[U-Boot] env_mmc: Fix broken build due to set_default_env() change
Previously the function was set_default_env(void), it is now set_default_env(const char *s). This patch adds the required parameter. This fixes a broken build on OMAP4430 SDP.
Signed-off-by: Steve Sakoman steve.sakoman@linaro.org ---
diff --git a/common/env_mmc.c b/common/env_mmc.c index 14203b6..cc288d4 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -147,7 +147,6 @@ void env_relocate_spec(void) #if !defined(ENV_IS_EMBEDDED) static void use_default() { - puts ("*** Warning - bad CRC or MMC, using default environment\n\n"); - set_default_env(); + set_default_env(NULL); } #endif
Dear Steve Sakoman,
- set_default_env(NULL);
} #endif
Applied, thanks.
Steve Sakoman
