[U-Boot] [PATCH] mpc83xx: fix 837x MDS PCI HOST build
commit 6aa3d3bfaa986f1aff5e21a9b9f68d087715b1a9 "83xx: Remove warmboot parameter from PCI init functions" missed one mpc83xx_pcie_init callsite, causing this build error:
Configuring for MPC837XEMDS_HOST board... pci.c: In function 'pci_init_board': pci.c:141: error: too many arguments to function 'mpc83xx_pcie_init'
this patch extends the commit to include that callsite.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- board/freescale/mpc837xemds/pci.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mpc837xemds/pci.c b/board/freescale/mpc837xemds/pci.c index 77c5bda..edb3ff0 100644 --- a/board/freescale/mpc837xemds/pci.c +++ b/board/freescale/mpc837xemds/pci.c @@ -138,7 +138,7 @@ skip_pci: out_be32(&pcie_law[1].bar, CONFIG_SYS_PCIE2_BASE & LAWBAR_BAR); out_be32(&pcie_law[1].ar, LBLAWAR_EN | LBLAWAR_512MB);
- mpc83xx_pcie_init(pex2 ? 1 : 2, pcie_reg, 0); + mpc83xx_pcie_init(pex2 ? 1 : 2, pcie_reg); }
void ft_pcie_fixup(void *blob, bd_t *bd)
Thanks for catching that. Should the MPC837XEMDS MAKEALL target be changed to MPC837XEMDS_HOST to include coverage of its PCI code? I tried running ./MAKEALL 83xx prior to submitting the offending change, but didn't catch this issue. Same for the MPC832XEMDS?
Regards, Peter
either that or the makeall code that uses boards.cfg could be extended to do certain board build variants...needs looking into.
the 832x mds looks ok to me.
Kim
Dear Kim Phillips,
boards.cfg is supposed to have a single line entry for each supported board configuration.
If you have several board build variants, then please use separate entries in boards.cfg for each of them (and see previous discussion about how config params should be passed).
Dear Peter Tyser,
Not needed any more. The new MAKEALL auto-generates the list of board configurations from boards.cfg, so we don't miss such cases any longer.
On Thu, 30 Sep 2010 13:40:34 -0500 Kim Phillips kim.phillips@freescale.com wrote:
applied to u-boot-mpc83xx master.
Kim
Dear Kim Phillips,
Applied directly, hope this is OK with you. Thanks.
Kim Phillips
Peter Tyser
