[PATCH] efi_loader: use %zu not %zd to print efi_uintn_t
efi_uintnt_t is an unsigned type. We should avoid showing negative numbers.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_boottime.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 1823990d9b..4f55dc82ff 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -464,7 +464,7 @@ static efi_status_t EFIAPI efi_allocate_pool_ext(int pool_type, { efi_status_t r;
- EFI_ENTRY("%d, %zd, %p", pool_type, size, buffer); + EFI_ENTRY("%d, %zu, %p", pool_type, size, buffer); r = efi_allocate_pool(pool_type, size, buffer); return EFI_EXIT(r); } @@ -911,7 +911,7 @@ static efi_status_t EFIAPI efi_wait_for_event(efi_uintn_t num_events, { int i;
- EFI_ENTRY("%zd, %p, %p", num_events, event, index); + EFI_ENTRY("%zu, %p, %p", num_events, event, index);
/* Check parameters */ if (!num_events || !event) @@ -2025,7 +2025,7 @@ efi_status_t EFIAPI efi_load_image(bool boot_policy, efi_status_t ret; void *dest_buffer;
- EFI_ENTRY("%d, %p, %pD, %p, %zd, %p", boot_policy, parent_image, + EFI_ENTRY("%d, %p, %pD, %p, %zu, %p", boot_policy, parent_image, file_path, source_buffer, source_size, image_handle);
if (!image_handle || (!source_buffer && !file_path) ||
