[PATCH] board: rockchip: Add support for FriendlyARM NanoPi R2C Plus
The NanoPi R2C Plus is a small variant of NanoPi R2C with a on-board eMMC flash (8G) included.
The device tree is taken from the kernel v6.5.
Signed-off-by: Tianling Shen cnsztl@gmail.com --- arch/arm/dts/Makefile | 1 + .../dts/rk3328-nanopi-r2c-plus-u-boot.dtsi | 9 ++ arch/arm/dts/rk3328-nanopi-r2c-plus.dts | 33 +++++ board/rockchip/evb_rk3328/MAINTAINERS | 6 + configs/nanopi-r2c-plus-rk3328_defconfig | 114 ++++++++++++++++++ 5 files changed, 163 insertions(+) create mode 100644 arch/arm/dts/rk3328-nanopi-r2c-plus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-nanopi-r2c-plus.dts create mode 100644 configs/nanopi-r2c-plus-rk3328_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9d28a485bec..6909f95e084 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -126,6 +126,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3308) += \ dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ rk3328-nanopi-r2c.dtb \ + rk3328-nanopi-r2c-plus.dtb \ rk3328-nanopi-r2s.dtb \ rk3328-orangepi-r1-plus.dtb \ rk3328-orangepi-r1-plus-lts.dtb \ diff --git a/arch/arm/dts/rk3328-nanopi-r2c-plus-u-boot.dtsi b/arch/arm/dts/rk3328-nanopi-r2c-plus-u-boot.dtsi new file mode 100644 index 00000000000..f8adb9e5e1f --- /dev/null +++ b/arch/arm/dts/rk3328-nanopi-r2c-plus-u-boot.dtsi @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0-or-later + +#include "rk3328-nanopi-r2c-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &emmc; + }; +}; diff --git a/arch/arm/dts/rk3328-nanopi-r2c-plus.dts b/arch/arm/dts/rk3328-nanopi-r2c-plus.dts new file mode 100644 index 00000000000..16a1958e457 --- /dev/null +++ b/arch/arm/dts/rk3328-nanopi-r2c-plus.dts @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2021 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com + */ + +/dts-v1/; +#include "rk3328-nanopi-r2c.dts" + +/ { + model = "FriendlyElec NanoPi R2C Plus"; + compatible = "friendlyarm,nanopi-r2c-plus", "rockchip,rk3328"; + + aliases { + mmc1 = &emmc; + }; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + max-frequency = <150000000>; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; + vmmc-supply = <&vcc_io_33>; + vqmmc-supply = <&vcc18_emmc>; + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index 8a19eb373d0..5fc114a63f6 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -11,6 +11,12 @@ S: Maintained F: configs/nanopi-r2c-rk3328_defconfig F: arch/arm/dts/rk3328-nanopi-r2c-u-boot.dtsi
+NANOPI-R2C-PLUS-RK3328 +M: Tianling Shen cnsztl@gmail.com +S: Maintained +F: configs/nanopi-r2c-plus-rk3328_defconfig +F: arch/arm/dts/rk3328-nanopi-r2c-plus-u-boot.dtsi + NANOPI-R2S-RK3328 M: David Bauer mail@david-bauer.net S: Maintained diff --git a/configs/nanopi-r2c-plus-rk3328_defconfig b/configs/nanopi-r2c-plus-rk3328_defconfig new file mode 100644 index 00000000000..320ed8b434a --- /dev/null +++ b/configs/nanopi-r2c-plus-rk3328_defconfig @@ -0,0 +1,114 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3328-nanopi-r2c-plus" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3328=y +CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_SPL_STACK=0x400000 +CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2c-plus.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2000000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSINFO=y +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
Hi Tianling,
- rk3328-nanopi-r2c-plus.dtb \ rk3328-nanopi-r2s.dtb \ rk3328-orangepi-r1-plus.dtb \ rk3328-orangepi-r1-plus-lts.dtb \
- chosen {
- Copyright (c) 2021 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2023 Tianling Shen cnsztl@gmail.com
- model = "FriendlyElec NanoPi R2C Plus";
- compatible = "friendlyarm,nanopi-r2c-plus", "rockchip,rk3328";
- aliases {
mmc1 = &emmc;
+&emmc {
- bus-width = <8>;
- cap-mmc-highspeed;
- max-frequency = <150000000>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- pinctrl-names = "default";
- pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>;
- vmmc-supply = <&vcc_io_33>;
- vqmmc-supply = <&vcc18_emmc>;
- status = "okay";
- NANOPI-R2S-RK3328 M: David Bauer mail@david-bauer.net S: Maintained
Did you test both TPL and SPL?
Thanks,
- Kever
Hi Kever,
On Tue, Jan 2, 2024 at 9:00 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Tianling,
chosen {
aliases {
mmc1 = &emmc;
+&emmc {
bus-width = <8>;
cap-mmc-highspeed;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
non-removable;
status = "okay";
Yes, I have confirmed both TPL and SPL are working fine.
Thanks, Tianling.
Thanks,
- Kever
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- chosen {
- aliases {
mmc1 = &emmc;
+&emmc {
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
Kever Yang
Tianling Shen
