[U-Boot] [PATCH] arc: Add support for IoT development kit
The DesignWare ARC IoT Development Kit is a versatile platform that includes the necessary hardware and software to accelerate software development and debugging of sensor fusion, voice recognition and face detection designs.
More information is avaialble here [1] and here [2].
The board is based on real silicon with ARC EM9D-based Data Fusion IP Subsystem.
It sports a rich set of I/O including * DW USB OTG * DW MobileStorage (used for micro SD-card) * GPIO * multiple serial interface including DW APB UART * ADC, PWM and eFlash, SRAM and SPI Flash memory * Real-Time Clock (RTC) * Bluetooth module with worldwide regulatory compliance (FCC, IC, CE, ETSI, TELEC) * On-board 9-axis sensor (gyro, accelerometer and compass)
Extensible with Arduino, Pmod, mikroBUS connectors and a 2x18 extension header.
One of the most interesting features for developers is built-in Digilent USB JTAG probe so only micro-USB cable is needed!
[1] https://www.synopsys.com/dw/ipdir.php?ds=arc_iot_development_kit [2] https://www.synopsys.com/dw/doc.php/ds/cc/iot_dev_kit.pdf
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- arch/arc/Kconfig | 5 + arch/arc/dts/Makefile | 1 + arch/arc/dts/iot_devkit.dts | 45 +++++++ board/synopsys/iot_devkit/Kconfig | 12 ++ board/synopsys/iot_devkit/MAINTAINERS | 5 + board/synopsys/iot_devkit/Makefile | 7 ++ board/synopsys/iot_devkit/config.mk | 2 + board/synopsys/iot_devkit/iot_devkit.c | 168 +++++++++++++++++++++++++ board/synopsys/iot_devkit/u-boot.lds | 77 ++++++++++++ configs/iot_devkit_defconfig | 38 ++++++ include/configs/iot_devkit.h | 84 +++++++++++++ 11 files changed, 444 insertions(+) create mode 100644 arch/arc/dts/iot_devkit.dts create mode 100644 board/synopsys/iot_devkit/Kconfig create mode 100644 board/synopsys/iot_devkit/MAINTAINERS create mode 100644 board/synopsys/iot_devkit/Makefile create mode 100644 board/synopsys/iot_devkit/config.mk create mode 100644 board/synopsys/iot_devkit/iot_devkit.c create mode 100644 board/synopsys/iot_devkit/u-boot.lds create mode 100644 configs/iot_devkit_defconfig create mode 100644 include/configs/iot_devkit.h
diff --git a/arch/arc/Kconfig b/arch/arc/Kconfig index d59aa3ae291e..b24593e137b3 100644 --- a/arch/arc/Kconfig +++ b/arch/arc/Kconfig @@ -157,6 +157,10 @@ config TARGET_EMDK config TARGET_HSDK bool "Support Synpsys HS DevelopmentKit board"
+config TARGET_IOT_DEVKIT + bool "Synopsys Brite IoT Development kit" + select CPU_ARCEM6 + endchoice
source "board/abilis/tb100/Kconfig" @@ -164,5 +168,6 @@ source "board/synopsys/Kconfig" source "board/synopsys/axs10x/Kconfig" source "board/synopsys/emdk/Kconfig" source "board/synopsys/hsdk/Kconfig" +source "board/synopsys/iot_devkit/Kconfig"
