[U-Boot-Users] [PATCH] HMI1001: add support for MPC5200 Rev. B processors.
Signed-off-by: Wolfgang Denk wd@denx.de --- board/hmi1001/hmi1001.c | 18 ++++++++++++++++++ 1 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/board/hmi1001/hmi1001.c b/board/hmi1001/hmi1001.c index 9fa0e74..3ecb74a 100644 --- a/board/hmi1001/hmi1001.c +++ b/board/hmi1001/hmi1001.c @@ -147,6 +147,24 @@ long int initdram (int board_type)
#endif /* CFG_RAMBOOT */
+ /* + * On MPC5200B we need to set the special configuration delay in the + * DDR controller. Please refer to Freescale's AN3221 "MPC5200B SDRAM + * Initialization and Configuration", 3.3.1 SDelay--MBAR + 0x0190: + * + * "The SDelay should be written to a value of 0x00000004. It is + * required to account for changes caused by normal wafer processing + * parameters." + */ + svr = get_svr(); + pvr = get_pvr(); + if ((SVR_MJREV(svr) >= 2) && + (PVR_MAJ(pvr) == 1) && (PVR_MIN(pvr) == 4)) { + + *(vu_long *)MPC5XXX_SDRAM_SDELAY = 0x04; + __asm__ volatile ("sync"); + } + /* return dramsize + dramsize2; */ return dramsize; }
* parameters."
- svr = get_svr();
- pvr = get_pvr();
- if ((SVR_MJREV(svr) >= 2) &&
Do we need to keep it?
return dramsize; }
Best Regards, J.
Probably not on the current hardware configuration; maybe the next one will use two banks of RAM.
Jean-Christophe PLAGNIOL-VILLARD
