[U-Boot] [PATCH] tests: Make test_log.py tests depend on cmd_log not log
While the tests in this testcase are for the log subsystem they are only able to be run if CONFIG_CMD_LOG is enabled as well as CONFIG_LOG, so update the buildconfigspec requirement.
Signed-off-by: Tom Rini trini@konsulko.com --- test/py/tests/test_log.py | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/test/py/tests/test_log.py b/test/py/tests/test_log.py index d1c2a36d8f25..605275b03992 100644 --- a/test/py/tests/test_log.py +++ b/test/py/tests/test_log.py @@ -12,7 +12,7 @@ import pytest
LOGL_FIRST, LOGL_WARNING, LOGL_INFO = (0, 4, 6)
-@pytest.mark.buildconfigspec('log') +@pytest.mark.buildconfigspec('cmd_log') def test_log(u_boot_console): """Test that U-Boot logging works correctly.""" def check_log_entries(lines, mask, max_level=LOGL_INFO): @@ -98,7 +98,7 @@ def test_log(u_boot_console): test8() test9()
-@pytest.mark.buildconfigspec('log') +@pytest.mark.buildconfigspec('cmd_log') def test_log_format(u_boot_console): """Test the 'log format' and 'log rec' commands""" def run_with_format(fmt, expected_output):