endmenu diff --git a/arch/arc/dts/Makefile b/arch/arc/dts/Makefile index 491a4f40bbc7..17e1405c0c48 100644 --- a/arch/arc/dts/Makefile +++ b/arch/arc/dts/Makefile @@ -6,6 +6,7 @@ dtb-$(CONFIG_TARGET_NSIM) += nsim.dtb dtb-$(CONFIG_TARGET_TB100) += abilis_tb100.dtb dtb-$(CONFIG_TARGET_EMDK) += emdk.dtb dtb-$(CONFIG_TARGET_HSDK) += hsdk.dtb +dtb-$(CONFIG_TARGET_IOT_DEVKIT) += iot_devkit.dtb
targets += $(dtb-y)
diff --git a/arch/arc/dts/iot_devkit.dts b/arch/arc/dts/iot_devkit.dts new file mode 100644 index 000000000000..ebf5a950f0f2 --- /dev/null +++ b/arch/arc/dts/iot_devkit.dts @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + */ +/dts-v1/; + +#include "skeleton.dtsi" + +/ { + #address-cells = <1>; + #size-cells = <1>; + + aliases { + console = &uart0; + }; + + cpu_card { + core_clk: core_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <144000000>; + u-boot,dm-pre-reloc; + }; + }; + + uart0: serial0@80014000 { + compatible = "snps,dw-apb-uart"; + clock-frequency = <16000000>; + reg = <0x80014000 0x1000>; + reg-shift = <2>; + reg-io-width = <4>; + }; + + usb: usb@f0040000 { + compatible = "snps,dwc2"; + reg = <0xf0040000 0x10000>; + phys = <&usbphy>; + phy-names = "usb2-phy"; + }; + + usbphy: phy { + compatible = "nop-phy"; + #phy-cells = <0>; + }; +}; diff --git a/board/synopsys/iot_devkit/Kconfig b/board/synopsys/iot_devkit/Kconfig new file mode 100644 index 000000000000..ad956b20f770 --- /dev/null +++ b/board/synopsys/iot_devkit/Kconfig @@ -0,0 +1,12 @@ +if TARGET_IOT_DEVKIT + +config SYS_BOARD + default "iot_devkit" + +config SYS_VENDOR + default "synopsys" + +config SYS_CONFIG_NAME + default "iot_devkit" + +endif diff --git a/board/synopsys/iot_devkit/MAINTAINERS b/board/synopsys/iot_devkit/MAINTAINERS new file mode 100644 index 000000000000..06457cfa6ae2 --- /dev/null +++ b/board/synopsys/iot_devkit/MAINTAINERS @@ -0,0 +1,5 @@ +IOT DEVKIT BOARD +M: Alexey Brodkin abrodkin@synopsys.com +S: Maintained +F: board/synopsys/iot_devkit/ +F: configs/iot_devkit_defconfig diff --git a/board/synopsys/iot_devkit/Makefile b/board/synopsys/iot_devkit/Makefile new file mode 100644 index 000000000000..161602464382 --- /dev/null +++ b/board/synopsys/iot_devkit/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2018 Synopsys, Inc. All rights reserved. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += iot_devkit.o diff --git a/board/synopsys/iot_devkit/config.mk b/board/synopsys/iot_devkit/config.mk new file mode 100644 index 000000000000..120733538a40 --- /dev/null +++ b/board/synopsys/iot_devkit/config.mk @@ -0,0 +1,2 @@ +PLATFORM_CPPFLAGS += -mlittle-endian -mcode-density -mdiv-rem -mswap -mnorm -mmpy-option=6 -mbarrel-shifter +LDSCRIPT = $(srctree)/board/synopsys/iot_devkit/u-boot.lds diff --git a/board/synopsys/iot_devkit/iot_devkit.c b/board/synopsys/iot_devkit/iot_devkit.c new file mode 100644 index 000000000000..c185d5cdb5cc --- /dev/null +++ b/board/synopsys/iot_devkit/iot_devkit.c @@ -0,0 +1,168 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + */ + +#include <common.h> +#include <malloc.h> +#include <dwmmc.h> +#include <linux/libfdt.h> +#include <fdtdec.h> + +#include <asm/arcregs.