[U-Boot] [PATCH 1/3] xilinx: zynq: Enable DCC and create new zynq_dcc board
Enable DCC driver for arm zynq platform to be compiled.
Signed-off-by: Michal Simek michal.simek@xilinx.com --- boards.cfg | 1 + include/configs/zynq.h | 5 +++++ 2 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 98f7a14..1d30a18 100644 --- a/boards.cfg +++ b/boards.cfg @@ -296,6 +296,7 @@ snowball arm armv7 snowball st-e kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq +zynq_dcc arm armv7 zynq xilinx zynq zynq:ZYNQ_DCC socfpga_cyclone5 arm armv7 socfpga_cyclone5 altera socfpga actux1_4_16 arm ixp actux1 - - actux1:FLASH2X2 actux1_4_32 arm ixp actux1 - - actux1:FLASH2X2,RAM_32MB diff --git a/include/configs/zynq.h b/include/configs/zynq.h index 18fd76f..2989e72 100644 --- a/include/configs/zynq.h +++ b/include/configs/zynq.h @@ -58,6 +58,11 @@ #define CONFIG_ZYNQ_GEM #define CONFIG_ZYNQ_GEM_BASEADDR0 0xE000B000
+#if defined(CONFIG_ZYNQ_DCC) +# define CONFIG_ARM_DCC +# define CONFIG_CPU_V6 /* Required by CONFIG_ARM_DCC */ +#endif + #define CONFIG_BOOTP_SERVERIP #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_GATEWAY
The patch provides slcr base address initialization support and a support to reset the cpu through slcr driver, hence removed the reset_cpu() from board.c.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com --- arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/cpu.c | 2 + arch/arm/cpu/armv7/zynq/slcr.c | 63 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynq/hardware.h | 41 ++++++++++++++++++ arch/arm/include/asm/arch-zynq/sys_proto.h | 30 +++++++++++++ 5 files changed, 137 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/zynq/slcr.c create mode 100644 arch/arm/include/asm/arch-zynq/hardware.h create mode 100644 arch/arm/include/asm/arch-zynq/sys_proto.h
diff --git a/arch/arm/cpu/armv7/zynq/Makefile b/arch/arm/cpu/armv7/zynq/Makefile index 499ace4..388085d 100644 --- a/arch/arm/cpu/armv7/zynq/Makefile +++ b/arch/arm/cpu/armv7/zynq/Makefile @@ -30,6 +30,7 @@ LIB = $(obj)lib$(SOC).o
COBJS-y := timer.o COBJS-y += cpu.o +COBJS-y += slcr.o
COBJS := $(COBJS-y)
diff --git a/arch/arm/cpu/armv7/zynq/cpu.c b/arch/arm/cpu/armv7/zynq/cpu.c index ab615cc..91618d3 100644 --- a/arch/arm/cpu/armv7/zynq/cpu.c +++ b/arch/arm/cpu/armv7/zynq/cpu.c @@ -21,11 +21,13 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/arch/sys_proto.h>
inline void lowlevel_init(void) {}
void reset_cpu(ulong addr) { + zynq_slcr_cpu_reset(); while (1) ; } diff --git a/arch/arm/cpu/armv7/zynq/slcr.c b/arch/arm/cpu/armv7/zynq/slcr.c new file mode 100644 index 0000000..788a8fd --- /dev/null +++ b/arch/arm/cpu/armv7/zynq/slcr.c @@ -0,0 +1,63 @@ +/* + * Copyright (c) 2013 Xilinx Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <malloc.h> +#include <asm/arch/hardware.h> + +#define SLCR_LOCK_MAGIC 0x767B +#define SLCR_UNLOCK_MAGIC 0xDF0D + +static int slcr_lock = 1; /* 1 means locked, 0 means unlocked */ + +void zynq_slcr_lock(void) +{ + if (!slcr_lock) + writel(SLCR_LOCK_MAGIC, &slcr_base->slcr_lock); +} + +void zynq_slcr_unlock(void) +{ + if (slcr_lock) + writel(SLCR_UNLOCK_MAGIC, &slcr_base->slcr_unlock); +} + +/* Reset the entire system */ +void zynq_slcr_cpu_reset(void) +{ + /* + * Unlock the SLCR then reset the system. + * Note that this seems to require raw i/o + * functions or there's a lockup? + */ + zynq_slcr_unlock(); + + /* + * Clear 0x0F000000 bits of reboot status register to workaround + * the FSBL not loading the bitstream after soft-reboot + * This is a temporary solution until we know more. + */ + clrbits_le32(&slcr_base->reboot_status, 0xF000000); + + writel(1, &slcr_base->pss_rst_ctrl); +} diff --git a/arch/arm/include/asm/arch-zynq/hardware.h b/arch/arm/include/asm/arch-zynq/hardware.h new file mode 100644 index 0000000..ad17b27 --- /dev/null +++ b/arch/arm/include/asm/arch-zynq/hardware.h @@ -0,0 +1,41 @@ +/* + * Copyright (c) 2013 Xilinx Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_ARCH_HARDWARE_H +#define _ASM_ARCH_HARDWARE_H + +#define XPSS_SYS_CTRL_BASEADDR 0xF8000000 + +/* Reflect slcr offsets */ +struct slcr_regs { + u32 scl; /* 0x0 */ + u32 slcr_lock; /* 0x4 */ + u32 slcr_unlock; /* 0x8 */ + u32 reserved1[125]; + u32 pss_rst_ctrl; /* 0x200 */ + u32 reserved2[21]; + u32 reboot_status; /* 0x258 */ +}; + +#define slcr_base ((struct slcr_regs *) XPSS_SYS_CTRL_BASEADDR) + +#endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-zynq/sys_proto.h b/arch/arm/include/asm/arch-zynq/sys_proto.h new file mode 100644 index 0000000..e788900 --- /dev/null +++ b/arch/arm/include/asm/arch-zynq/sys_proto.h @@ -0,0 +1,30 @@ +/* + * Copyright (c) 2013 Xilinx Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ + +extern void zynq_slcr_lock(void); +extern void zynq_slcr_unlock(void); +extern void zynq_slcr_cpu_reset(void); + +#endif /* _SYS_PROTO_H_ */
Do lowlevel initialization directly in C. Zynq do not require to do it in asm.
Signed-off-by: Michal Simek michal.simek@xilinx.com --- arch/arm/cpu/armv7/zynq/cpu.c | 26 +++++++++++++++- arch/arm/include/asm/arch-zynq/hardware.h | 46 ++++++++++++++++++++++++++++- 2 files changed, 70 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/zynq/cpu.c b/arch/arm/cpu/armv7/zynq/cpu.c index 91618d3..e8f4c19 100644 --- a/arch/arm/cpu/armv7/zynq/cpu.c +++ b/arch/arm/cpu/armv7/zynq/cpu.c @@ -21,9 +21,33 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/io.h> #include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h>
-inline void lowlevel_init(void) {} +void lowlevel_init(void) +{ + zynq_slcr_unlock(); + /* remap DDR to zero, FILTERSTART */ + writel(0, &scu_base->filter_start); + + /* Device config APB, unlock the PCAP */ + writel(0x757BDF0D, &devcfg_base->unlock); + writel(0xFFFFFFFF, &devcfg_base->rom_shadow); + + /* OCM_CFG, Mask out the ROM, map ram into upper addresses */ + writel(0x1F, &slcr_base->ocm_cfg); + /* FPGA_RST_CTRL, clear resets on AXI fabric ports */ + writel(0x0, &slcr_base->fpga_rst_ctrl); + /* TZ_DDR_RAM, Set DDR trust zone non-secure */ + writel(0xFFFFFFFF, &slcr_base->trust_zone); + /* Set urgent bits with register */ + writel(0x0, &slcr_base->ddr_urgent_sel); + /* Urgent write, ports S2/S3 */ + writel(0xC, &slcr_base->ddr_urgent); + + zynq_slcr_lock(); +}
void reset_cpu(ulong addr) { diff --git a/arch/arm/include/asm/arch-zynq/hardware.h b/arch/arm/include/asm/arch-zynq/hardware.h index ad17b27..d0c69da 100644 --- a/arch/arm/include/asm/arch-zynq/hardware.h +++ b/arch/arm/include/asm/arch-zynq/hardware.h @@ -24,6 +24,8 @@ #define _ASM_ARCH_HARDWARE_H
#define XPSS_SYS_CTRL_BASEADDR 0xF8000000 +#define XPSS_DEV_CFG_APB_BASEADDR 0xF8007000 +#define XPSS_SCU_BASEADDR 0xF8F00000
