ext2ls zero-length directory entries?
(This is a vendor-modified version of uboot 2011.03.)
I am running into problems using ext2load, the command complains that the file of interest is not found. I know it's there though since it is fine under LINUX.
Doing some poking around, I see that ext2ls is showing mostly zero length on the subdirs I am interested in loading files from -- thus the "not found" issues. Some of the directories have enormous lengths and crash uboot when attempting to list their content.
I am attempting to load from a large SATA disk partitioned into two equal-size partitions that add up to the whole disk. No problems with the first partition, the second partition has the issue.
Does this ring a bell with anyone? Perhaps it is a disk size issue and an old uboot? LINUX says the following about the disk:
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 0) ata1.00: supports DRM functions and may not be fully accessable. ata1.00: ATA-10: Micron_1100_MTFDDAK256TBN, M0MU031, max UDMA/133 ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32) ata1.00: supports DRM functions and may not be fully accessable. ata1.00: configured for UDMA/100 scsi 0:0:0:0: Direct-Access ATA Micron_1100_MTFD n/a PQ: 0 ANSI: 5 sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: sda1 sda2 sd 0:0:0:0: [sda] Attached SCSI disk
Joe Buehler
Joe Buehler