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define SYSCON_BASE 0xf000a000 +#define AHBCKDIV (void *)(SYSCON_BASE + 0x04) +#define APBCKDIV (void *)(SYSCON_BASE + 0x08) +#define APBCKEN (void *)(SYSCON_BASE + 0x0C) +#define CLKSEL (void *)(SYSCON_BASE + 0x24) +#define CLKSTAT (void *)(SYSCON_BASE + 0x28) +#define PLLCON (void *)(SYSCON_BASE + 0x2C) +#define APBCKSEL (void *)(SYSCON_BASE + 0x30) +#define AHBCKEN (void *)(SYSCON_BASE + 0x34) +#define USBPHY_PLL (void *)(SYSCON_BASE + 0x78) +#define USBCFG (void *)(SYSCON_BASE + 0x7c) + +#define PLL_MASK_0 0xffcfffff +#define PLL_MASK_1 0xffcfff00 +#define PLL_MASK_2 0xfbcfff00 + +#define CLKSEL_DEFAULT 0x5a690000 + +static int set_cpu_freq(unsigned int clk) +{ + clk /= 1000000; + + /* Set clk to ext Xtal (LSN value 0) */ + writel(CLKSEL_DEFAULT, CLKSEL); + + switch (clk) { + case 16: + /* Bypass mode */ + return 0; + + case 50: + writel(readl(PLLCON) & PLL_MASK_0, PLLCON); + /* pll_off=1, M=25, N=1, OD=3, PLL_OUT_CLK=50M */ + writel((readl(PLLCON) & PLL_MASK_1) | 0x300191, PLLCON); + /* pll_off=0, M=25, N=1, OD=3, PLL_OUT_CLK=50M */ + writel((readl(PLLCON) & PLL_MASK_2) | 0x300191, PLLCON); + break; + + case 72: + writel(readl(PLLCON) & PLL_MASK_0, PLLCON); + /* pll_off=1, M=18, N=1, OD=2, PLL_OUT_CLK=72M */ + writel((readl(PLLCON) & PLL_MASK_1) | 0x200121, PLLCON); + /* pll_off=0, M=18, N=1, OD=2, PLL_OUT_CLK=72M */ + writel((readl(PLLCON) & PLL_MASK_2) | 0x200121, PLLCON); + break; + + case 100: + writel(readl(PLLCON) & PLL_MASK_0, PLLCON); + /* pll_off=1,M=25, N=1, OD=2, PLL_OUT_CLK=100M */ + writel((readl(PLLCON) & PLL_MASK_1) | 0x200191, PLLCON); + /* pll_off=0,M=25, N=1, OD=2, PLL_OUT_CLK=100M */ + writel((readl(PLLCON) & PLL_MASK_2) | 0x200191, PLLCON); + break; + + case 144: + writel(readl(PLLCON) & PLL_MASK_0, PLLCON); + /* pll_off=1, M=18, N=1, OD=1, PLL_OUT_CLK=144M */ + writel((readl(PLLCON) & PLL_MASK_1) | 0x100121, PLLCON); + /* pll_off=0, M=18, N=1, OD=1, PLL_OUT_CLK=144M */ + writel((readl(PLLCON) & PLL_MASK_2) | 0x100121, PLLCON); + break; + + default: + return -EINVAL; + } + + while (!(readl(CLKSTAT) & 0x4)) + ; + + /* Set clk from PLL on bus (LSN = 1) */ + writel(CLKSEL_DEFAULT | BIT(0), CLKSEL); + + return 0; +} + +extern u8 __rom_end[]; +extern u8 __ram_start[]; +extern u8 __ram_end[]; + +/* + * Use mach_cpu_init() for .data section copy as board_early_init_f() will be + * too late: initf_dm() will use a value of "av_" variable from not yet + * initialized (by copy) area. + */ +int mach_cpu_init(void) +{ + int offset, freq; + + /* Don't relocate U-Boot */ + gd->flags |= GD_FLG_SKIP_RELOC; + + /* Copy data from ROM to RAM */ + u8 *src = __rom_end; + u8 *dst = __ram_start; + + while (dst < __ram_end) + *dst++ = *src++; + + /* Enable debug uart */ +#define DEBUG_UART_BASE 0x80014000 +#define DEBUG_UART_DLF_OFFSET 0xc0 + write_aux_reg(DEBUG_UART_BASE + DEBUG_UART_DLF_OFFSET, 1); + + offset = fdt_path_offset(gd->fdt_blob, "/cpu_card/core_clk"); + if (offset < 0) + return offset; + + freq = fdtdec_get_int(gd->fdt_blob, offset, "clock-frequency", 0); + if (!freq) + return -EINVAL; + + /* If CPU freq > 100 MHz, divide eFLASH clock by 2 */ + if (freq > 100000000) { + u32 reg = readl(AHBCKDIV); + + reg &= ~(0xF << 8); + reg |= 2 << 8; + writel(reg, AHBCKDIV); + } + + return set_cpu_freq(freq); +} + +#define ARC_PERIPHERAL_BASE 0xF0000000 +#define SDIO_BASE (ARC_PERIPHERAL_BASE + 0xB000) + +int board_mmc_init(bd_t *bis) +{ + struct dwmci_host *host = NULL; + + host = malloc(sizeof(struct dwmci_host)); + if (!host) { + printf("dwmci_host malloc fail!\n"); + return -ENOMEM; + } + + memset(host, 0, sizeof(struct dwmci_host)); + host->name = "Synopsys Mobile storage"; + host->ioaddr = (void *)SDIO_BASE; + host->buswidth = 4; + host->dev_index = 0; + host->bus_hz = 50000000; + + add_dwmci(host, host->bus_hz / 2, 400000); + + return 0; +} + +int checkboard(void) +{ + puts("Board: Synopsys IoT Development Kit\n"); + return 0; +}; diff --git a/board/synopsys/iot_devkit/u-boot.lds b/board/synopsys/iot_devkit/u-boot.lds new file mode 100644 index 000000000000..d08316870553 --- /dev/null +++ b/board/synopsys/iot_devkit/u-boot.lds @@ -0,0 +1,77 @@ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +MEMORY { + ROM : ORIGIN = ROM_BASE, LENGTH = ROM_SIZE + RAM : ORIGIN = RAM_DATA_BASE, LENGTH = RAM_DATA_SIZE +} + +OUTPUT_FORMAT("elf32-littlearc", "elf32-littlearc", "elf32-littlearc") +OUTPUT_ARCH(arc) +ENTRY(_start) +SECTIONS +{ + . = CONFIG_SYS_MONITOR_BASE; + __image_copy_start = .; + .ivt : + { + __ivt_start = .; + KEEP(*(.ivt)); + __ivt_end = .; + } > ROM + + . = ALIGN(1024); + .text : { + __text_start = .; + arch/arc/lib/start.o (.text*) + *(.text*) + __text_end = .; + } > ROM + + . = ALIGN(4); + .rodata : { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } > ROM + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + + /* Mark RAM's LMA */ + . = ALIGN(4); + __rom_end = .; + } > ROM + + .data : { + /* Mark RAM's VMA */ + . = ALIGN(4); + + /* + * Everything between __ram_start and __ram_start will be + * copied from ROM to RAM in board_early_init_f(). + */ + __ram_start = .; + + *(.data*) + + __ram_end = .; + } > RAM AT > ROM + + .bss : { + . = ALIGN(1024); + __bss_start = .; + *(.bss*) + __bss_end = .; + } > RAM + + /* Keep relocation-related symbols to make linker happy */ + __rel_dyn_start = .; + __rel_dyn_end = .; + __image_copy_end = .; + __init_end = .; +} diff --git a/configs/iot_devkit_defconfig b/configs/iot_devkit_defconfig new file mode 100644 index 000000000000..1f0f9c325676 --- /dev/null +++ b/configs/iot_devkit_defconfig @@ -0,0 +1,38 @@ +CONFIG_ARC=y +CONFIG_ISA_ARCV2=y +CONFIG_CPU_ARCEM6=y +CONFIG_SYS_ICACHE_OFF=y +CONFIG_SYS_DCACHE_OFF=y +CONFIG_TARGET_IOT_DEVKIT=y +CONFIG_SYS_TEXT_BASE=0x20000000 +CONFIG_SYS_CLK_FREQ=16000000 +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SYS_PROMPT="IoTDK# " +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_NET is not set +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_DEFAULT_DEVICE_TREE="iot_devkit" +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_DM=y +CONFIG_MMC=y +CONFIG_MMC_DW=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC2_BUFFER_SIZE=16 +CONFIG_USB_STORAGE=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=4096 diff --git a/include/configs/iot_devkit.h b/include/configs/iot_devkit.h new file mode 100644 index 000000000000..4ffe1141d922 --- /dev/null +++ b/include/configs/iot_devkit.h @@ -0,0 +1,84 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + */ + +#ifndef _CONFIG_IOT_DEVKIT_H_ +#define _CONFIG_IOT_DEVKIT_H_ + +#include <linux/sizes.h> + +/* + * MEMORY MAP + * + * eFlash: 0x0000_0000 - 0x0008_0000 (512K) + * ICCM: 0x2000_0000 - 0x2004_0000 (256K) + * SRAM: 0x3000_0000 - 0x3002_0000 (128K) + * DCCM: 0x8000_0000 - 0x8002_0000 (128K) + * Note: only data goes here, as IFQ cannot fetch instructions from DCCM + * + * + * RAM PARTITIONING + * + * +-----------+----------+---------------------+-------------+ + * | <-- Stack | .data | Malloc | Environment | + * +-----------+----------+---------------------+-------------+ + * : : : :___________/ + * : : : : | + * : : : : CONFIG_ENV_SIZE + * : : ____________________/ + * : : | + * : : CONFIG_SYS_MALLOC_LEN + * : : + * : Specified explicitly by CONFIG_SYS_INIT_SP_ADDR + * : + * Specified explicitly by CONFIG_SYS_SDRAM_BASE + * + * NOTES: + * - Stack starts from CONFIG_SYS_INIT_SP_ADDR and grows down, + * i.e. towards CONFIG_SYS_SDRAM_BASE but nothing stops it from crossing + * that CONFIG_SYS_SDRAM_BASE in which case data won't be really saved on + * stack any longer and values popped from stack will contain garbage + * leading to unexpected behavior, typically but not limited to: + * - "Returning" back to bogus caller function + * - Reading data from weird addresses + */ + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define SRAM_BASE 0x30000000 +#define SRAM_SIZE SZ_128K + +#define DCCM_BASE 0x80000000 +#define DCCM_SIZE SZ_128K + +#define CONFIG_SYS_SDRAM_BASE DCCM_BASE +#define CONFIG_SYS_SDRAM_SIZE DCCM_SIZE + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_32K) + +#define CONFIG_SYS_MALLOC_LEN SZ_64K +#define CONFIG_SYS_BOOTM_LEN SZ_128K +#define CONFIG_SYS_LOAD_ADDR SRAM_BASE + +#define ROM_BASE CONFIG_SYS_MONITOR_BASE +#define ROM_SIZE SZ_256K + +#define RAM_DATA_BASE CONFIG_SYS_INIT_SP_ADDR +#define RAM_DATA_SIZE CONFIG_SYS_SDRAM_SIZE - \ + (CONFIG_SYS_INIT_SP_ADDR - \ + CONFIG_SYS_SDRAM_BASE) - \ + CONFIG_SYS_MALLOC_LEN - \ + CONFIG_ENV_SIZE + +/* Required by DW MMC driver */ +#define CONFIG_BOUNCE_BUFFER + +/* + * Environment + */ +#define CONFIG_ENV_SIZE SZ_4K +#define CONFIG_BOOTFILE "app.bin" +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#endif /* _CONFIG_IOT_DEVKIT_H_ */
Alexey Brodkin
