv(dev); @@ -678,7 +678,7 @@ static int designware_eth_remove(struct udevice *dev) return 0; }
-static const struct eth_ops designware_eth_ops = { +const struct eth_ops designware_eth_ops = { .start = designware_eth_start, .send = designware_eth_send, .recv = designware_eth_recv, @@ -687,7 +687,7 @@ static const struct eth_ops designware_eth_ops = { .write_hwaddr = designware_eth_write_hwaddr, };
-static int designware_eth_ofdata_to_platdata(struct udevice *dev) +int designware_eth_ofdata_to_platdata(struct udevice *dev) { struct dw_eth_pdata *dw_pdata = dev_get_platdata(dev); #ifdef CONFIG_DM_GPIO diff --git a/drivers/net/designware.h b/drivers/net/designware.h index d345c5b..087ebef 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -245,6 +245,10 @@ struct dw_eth_dev { };
#ifdef CONFIG_DM_ETH +int designware_eth_ofdata_to_platdata(struct udevice *dev); +int designware_eth_probe(struct udevice *dev); +extern const struct eth_ops designware_eth_ops; + struct dw_eth_pdata { struct eth_pdata eth_pdata; u32 reset_delays[3];
On 11 January 2017 at 03:46, Romain Perier romain.perier@collabora.com wrote:
Changes in v7: NONE
Changes in v6:
Changes in v5:
Applied to u-boot-rockchip, thanks!
This function can fail, so return the error if there is one.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Romain Perier romain.perier@collabora.com Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v7: None Changes in v6: - Changed Acked-by to Signed-off-by for Romain Changes in v5: - Add Acked-by for Romain Changes in v4: None Changes in v3: - Add new patch to adjust dw_adjust_link() to return an error
Changes in v2: None
drivers/net/designware.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 6ef36bc..ebcef8b 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -230,14 +230,14 @@ static int _dw_write_hwaddr(struct dw_eth_dev *priv, u8 *mac_id) return 0; }
-static void dw_adjust_link(struct eth_mac_regs *mac_p, - struct phy_device *phydev) +static int dw_adjust_link(struct dw_eth_dev *priv, struct eth_mac_regs *mac_p, + struct phy_device *phydev) { u32 conf = readl(&mac_p->conf) | FRAMEBURSTENABLE | DISABLERXOWN;
if (!phydev->link) { printf("%s: No link.\n", phydev->dev->name); - return; + return 0; }
if (phydev->speed != 1000) @@ -256,6 +256,8 @@ static void dw_adjust_link(struct eth_mac_regs *mac_p, printf("Speed: %d, %s duplex%s\n", phydev->speed, (phydev->duplex) ? "full" : "half", (phydev->port == PORT_FIBRE) ? ", fiber mode" : ""); + + return 0; }
static void _dw_eth_halt(struct dw_eth_dev *priv) @@ -321,7 +323,9 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) return ret; }
- dw_adjust_link(mac_p, priv->phydev); + ret = dw_adjust_link(priv, mac_p, priv->phydev); + if (ret) + return ret;
if (!priv->phydev->link) return -EIO;
Changes in v5:
Changes in v2: None
With rockchip we need to make adjustments after the link speed is set but before enabling received/transmit. In preparation for this, split these two pieces into separate functions.
