[U-Boot] [PATCH v3 1/3] armv8/ls1043a: fixup GIC offset according to SVR and SCFG_GIC400_ALIGN[GIC_ADDR_BIT]
The LS1043A rev1.1 silicon supports two types of GIC offset: 4K alignment and 64K alignment. The bit SCFG_GIC400_ALIGN[GIC_ADDR_BIT] is used to choose which offset will be used.
If GIC_ADDR_BIT bit is set, 4K alignment is used, or else 64K alignment is used. 64K alignment is the default setting.
Overriding the weekly smp_kick_all_cpus, the new impletment is able to detect GIC offset.
Signed-off-by: Wenbin Song wenbin.song@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com --- Changes in v3: Add description about smp_kick_all_cpus on commit message. Rename the macros on commit message to match with them used in the change. Replace CONFIG_LS1043A with HAS_FEATURE_GIC4K_ALIGN. Changes in v2: None --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 47 +++++++++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 12 +++++- 3 files changed, 61 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 94ec8d5..c66c497 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -12,6 +12,7 @@ config ARCH_LS1043A select SYS_FSL_DDR_VER_50 select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A010539 + select HAS_FEATURE_GIC4K_ALIGN
config ARCH_LS1046A bool @@ -135,4 +136,7 @@ config SYS_FSL_DDR4 help Enable Freescale DDR4 controller.
+config HAS_FEATURE_GIC4K_ALIGN + bool + endmenu diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 5d0b7a4..f0da559 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -14,6 +14,40 @@ #include <asm/arch/mp.h> #endif
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + +/* fixup GIC offset */ +ENTRY(fix_gic_offset) + ldr x0, =GICD_BASE + ldr x1, =GICC_BASE + ldr x3, =DCFG_CCSR_SVR + ldr w3, [x3] + rev w3, w3 + ands w3, w3, #0xff + cmp w3, #REV1_0 + b.eq 1f + ldr x3, =SCFG_GIC400_ALIGN + ldr w3, [x3] + rev w3, w3 + tbnz w3, #GIC_ADDR_BIT, 1f + ret +1: + ldr x0, =GICD_BASE_4K + ldr x1, =GICC_BASE_4K + ret +ENDPROC(fix_gic_offset) + +ENTRY(smp_kick_all_cpus) + /* Kick secondary cpus up by SGI 0 interrupt */ + mov x29, lr /* Save LR */ + bl fix_gic_offset + bl gic_kick_secondary_cpus + mov lr, x29 /* Restore LR */ + ret +ENDPROC(smp_kick_all_cpus) + +#endif + ENTRY(lowlevel_init) mov x29, lr /* Save LR */
@@ -105,15 +139,23 @@ ENTRY(lowlevel_init) /* Initialize GIC Secure Bank Status */ #if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) branch_if_slave x0, 1f +#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + bl fix_gic_offset +#else ldr x0, =GICD_BASE +#endif bl gic_init_secure 1: #ifdef CONFIG_GICV3 ldr x0, =GICR_BASE bl gic_init_secure_percpu #elif defined(CONFIG_GICV2) +#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + bl fix_gic_offset +#else ldr x0, =GICD_BASE ldr x1, =GICC_BASE +#endif bl gic_init_secure_percpu #endif #endif @@ -335,7 +377,12 @@ ENTRY(secondary_boot_func) #if defined(CONFIG_GICV3) gic_wait_for_interrupt_m x0 #elif defined(CONFIG_GICV2) +#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + bl fix_gic_offset + mov x0, x1 +#else ldr x0, =GICC_BASE +#endif gic_wait_for_interrupt_m x0, w1 #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 4201e0f..eb6e58d 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -172,8 +172,16 @@ #define SMMU_BASE 0x09000000
/* Generic Interrupt Controller Definitions */ -#define GICD_BASE 0x01401000 -#define GICC_BASE 0x01402000 +#define GICD_BASE 0x01410000 +#define GICC_BASE 0x01420000 +#define GICD_BASE_4K 0x01401000 +#define GICC_BASE_4K 0x01402000 + +#define DCFG_CCSR_SVR 0x1ee00a4 +#define REV1_0 0x10 +#define REV1_1 0x11 +#define GIC_ADDR_BIT 31 +#define SCFG_GIC400_ALIGN 0x1570188
#define CONFIG_SYS_FSL_ERRATUM_A008850 #define CONFIG_SYS_FSL_ERRATUM_A009663
The LS1043A rev1.1 silicon supports two types of GIC offset: 4K alignment and 64K alignment. 4K alignment is consistent with rev1.0 implement.
The default GIC offset in kernel device tree is using 64K alignment, if rev1.0 silicon used, need to fixup the GIC node to use 4K alignment.
