[U-Boot] [PATCH] Convert CONFIG_DA8XX_GPIO to Kconfig
This converts the following to Kconfig: CONFIG_DA8XX_GPIO
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 7908cfcc34..bc704ff7bd 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DIAG=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_SYS_BOOTCOUNT_ADDR=0x01C23000 +CONFIG_DA8XX_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index c76321fb47..3223b44ba5 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_DIAG=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 6a2b7ae670..b6ec087569 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -37,6 +37,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_DM_GPIO=y +CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index f71d351ad3..9d6c47df50 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_DIAG=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y # CONFIG_MMC is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 497e5515d7..8d0aac700c 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DA8XX_GPIO=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 15c4944b3b..4256730e4c 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -33,5 +33,6 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:128k(u-boot-env),1408k(u-boot), CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_DA8XX_GPIO=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 29af22ecc7..9caa87846c 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -58,6 +58,11 @@ config ATMEL_PIO4 may be dedicated as a general purpose I/O or be assigned to a function of an embedded peripheral.
+config DA8XX_GPIO + bool "DA8xx GPIO Driver" + help + This driver supports the DA8xx GPIO controller + config INTEL_BROADWELL_GPIO bool "Intel Broadwell GPIO driver" depends on DM diff --git a/include/configs/calimain.h b/include/configs/calimain.h index ab4a9e6ddc..690f605695 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -26,7 +26,6 @@ #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) #define CONFIG_ARCH_CPU_INIT -#define CONFIG_DA8XX_GPIO #define CONFIG_HW_WATCHDOG #define CONFIG_SYS_WDTTIMERBASE DAVINCI_TIMER1_BASE #define CONFIG_SYS_WDT_PERIOD_LOW \ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 6690be60b6..a8d4894bee 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -226,7 +226,6 @@ #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ #endif
-#define CONFIG_DA8XX_GPIO /* * U-Boot general configuration */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index c84cd962d7..5e6f0c23d2 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_DA8XX_GPIO
/* * Memory Info diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index faf21ddb08..3b13798529 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -238,7 +238,6 @@ #define CONFIG_SYS_SPL_ARGS_ADDR LINUX_BOOT_PARAM_ADDR
/* GPIO support */ -#define CONFIG_DA8XX_GPIO #define CONFIG_IPAM390_GPIO_BOOTMODE ((16 * 7) + 14)
#define CONFIG_SHOW_BOOT_PROGRESS diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8ded15c89a..120212c4a6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -309,7 +309,6 @@ CONFIG_CUSTOMER_BOARD_SUPPORT CONFIG_D2NET_V2 CONFIG_DA850_AM18X_EVM CONFIG_DA850_EVM_MAX_CPU_CLK -CONFIG_DA8XX_GPIO CONFIG_DBAU1000 CONFIG_DBGU CONFIG_DBG_MONITOR
Adam Ford