Changes in v7: None Changes in v6: - Changed Acked-by to Signed-off-by for Romain Changes in v5: - Added Acked-by for Romain Changes in v4: None Changes in v3: - Add new patch to split the link init into a separate function
Changes in v2: None
drivers/net/designware.c | 26 ++++++++++++++++++++++++-- 1 file changed, 24 insertions(+), 2 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index ebcef8b..0c596a7 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -327,6 +327,13 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) if (ret) return ret;
+ return 0; +} + +static int designware_eth_enable(struct dw_eth_dev *priv) +{ + struct eth_mac_regs *mac_p = priv->mac_regs_p; + if (!priv->phydev->link) return -EIO;
@@ -484,7 +491,13 @@ static int dw_phy_init(struct dw_eth_dev *priv, void *dev) #ifndef CONFIG_DM_ETH static int dw_eth_init(struct eth_device *dev, bd_t *bis) { - return _dw_eth_init(dev->priv, dev->enetaddr); + int ret; + + ret = _dw_eth_init(dev->priv, dev->enetaddr); + if (!ret) + ret = designware_eth_enable(dev->priv); + + return ret; }
static int dw_eth_send(struct eth_device *dev, void *packet, int length) @@ -575,8 +588,17 @@ int designware_initialize(ulong base_addr, u32 interface) static int designware_eth_start(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); + struct dw_eth_dev *priv = dev_get_priv(dev); + int ret;
- return _dw_eth_init(dev->priv, pdata->enetaddr); + ret = _dw_eth_init(priv, pdata->enetaddr); + if (ret) + return ret; + ret = designware_eth_enable(priv); + if (ret) + return ret; + + return 0; }
static int designware_eth_send(struct udevice *dev, void *packet, int length)
Changes in v5:
Changes in v2: None
Export all functions so that drivers can use them, or not, as the need arises.
Changes in v7: None Changes in v6: - Changed Acked-by to Signed-off-by for Romain Changes in v5: - Add Acked-by for Romain Changes in v4: None Changes in v3: - Add new patch to export the operation functions
Changes in v2: None
drivers/net/designware.c | 19 +++++++++---------- drivers/net/designware.h | 9 +++++++++ 2 files changed, 18 insertions(+), 10 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 0c596a7..f242fc6 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -271,7 +271,7 @@ static void _dw_eth_halt(struct dw_eth_dev *priv) phy_shutdown(priv->phydev); }
-static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) +int designware_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) { struct eth_mac_regs *mac_p = priv->mac_regs_p; struct eth_dma_regs *dma_p = priv->dma_regs_p; @@ -330,7 +330,7 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) return 0; }
-static int designware_eth_enable(struct dw_eth_dev *priv) +int designware_eth_enable(struct dw_eth_dev *priv) { struct eth_mac_regs *mac_p = priv->mac_regs_p;
@@ -493,7 +493,7 @@ static int dw_eth_init(struct eth_device *dev, bd_t *bis) { int ret;
- ret = _dw_eth_init(dev->priv, dev->enetaddr); + ret = designware_eth_init(dev->priv, dev->enetaddr); if (!ret) ret = designware_eth_enable(dev->priv);
@@ -591,7 +591,7 @@ static int designware_eth_start(struct udevice *dev) struct dw_eth_dev *priv = dev_get_priv(dev); int ret;
- ret = _dw_eth_init(priv, pdata->enetaddr); + ret = designware_eth_init(priv, pdata->enetaddr); if (ret) return ret; ret = designware_eth_enable(priv); @@ -601,36 +601,35 @@ static int designware_eth_start(struct udevice *dev) return 0; }
-static int designware_eth_send(struct udevice *dev, void *packet, int length) +int designware_eth_send(struct udevice *dev, void *packet, int length) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_eth_send(priv, packet, length); }
-static int designware_eth_recv(struct udevice *dev, int flags, uchar **packetp) +int designware_eth_recv(struct udevice *dev, int flags, uchar **packetp) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_eth_recv(priv, packetp); }
-static int designware_eth_free_pkt(struct udevice *dev, uchar *packet, - int length) +int designware_eth_free_pkt(struct udevice *dev, uchar *packet, int length) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_free_pkt(priv); }
-static void designware_eth_stop(struct udevice *dev) +void designware_eth_stop(struct udevice *dev) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_eth_halt(priv); }
