[U-Boot] [RFC PATCH] arm: zynq: read mac address from SPI flash memory
Implement a method for reading the MAC address from an SPI flash memory. In particular, this method is used by the Zybo Z7 board to read the MAC address from the OTP region in the SPI NOR memory
Signed-off-by: Luis Araneda luaraneda@gmail.com ---
I'm trying to implement the reading of the MAC address of the Zybo Z7 board from the OTP region of its SPI NOR memory.
I took some ideas from Digilent's fork, but the commit was marked as not upstremeable. That's why I'm asking for comments.
If the code can't be merged, ideas on how this can be implemented are welcome.
Thanks,
Luis Araneda.
--- board/xilinx/zynq/board.c | 28 ++++++++++++++++++++++++++++ configs/zynq_zybo_z7_defconfig | 3 +++ drivers/misc/Kconfig | 17 +++++++++++++++++ 3 files changed, 48 insertions(+)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 614d93c082..a252c38956 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -6,9 +6,12 @@
#include <common.h> #include <dm/uclass.h> +#include <dm/device.h> +#include <dm/device-internal.h> #include <fdtdec.h> #include <fpga.h> #include <mmc.h> +#include <spi_flash.h> #include <watchdog.h> #include <wdt.h> #include <zynqpl.h> @@ -87,6 +90,31 @@ int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) printf("I2C EEPROM MAC address read failed\n"); #endif
+#if defined(CONFIG_MAC_ADDR_IN_SPI_FLASH) + struct spi_flash *flash; + struct udevice *dev; + int ret; + + ret = spi_flash_probe_bus_cs(CONFIG_SF_DEFAULT_BUS, + CONFIG_SF_DEFAULT_CS, + 0, 0, &dev); + if (ret) { + printf("SPI(bus:%u cs:%u) probe failed\n", + CONFIG_SF_DEFAULT_BUS, + CONFIG_SF_DEFAULT_CS); + return 0; + } + + flash = dev_get_uclass_priv(dev); + flash->read_cmd = CONFIG_MAC_ADDR_SPI_FLASH_READ_CMD; + + if (spi_flash_read_dm(dev, + CONFIG_MAC_ADDR_SPI_FLASH_DATA_OFFSET, + 6, ethaddr)) + printf("SPI MAC address read failed\n"); + + device_remove(dev, DM_REMOVE_NORMAL); +#endif return 0; }
diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig index ad44e772aa..ca402e3231 100644 --- a/configs/zynq_zybo_z7_defconfig +++ b/configs/zynq_zybo_z7_defconfig @@ -44,6 +44,9 @@ CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y +CONFIG_MAC_ADDR_IN_SPI_FLASH=y +CONFIG_MAC_ADDR_SPI_FLASH_READ_CMD=0x4b +CONFIG_MAC_ADDR_SPI_FLASH_DATA_OFFSET=0x20 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index c031dfde9d..40cec81e66 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -272,6 +272,23 @@ config SYS_I2C_EEPROM_ADDR_OVERFLOW
endif
+config MAC_ADDR_IN_SPI_FLASH + bool "MAC address in SPI flash" + help + Read MAC address from an SPI flash memory + +if MAC_ADDR_IN_SPI_FLASH + +config MAC_ADDR_SPI_FLASH_READ_CMD + hex "Read command for the SPI flash memory" + default 0 + +config MAC_ADDR_SPI_FLASH_DATA_OFFSET + hex "Offset of MAC data in SPI flash memory" + default 0 + +endif + config GDSYS_RXAUI_CTRL bool "Enable gdsys RXAUI control driver" depends on MISC
Hi Luis, +Jagan,
I have done this code long time ago because there was a work which wasn't finished. Also upstreaming takes some time to finish.
Thanks,
Luis Araneda.
- struct spi_flash *flash;
- struct udevice *dev;
- int ret;
- ret = spi_flash_probe_bus_cs(CONFIG_SF_DEFAULT_BUS,
0, 0, &dev);
- if (ret) {
- flash = dev_get_uclass_priv(dev);
- flash->read_cmd = CONFIG_MAC_ADDR_SPI_FLASH_READ_CMD;
- if (spi_flash_read_dm(dev,
6, ethaddr))
- device_remove(dev, DM_REMOVE_NORMAL);
+#endif return 0; }
I am doing spi but isn't this any standard OTP read command which should put to spi framework.
endif
- bool "MAC address in SPI flash"
- help
- hex "Read command for the SPI flash memory"
- default 0
- hex "Offset of MAC data in SPI flash memory"
- default 0
+endif
Thanks, Michal
Implement a method for reading the MAC address from an SPI flash memory. In particular, this method is used by the Zybo Z7 board to read the MAC address from the OTP region in the SPI NOR memory [...] +#if defined(CONFIG_MAC_ADDR_IN_SPI_FLASH)
int ret;
0, 0, &dev);
if (ret) {
6, ethaddr))
+#endif return 0; }
I'm not sure if there is an standard OTP read command, they might be vendor/model specific. Jagan, is this possible currently, or might it be covered by the new SPI-mem/SPI-NAND code?
In order to keep this moving, I would like to get some specific question answered: 1: Should the final code be in the "zynq_board_read_rom_ethaddr" function like it is now? 2: On an ideal solution, should I remove the probing and read_cmd, and call a function to read from OTP at a certain offset? In that case the CONFIG_MAC_ADDR_SPI_FLASH_READ_CMD would't be necessary. 3: Is the CONFIG_MAC_ADDR_IN_SPI_FLASH an acceptable solution to enable the feature?
Thanks,
Luis Araneda.
Luis Araneda
Michal Simek
