[PATCH] dt-bindings: nvmem: u-boot,env: add basic NVMEM cells
U-Boot doesn't have cells at hardcoded addresses. They are stored in internal format. It's still important to define relevant cells in DT so NVMEM consumers can reference them.
Update binding to allow including basic cells as NVMEM device subnodes.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- .../devicetree/bindings/nvmem/u-boot,env.yaml | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml b/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml index e70b2a60cb9a..e96bca99f2d9 100644 --- a/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml +++ b/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml @@ -24,6 +24,8 @@ description: | Right now only flash partition case is covered but it may be extended to e.g. UBI volumes in the future.
+ Variables can be defined as NVMEM device subnodes. + maintainers: - Rafał Miłecki rafal@milecki.pl
@@ -40,6 +42,14 @@ properties: reg: maxItems: 1
+ bootcmd: + type: object + description: Command to use for automatic booting + + ethaddr: + type: object + description: Ethernet interface's MAC address + additionalProperties: false
examples: @@ -58,5 +68,8 @@ examples: env: partition@40000 { compatible = "u-boot,env"; reg = <0x40000 0x10000>; + + mac: ethaddr { + }; }; };
Ping :)
For a reference you can see Broadcom's NVRAM (identical feature):
084973e944bec ("dt-bindings: nvmem: brcm,nvram: add basic NVMEM cells") https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
c8442f0fb09ca ("ARM: dts: BCM5301X: Add Ethernet MAC address to Luxul XWR-3150") https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i...
Ping :)
Seems fine to me.
Sorry, I guess I was thinking this depended on or interacted with one of the other nvmem series.
Applied, thanks!
Rob
Rafał Miłecki
Rob Herring