-static int designware_eth_write_hwaddr(struct udevice *dev) +int designware_eth_write_hwaddr(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct dw_eth_dev *priv = dev_get_priv(dev); diff --git a/drivers/net/designware.h b/drivers/net/designware.h index 087ebef..7992d0e 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -253,6 +253,15 @@ struct dw_eth_pdata { struct eth_pdata eth_pdata; u32 reset_delays[3]; }; + +int designware_eth_init(struct dw_eth_dev *priv, u8 *enetaddr); +int designware_eth_enable(struct dw_eth_dev *priv); +int designware_eth_send(struct udevice *dev, void *packet, int length); +int designware_eth_recv(struct udevice *dev, int flags, uchar **packetp); +int designware_eth_free_pkt(struct udevice *dev, uchar *packet, + int length); +void designware_eth_stop(struct udevice *dev); +int designware_eth_write_hwaddr(struct udevice *dev); #endif
#endif
Changes in v5:
Changes in v2: None
Add a new driver for the GMAC ethernet interface present in Rockchip RK3288 SOCs. This driver subclasses the generic design-ware driver to add the glue needed specifically for Rockchip.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Romain Perier romain.perier@collabora.com Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v7: None Changes in v6: - Changed Acked-by to Signed-off-by for Romain Changes in v5: - Rename the driver to gmac_rockchip as suggested by David Wu - Rewrote commit message (gmac_rk3288 -> gmac_rockchip) - Added Acked-by for Romain
Changes in v4: None Changes in v3: - Add comments for struct gmac_rk3288_platdata - Adjust binding to use r/tx-delay instead of r/tx_delay - Sort includes - Use debug() instead of printf() for error - Use function calls instead of fix_mac_speed() hook - Use new clk interface
drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/gmac_rockchip.c | 154 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 162 insertions(+) create mode 100644 drivers/net/gmac_rockchip.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 929b9e2..f52629f 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -215,4 +215,11 @@ config PIC32_ETH This driver implements 10/100 Mbps Ethernet and MAC layer for Microchip PIC32 microcontrollers.
+config GMAC_ROCKCHIP + bool "Rockchip Synopsys Designware Ethernet MAC" + depends on DM_ETH && ETH_DESIGNWARE + help + This driver provides Rockchip SoCs network support based on the + Synopsys Designware driver. + endif # NETDEVICES diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 9a7bfc6..2493a48 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_FTGMAC100) += ftgmac100.o obj-$(CONFIG_FTMAC110) += ftmac110.o obj-$(CONFIG_FTMAC100) += ftmac100.o obj-$(CONFIG_GRETH) += greth.o +obj-$(CONFIG_GMAC_ROCKCHIP) += gmac_rockchip.o obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o obj-$(CONFIG_LAN91C96) += lan91c96.o diff --git a/drivers/net/gmac_rockchip.c b/drivers/net/gmac_rockchip.c new file mode 100644 index 0000000..5f833fa --- /dev/null +++ b/drivers/net/gmac_rockchip.c @@ -0,0 +1,154 @@ +/* + * (C) Copyright 2015 Sjoerd Simons sjoerd.simons@collabora.co.uk + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Rockchip GMAC ethernet IP driver for U-Boot + */ + +#include <common.h> +#include <dm.h> +#include <clk.h> +#include <phy.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/periph.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rk3288.h> +#include <dm/pinctrl.h> +#include <dt-bindings/clock/rk3288-cru.h> +#include "designware.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Platform data for the gmac + * + * dw_eth_pdata: Required platform data for designware driver (must be first) + */ +struct gmac_rockchip_platdata { + struct dw_eth_pdata dw_eth_pdata; + int tx_delay; + int rx_delay; +}; + +static int gmac_rockchip_ofdata_to_platdata(struct udevice *dev) +{ + struct gmac_rockchip_platdata *pdata = dev_get_platdata(dev); + + pdata->tx_delay = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "tx-delay", 0x30); + pdata->rx_delay = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "rx-delay", 0x10); + + return designware_eth_ofdata_to_platdata(dev); +} + +static int gmac_rockchip_fix_mac_speed(struct dw_eth_dev *priv) +{ + struct rk3288_grf *grf; + int clk; + + switch (priv->phydev->speed) { + case 10: + clk = GMAC_CLK_SEL_2_5M; + break; + case 100: + clk = GMAC_CLK_SEL_25M; + break; + case 1000: + clk = GMAC_CLK_SEL_125M; + break; + default: + debug("Unknown phy speed: %d\n", priv->phydev->speed); + return -EINVAL; + } + + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + rk_clrsetreg(&grf->soc_con1, + GMAC_CLK_SEL_MASK << GMAC_CLK_SEL_SHIFT, + clk << GMAC_CLK_SEL_SHIFT); + + return 0; +} + +static int gmac_rockchip_probe(struct udevice *dev) +{ + struct gmac_rockchip_platdata *pdata = dev_get_platdata(dev); + struct rk3288_grf *grf; + struct clk clk; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + /* Since mac_clk is fed by an external clock we can use 0 here */ + ret = clk_set_rate(&clk, 0); + if (ret) + return ret; + + /* Set to RGMII mode */ + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + rk_clrsetreg(&grf->soc_con1, + RMII_MODE_MASK << RMII_MODE_SHIFT | + GMAC_PHY_INTF_SEL_MASK << GMAC_PHY_INTF_SEL_SHIFT, + GMAC_PHY_INTF_SEL_RGMII << GMAC_PHY_INTF_SEL_SHIFT); + + rk_clrsetreg(&grf->soc_con3, + RXCLK_DLY_ENA_GMAC_MASK << RXCLK_DLY_ENA_GMAC_SHIFT | + TXCLK_DLY_ENA_GMAC_MASK << TXCLK_DLY_ENA_GMAC_SHIFT | + CLK_RX_DL_CFG_GMAC_MASK << CLK_RX_DL_CFG_GMAC_SHIFT | + CLK_TX_DL_CFG_GMAC_MASK << CLK_TX_DL_CFG_GMAC_SHIFT, + RXCLK_DLY_ENA_GMAC_ENABLE << RXCLK_DLY_ENA_GMAC_SHIFT | + TXCLK_DLY_ENA_GMAC_ENABLE << TXCLK_DLY_ENA_GMAC_SHIFT | + pdata->rx_delay << CLK_RX_DL_CFG_GMAC_SHIFT | + pdata->tx_delay << CLK_TX_DL_CFG_GMAC_SHIFT); + + return designware_eth_probe(dev); +} + +static int gmac_rockchip_eth_start(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct dw_eth_dev *priv = dev_get_priv(dev); + int ret; + + ret = designware_eth_init(priv, pdata->enetaddr); + if (ret) + return ret; + ret = gmac_rockchip_fix_mac_speed(priv); + if (ret) + return ret; + ret = designware_eth_enable(priv); + if (ret) + return ret; + + return 0; +} + +const struct eth_ops gmac_rockchip_eth_ops = { + .start = gmac_rockchip_eth_start, + .send = designware_eth_send, + .recv = designware_eth_recv, + .free_pkt = designware_eth_free_pkt, + .stop = designware_eth_stop, + .write_hwaddr = designware_eth_write_hwaddr, +}; + +static const struct udevice_id rockchip_gmac_ids[] = { + { .compatible = "rockchip,rk3288-gmac" }, + { } +}; + +U_BOOT_DRIVER(eth_gmac_rockchip) = { + .name = "gmac_rockchip", + .id = UCLASS_ETH, + .of_match = rockchip_gmac_ids, + .ofdata_to_platdata = gmac_rockchip_ofdata_to_platdata, + .probe = gmac_rockchip_probe, + .ops = &gmac_rockchip_eth_ops, + .priv_auto_alloc_size = sizeof(struct dw_eth_dev), + .platdata_auto_alloc_size = sizeof(struct gmac_rockchip_platdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
Changes in v5:
- Sort includes
Enable the various configuration option required to get the ethernet interface up and running on Radxa Rock2 and Firefly.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Signed-off-by: Romain Perier romain.perier@collabora.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v7: None Changes in v6: - Changed Acked-by to Signed-off-by for Romain Changes in v5: - Added Acked-by for Romain - Replaced CONFIG_GMAC_RK3288 by CONFIG_GMAC_ROCKCHIP Changes in v4: None Changes in v3: None Changes in v2: None
configs/firefly-rk3288_defconfig | 4 ++++ configs/rock2_defconfig | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 4910c80..3431464 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -44,6 +44,10 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_ROCKCHIP_DWMMC=y +CONFIG_DM_ETH=y +CONFIG_NETDEVICES=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_FULL is not set diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 9e332bc..597d465 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -42,6 +42,10 @@ CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_ROCKCHIP_DWMMC=y +CONFIG_DM_ETH=y +CONFIG_NETDEVICES=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_FULL is not set
Changes in v5:
This is the only RK3399 device without DHCP. Enable it so that we can use a common BOOT_TARGET_DEVICES setting. It is likely useful to be able to use USB networking, at least. Full networking can be enabled when a suitable platform needs it.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: - Fix commit message to say 'rk3399'
Changes in v3: - Add new patch to enable networking on evb-rk3399
Changes in v2: None
configs/evb-rk3399_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 6c27104..b1eefe2 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -11,6 +11,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y
Changes in v3:
Changes in v2: None
This enables suitable commands needed for booting general purpose Linux distribution. This is required for example if we want to use PXE or DHCP as default boot targets, symbols no longer enabled by config_distro_defaults.h .