Signed-off-by: Wenbin Song wenbin.song@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com --- Changes for v3: Replace CONFIG_LS1043A with HAS_FEATURE_GIC4K_ALIGN. --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 49 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 3 +- 2 files changed, 51 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 1a8321b..54f8492 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -126,6 +126,52 @@ void fsl_fdt_disable_usb(void *blob) } }
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN +/* Fixup gic node align with 4K */ +static void fdt_fixup_gic(void *blob) +{ + int offset, err; + u64 reg[8]; + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + unsigned int val; + struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR; + + val = gur_in32(&gur->svr) & 0xff; + + if (val == REV1_1) { + val = scfg_in32(&scfg->gic_align) & (0x01 << GIC_ADDR_BIT); + if (!val) + return; + } + + offset = fdt_subnode_offset(blob, 0, "interrupt-controller@1400000"); + if (offset < 0) { + printf("WARNING: fdt_subnode_offset can't find node %s: %s\n", + "interrupt-controller@1400000", fdt_strerror(offset)); + return; + } + + reg[0] = cpu_to_fdt64(0x1401000); + reg[1] = cpu_to_fdt64(0x1000); + reg[2] = cpu_to_fdt64(0x1402000); + reg[3] = cpu_to_fdt64(0x2000); + reg[4] = cpu_to_fdt64(0x1404000); + reg[5] = cpu_to_fdt64(0x2000); + reg[6] = cpu_to_fdt64(0x1406000); + reg[7] = cpu_to_fdt64(0x2000); + + err = fdt_setprop(blob, offset, "reg", reg, sizeof(reg)); + if (err < 0) { + printf("WARNING: fdt_setprop can't set %s from node %s: %s\n", + "reg", "interrupt-controller@1400000", + fdt_strerror(err)); + return; + } + + return; +} +#endif + void ft_cpu_setup(void *blob, bd_t *bd) { #ifdef CONFIG_FSL_LSCH2 @@ -170,4 +216,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #endif fsl_fdt_disable_usb(blob);
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + fdt_fixup_gic(blob); +#endif } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d88543d..1dfef53 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -359,7 +359,8 @@ struct ccsr_scfg { u32 qspi_cfg; u8 res_160[0x180-0x160]; u32 dmamcr; - u8 res_184[0x18c-0x184]; + u8 res_184[0x188-0x184]; + u32 gic_align; u32 debug_icid; u8 res_190[0x1a4-0x190]; u32 snpcnfgcr;
- int offset, err;
- u64 reg[8];
- struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR);
- unsigned int val;
- struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR;
- val = gur_in32(&gur->svr) & 0xff;
- if (val == REV1_1) {
if (!val)
return;
For rev 1.0 SoC, it runs through here, right? If that what you want?
- offset = fdt_subnode_offset(blob, 0, "interrupt-controller@1400000");
- if (offset < 0) {
return;
- reg[0] = cpu_to_fdt64(0x1401000);
- reg[1] = cpu_to_fdt64(0x1000);
- reg[2] = cpu_to_fdt64(0x1402000);
- reg[3] = cpu_to_fdt64(0x2000);
- reg[4] = cpu_to_fdt64(0x1404000);
- reg[5] = cpu_to_fdt64(0x2000);
- reg[6] = cpu_to_fdt64(0x1406000);
- reg[7] = cpu_to_fdt64(0x2000);
What are these magic numbers?
- err = fdt_setprop(blob, offset, "reg", reg, sizeof(reg));
- if (err < 0) {
fdt_strerror(err));
return;
- return;
+} +#endif
- fdt_fixup_gic(blob);
- u8 res_184[0x188-0x184];
- u32 gic_align; u32 debug_icid; u8 res_190[0x1a4-0x190]; u32 snpcnfgcr;
Would it be reasonable to squash this patch with previous one in this set? They both deal with the same thing. If you run git bisect between this two, you don't get correct gic offset in device tree, do you?
York
hi
Best Regards Wenbin Song
-----Original Message----- From: york sun Sent: Friday, October 21, 2016 10:16 PM To: Wenbin Song wenbin.song@nxp.com; albert.u.boot@aribaud.net; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH v3 2/3] armv8/fsl-layerscape: fdt: fixup GIC node for LS1043A rev1.0
implement.
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN +/* Fixup gic node align with 4K */ +static void fdt_fixup_gic(void *blob) {
- int offset, err;
- u64 reg[8];
- unsigned int val;
if (!val)
return;
[wenbin] For rev1.0 , it should be fixed, too. Because rev1.0 is using 4K offset alignment, but the default is using 64K alignment. I will give some descriptions on commit message about it.
- if (offset < 0) {
node %s: %s\n",
return;
[wenbin] they are the offset and size for each GIC components. I will redefine them using macros.
- if (err < 0) {
node %s: %s\n",
fdt_strerror(err));
return;
- return;
+} +#endif
[wenbin]yes , I will squash it .
York
The default MSI node in kernel tree is for LS1043A rev1.1 silicon, if rev1.0 silicon used, need to fixup the MSI node to match it.
