[PATCH] clk: at91: sam9x60: remove the parsing of atmel, main-osc-bypass
Remove the parsing of atmel,main-osc-bypass DT property as the SAM9X60 have no support for crystal oscillator bypass. Setting this bit might affect the device functionality.
Fixes: a64862284f65 ("clk: at91: sam9x60: add support compatible with CCF") Signed-off-by: Claudiu Beznea claudiu.beznea@microchip.com --- drivers/clk/at91/sam9x60.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/clk/at91/sam9x60.c b/drivers/clk/at91/sam9x60.c index c3235f565d7e..9e9a643d62d7 100644 --- a/drivers/clk/at91/sam9x60.c +++ b/drivers/clk/at91/sam9x60.c @@ -382,7 +382,6 @@ static int sam9x60_clk_probe(struct udevice *dev) const char *p[10]; unsigned int cm[10], m[10], *tmpclkmux, *tmpmux; struct clk clk, *c; - bool main_osc_bypass; int ret, muxallocindex = 0, clkmuxallocindex = 0, i; static const struct clk_range r = { 0, 0 };
@@ -440,8 +439,6 @@ static int sam9x60_clk_probe(struct udevice *dev) if (ret) goto fail;
- main_osc_bypass = dev_read_bool(dev, "atmel,main-osc-bypass"); - /* Register main rc oscillator. */ c = at91_clk_main_rc(base, clk_names[ID_MAIN_RC_OSC], clk_names[ID_MAIN_RC]); @@ -453,7 +450,7 @@ static int sam9x60_clk_probe(struct udevice *dev)
/* Register main oscillator. */ c = at91_clk_main_osc(base, clk_names[ID_MAIN_OSC], - clk_names[ID_MAIN_XTAL], main_osc_bypass); + clk_names[ID_MAIN_XTAL], false); if (IS_ERR(c)) { ret = PTR_ERR(c); goto fail;
Applied to u-boot-atmel/master, thanks !
Claudiu Beznea
Eugen.Hristev@microchip.com