Signed-off-by: Romain Perier romain.perier@collabora.com ---
Changes in v7: - Added this commit to fix build failure introduced by commit 09/11
Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/Kconfig b/Kconfig index a44ac91..ebc3974 100644 --- a/Kconfig +++ b/Kconfig @@ -57,6 +57,7 @@ config DISTRO_DEFAULTS bool "Select defaults suitable for booting general purpose Linux distributions" default y if ARCH_SUNXI || TEGRA default y if ARCH_LS2080A + default y if ARCH_ROCKCHIP default n select CMD_BOOTZ if ARM && !ARM64 select CMD_BOOTI if ARM64
Changes in v7:
Now that at least on the firefly board we have network support, enable PXE and DHCP boot targets by default.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Acked-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
include/configs/rockchip-common.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 9ec71c4..be53e65 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -14,7 +14,9 @@ /* First try to boot from SD (index 0), then eMMC (index 1 */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ - func(MMC, mmc, 1) + func(MMC, mmc, 1) \ + func(PXE, pxe, na) \ + func(DHCP, dchp, na)
/* Enable gpt partition table */ #define CONFIG_CMD_GPT
This commit enables ethernet MAC address randomization on the rock2. It removes the error at startup 'ethernet@ff290000 address not set'.
Changes in v7: - Added this commit to the series
configs/rock2_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 597d465..ea8ba06 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y
Changes in v7:
Now that ethernet support works, it can be dropped from the rockchip TODO
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Acked-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: - Add a few new patches - Drop the 'net: designware: Add a fix_mac_speed hook' patch
doc/README.rockchip | 1 - 1 file changed, 1 deletion(-)
diff --git a/doc/README.rockchip b/doc/README.rockchip index 06ec80e..43cafc7 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -219,7 +219,6 @@ Immediate priorities are: - USB host - USB device - Run CPU at full speed (code exists but we only see ~60 DMIPS maximum) -- Ethernet - NAND flash - Support for other Rockchip parts - Boot U-Boot proper over USB OTG (at present only SPL works)
From Romain:
From Simon:
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
- Sort includes
Changes in v2:
-- 2.9.3
I have tested this on a gigabit link and it does not work. I wonder if the clocks are wrong?
However it works fine on 100Mbps which is better than what we have, so I'm going to apply this. Thank you for your work, Romain.
On Wed, 2017-01-11 at 22:08 -0700, Simon Glass wrote:
On 11 January 2017 at 03:46, Romain Perier <romain.perier@collabora.c om> wrote:
From Romain:
Funny, my initial patchset only worked on gigabit due to a wrong phy clock on 100mbit/s. Hopefully should be an easy fix in a follow-up patch. Thanks for merging!
Hi Sjoerd,
On 12 January 2017 at 00:53, Sjoerd Simons sjoerd.simons@collabora.co.uk wrote:
From Romain:
Yes, it worked OK for me ages ago when I first tested it, but I did have a different setup. It gives a lot of timeouts for me now. As you say it shouldn't be hard to resolve.
Romain Perier
Sjoerd Simons