Signed-off-by: Wenbin Song wenbin.song@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com --- Changes for v3: Replace CONFIG_LS1043A with HAS_FEATURE_ENHACED_MSI. --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 + arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 94 +++++++++++++++++++++++++++++++ 2 files changed, 97 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index c66c497..d2537bb 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -13,6 +13,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A010539 select HAS_FEATURE_GIC4K_ALIGN + select HAS_FEATURE_ENHANCED_MSI
config ARCH_LS1046A bool @@ -138,5 +139,7 @@ config SYS_FSL_DDR4
config HAS_FEATURE_GIC4K_ALIGN bool +config HAS_FEATURE_ENHANCED_MSI + bool
endmenu diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 54f8492..7a1e445 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -171,6 +171,97 @@ static void fdt_fixup_gic(void *blob) return; } #endif +#ifdef CONFIG_HAS_FEATURE_ENHANCED_MSI +static int _fdt_fixup_msi_subnode(void *blob, int parentoffset, + const char *name, int irq_no) +{ + int err, offset; + u32 tmp[3]; + + offset = fdt_subnode_offset(blob, parentoffset, name); + if (offset < 0) { + printf("WARNING: fdt_subnode_offset can't find %s: %s\n", + name, fdt_strerror(offset)); + return 0; + } + + tmp[0] = cpu_to_fdt32(0x0); + tmp[1] = cpu_to_fdt32(irq_no); + tmp[2] = cpu_to_fdt32(0x4); + + err = fdt_setprop(blob, offset, "interrupts", tmp, sizeof(tmp)); + if (err < 0) { + printf("WARNING: fdt_setprop can't set %s from node %s: %s\n", + "interrupts", name, fdt_strerror(err)); + return 0; + } + + return 1; +} + +static int _fdt_fixup_pci_msi(void *blob, const char *name) +{ + int offset, len, err; + void *p; + int val; + u32 tmp[4][8]; + + offset = fdt_path_offset(blob, name); + if (offset < 0) { + printf("WARNING: fdt_path_offset can't find path %s: %s\n", + name, fdt_strerror(offset)); + return 0; + } + + p = (char *)fdt_getprop(blob, offset, "interrupt-map", &len); + if (!p || len != sizeof(tmp)) { + printf("WARNING: fdt_getprop can't get %s from node %s\n", + "interrupt-map", name); + return 0; + } + + memcpy((char *)tmp, p, len); + val = fdt32_to_cpu(tmp[0][6]); + tmp[1][6] = cpu_to_fdt32(val + 1); + tmp[2][6] = cpu_to_fdt32(val + 2); + tmp[3][6] = cpu_to_fdt32(val + 3); + + err = fdt_setprop(blob, offset, "interrupt-map", tmp, sizeof(tmp)); + if (err < 0) { + printf("WARNING: fdt_setprop can't set %s from node %s: %s.\n", + "interrupt-map", name, fdt_strerror(err)); + return 0; + } + return 1; +} + +/* Fixup msi to v1_0*/ + +static void fdt_fixup_msi(void *blob) +{ + int nodeoffset; + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + unsigned int val; + + val = gur_in32(&gur->svr) & 0xff; + if (val == REV1_1) + return; + + nodeoffset = fdt_path_offset(blob, "/soc/msi-controller"); + if (nodeoffset < 0) { + printf("WARNING: fdt_path_offset can't find path %s: %s\n", + "/soc/msi-controller", fdt_strerror(nodeoffset)); + return; + } + _fdt_fixup_msi_subnode(blob, nodeoffset, "msi0@1571000", 116); + _fdt_fixup_msi_subnode(blob, nodeoffset, "msi1@1572000", 126); + _fdt_fixup_msi_subnode(blob, nodeoffset, "msi2@1573000", 160); + + _fdt_fixup_pci_msi(blob, "/soc/pcie@3400000"); + _fdt_fixup_pci_msi(blob, "/soc/pcie@3500000"); + _fdt_fixup_pci_msi(blob, "/soc/pcie@3600000"); +} +#endif
void ft_cpu_setup(void *blob, bd_t *bd) { @@ -219,4 +310,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN fdt_fixup_gic(blob); #endif +#ifdef CONFIG_HAS_FEATURE_ENHANCED_MSI + fdt_fixup_msi(blob); +#endif }
- select HAS_FEATURE_GIC4K_ALIGN
bool
Nitpick. It would be easier to understand if you have some comments to show the input and output of such function.
- ldr x0, =GICD_BASE
- ldr x1, =GICC_BASE
- ldr x3, =DCFG_CCSR_SVR
- ldr w3, [x3]
- rev w3, w3
- ands w3, w3, #0xff
- cmp w3, #REV1_0
- b.eq 1f
- ldr x3, =SCFG_GIC400_ALIGN
- ldr w3, [x3]
- rev w3, w3
- tbnz w3, #GIC_ADDR_BIT, 1f
- ret
+1:
- ldr x0, =GICD_BASE_4K
- ldr x1, =GICC_BASE_4K
- ret
- /* Kick secondary cpus up by SGI 0 interrupt */
- mov x29, lr /* Save LR */
- bl fix_gic_offset
- bl gic_kick_secondary_cpus
- mov lr, x29 /* Restore LR */
- ret
- bl fix_gic_offset
- bl fix_gic_offset
- bl fix_gic_offset
- mov x0, x1
Reviewed-by: York Sun york.sun@nxp.com
Wenbin Song
Wenbin song
york sun