/* Reflect slcr offsets */ struct slcr_regs { @@ -32,10 +34,52 @@ struct slcr_regs { u32 slcr_unlock; /* 0x8 */ u32 reserved1[125]; u32 pss_rst_ctrl; /* 0x200 */ - u32 reserved2[21]; + u32 reserved2[15]; + u32 fpga_rst_ctrl; /* 0x240 */ + u32 reserved3[5]; u32 reboot_status; /* 0x258 */ + u32 boot_mode; /* 0x25c */ + u32 reserved4[116]; + u32 trust_zone; /* 0x430 */ /* FIXME */ + u32 reserved5[115]; + u32 ddr_urgent; /* 0x600 */ + u32 reserved6[6]; + u32 ddr_urgent_sel; /* 0x61c */ + u32 reserved7[188]; + u32 ocm_cfg; /* 0x910 */ };
+struct devcfg_regs { + u32 ctrl; /* 0x0 */ + u32 lock; /* 0x4 */ + u32 cfg; /* 0x8 */ + u32 int_sts; /* 0xc */ + u32 int_mask; /* 0x10 */ + u32 status; /* 0x14 */ + u32 dma_src_addr; /* 0x18 */ + u32 dma_dst_addr; /* 0x1c */ + u32 dma_src_len; /* 0x20 */ + u32 dma_dst_len; /* 0x24 */ + u32 rom_shadow; /* 0x28 */ + u32 reserved1[2]; + u32 unlock; /* 0x34 */ + u32 reserved2[18]; + u32 mctrl; /* 0x80 */ + u32 reserved3; + u32 write_count; /* 0x88 */ + u32 read_count; /* 0x8c */ +}; + +#define devcfg_base ((struct devcfg_regs *) XPSS_DEV_CFG_APB_BASEADDR) + +struct scu_regs { + u32 reserved1[16]; + u32 filter_start; /* 0x40 */ + u32 filter_end; /* 0x44 */ +}; + +#define scu_base ((struct scu_regs *) XPSS_SCU_BASEADDR) + #endif /* _ASM_ARCH_HARDWARE_H */
Hi Michal,
On Mon, 4 Feb 2013 15:36:07 +0100, Michal Simek michal.simek@xilinx.com wrote:
- MA 02111-1307 USA
- zynq_slcr_unlock();
- /* remap DDR to zero, FILTERSTART */
- writel(0, &scu_base->filter_start);
- /* Device config APB, unlock the PCAP */
- writel(0x757BDF0D, &devcfg_base->unlock);
- writel(0xFFFFFFFF, &devcfg_base->rom_shadow);
- /* OCM_CFG, Mask out the ROM, map ram into upper addresses */
- writel(0x1F, &slcr_base->ocm_cfg);
- /* FPGA_RST_CTRL, clear resets on AXI fabric ports */
- writel(0x0, &slcr_base->fpga_rst_ctrl);
- /* TZ_DDR_RAM, Set DDR trust zone non-secure */
- writel(0xFFFFFFFF, &slcr_base->trust_zone);
- /* Set urgent bits with register */
- writel(0x0, &slcr_base->ddr_urgent_sel);
- /* Urgent write, ports S2/S3 */
- writel(0xC, &slcr_base->ddr_urgent);
- zynq_slcr_lock();
- u32 reserved2[15];
- u32 fpga_rst_ctrl; /* 0x240 */
- u32 reserved3[5]; u32 reboot_status; /* 0x258 */
- u32 boot_mode; /* 0x25c */
- u32 reserved4[116];
- u32 trust_zone; /* 0x430 */ /* FIXME */
- u32 reserved5[115];
- u32 ddr_urgent; /* 0x600 */
- u32 reserved6[6];
- u32 ddr_urgent_sel; /* 0x61c */
- u32 reserved7[188];
- u32 ocm_cfg; /* 0x910 */
- u32 ctrl; /* 0x0 */
- u32 lock; /* 0x4 */
- u32 cfg; /* 0x8 */
- u32 int_sts; /* 0xc */
- u32 int_mask; /* 0x10 */
- u32 status; /* 0x14 */
- u32 dma_src_addr; /* 0x18 */
- u32 dma_dst_addr; /* 0x1c */
- u32 dma_src_len; /* 0x20 */
- u32 dma_dst_len; /* 0x24 */
- u32 rom_shadow; /* 0x28 */
- u32 reserved1[2];
- u32 unlock; /* 0x34 */
- u32 reserved2[18];
- u32 mctrl; /* 0x80 */
- u32 reserved3;
- u32 write_count; /* 0x88 */
- u32 read_count; /* 0x8c */
+struct scu_regs {
- u32 reserved1[16];
- u32 filter_start; /* 0x40 */
- u32 filter_end; /* 0x44 */
Applied to u-boot-arm/master via microblaze/mainline/arm, thanks!
Amicalement,
Hi Michal,
On Mon, 4 Feb 2013 15:36:05 +0100, Michal Simek michal.simek@xilinx.com wrote:
Amicalement,
Hi Michal,
Amicalement,
Albert ARIBAUD
Michal Simek
