[U-Boot] [PATCH v3 0/5] Extend FIT support for falcon boot
This patch set extends FIT support for falcon boot. The difference between U-Boot FIT and Linux FIT lies not only on the images inside, but also the data offset. U-Boot FIT image has data outside of the FIT structure while Linux FIT image can have data embedded within. Linux FIT can use compressed image as well.
Changes in v3: Replace ifdef with if IS_ENABLED(). Add help to new Kconfig optons. Update doc/uImage.FIT/source_file_format.txt with embedded and external data Update doc/uImage.FIT/multi_spl.its to explain the priority of booting image.
Changes in v2: Combine Kconfig change and actual code into one patch Rebase on top of "SPL: FIT: factor out spl_load_fit_image()" by Andre Przywara Split from previous patch, rebased on top of "SPL: FIT: allow loading multiple images" by Andre Przywara.
York Sun (5): tools: pblimage: Fix address calculation cmd: spl: Fix compiling warning spl: fit: Eanble GZIP support for image decompression spl: fit: Support both external and embedded data spl: fit: Add booting OS first
cmd/spl.c | 8 +- common/spl/spl_fit.c | 144 ++++++++++++++++++++++++---------- doc/uImage.FIT/multi_spl.its | 7 ++ doc/uImage.FIT/source_file_format.txt | 4 + lib/Kconfig | 12 +++ lib/Makefile | 5 +- tools/pblimage.c | 2 +- 7 files changed, 135 insertions(+), 47 deletions(-)
The image size should be added to the initial pbl command, not bit "ORed".
Signed-off-by: York Sun york.sun@nxp.com ---
tools/pblimage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/pblimage.c b/tools/pblimage.c index ffc3268..d25a733 100644 --- a/tools/pblimage.c +++ b/tools/pblimage.c @@ -293,7 +293,7 @@ int pblimage_check_params(struct image_tool_params *params) pbi_crc_cmd2 = 0; pbl_cmd_initaddr = params->addr & PBL_ADDR_24BIT_MASK; pbl_cmd_initaddr |= PBL_ACS_CONT_CMD; - pbl_cmd_initaddr |= uboot_size; + pbl_cmd_initaddr += uboot_size; pbl_end_cmd[0] = 0x09610000; pbl_end_cmd[1] = 0x00000000; pbl_end_cmd[2] = 0x096100c0;
Applied to fsl-qoriq master.
York
Fix warning "cast from pointer to integer of different size".
Signed-off-by: York Sun york.sun@nxp.com Reviewed-by: Tom Rini trini@konsulko.com ---
cmd/spl.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/cmd/spl.c b/cmd/spl.c index 057764a..562140a 100644 --- a/cmd/spl.c +++ b/cmd/spl.c @@ -108,12 +108,12 @@ static int spl_export(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
c = find_cmd_tbl(argv[1], &cmd_spl_export_sub[0], ARRAY_SIZE(cmd_spl_export_sub)); - if ((c) && ((int)c->cmd <= SPL_EXPORT_LAST)) { + if ((c) && ((long)c->cmd <= SPL_EXPORT_LAST)) { argc -= 2; argv += 2; - if (call_bootm(argc, argv, subcmd_list[(int)c->cmd])) + if (call_bootm(argc, argv, subcmd_list[(long)c->cmd])) return -1; - switch ((int)c->cmd) { + switch ((long)c->cmd) { #ifdef CONFIG_OF_LIBFDT case SPL_EXPORT_FDT: printf("Argument image is now in RAM: 0x%p\n", @@ -147,7 +147,7 @@ static int do_spl(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
c = find_cmd_tbl(argv[1], &cmd_spl_sub[0], ARRAY_SIZE(cmd_spl_sub)); if (c) { - cmd = (int)c->cmd; + cmd = (long)c->cmd; switch (cmd) { case SPL_EXPORT: argc--;
York
Add Kconfig option SPL_GZIP and SPL_ZLIB to enable gunzip support for SPL boot, eg. falcon boot compressed kernel image.
common/spl/spl_fit.c | 32 ++++++++++++++++++++++++++++++-- lib/Kconfig | 12 ++++++++++++ lib/Makefile | 5 +++-- 3 files changed, 45 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index d2a352e..fe41ce0 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -11,6 +11,10 @@ #include <libfdt.h> #include <spl.h>
+#ifndef CONFIG_SYS_BOOTM_LEN +#define CONFIG_SYS_BOOTM_LEN (64 << 20) +#endif + /** * spl_fit_get_image_node(): By using the matching configuration subnode, * retrieve the name of an image, specified by a property name and an index @@ -135,6 +139,19 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, ulong overhead; int nr_sectors; int align_len = ARCH_DMA_MINALIGN - 1; + uint8_t image_comp = -1, type = -1; + + if (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP)) { + if (fit_image_get_comp(fit, node, &image_comp)) + puts("Cannot get image compression format.\n"); + else + debug("%s ", genimg_get_comp_name(image_comp)); + + if (fit_image_get_type(fit, node, &type)) + puts("Cannot get image type.\n"); + else + debug("%s ", genimg_get_type_name(type)); + }
offset = fdt_getprop_u32(fit, node, "data-offset"); if (offset == FDT_ERROR) @@ -154,7 +171,7 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, if (info->read(info, sector + get_aligned_image_offset(info, offset), nr_sectors, (void*)load_ptr) != nr_sectors) return -EIO; - debug("image: dst=%lx, offset=%lx, size=%lx\n", load_ptr, offset, + debug("image dst=%lx, offset=%lx, size=%lx\n", load_ptr, offset, (unsigned long)length);
src = (void *)load_ptr + overhead; @@ -162,7 +179,18 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, board_fit_image_post_process(&src, &length); #endif
- memcpy((void*)load_addr, src, length); + if (IS_ENABLED(CONFIG_SPL_OS_BOOT) && + IS_ENABLED(CONFIG_SPL_GZIP) && + image_comp == IH_COMP_GZIP && + type == IH_TYPE_KERNEL) { + if (gunzip((void *)load_addr, CONFIG_SYS_BOOTM_LEN, + src, &length)) { + puts("Uncompressing error\n"); + return -EIO; + } + } else { + memcpy((void *)load_addr, src, length); + }
if (image_info) { image_info->load_addr = load_addr; diff --git a/lib/Kconfig b/lib/Kconfig index 2f5a210..3b5e3b4 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -160,6 +160,18 @@ config LZO bool "Enable LZO decompression support" help This enables support for LZO compression algorithm.r + +config SPL_GZIP + bool "Enable gzip decompression support for SPL build" + select SPL_ZLIB + help + This enables support for GZIP compression altorithm for SPL boot. + +config SPL_ZLIB + bool + help + This enables compression lib for SPL boot. + endmenu
config ERRNO_STR diff --git a/lib/Makefile b/lib/Makefile index eacc7d6..455cc9d 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -11,7 +11,6 @@ obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_LZO) += lzo/ -obj-$(CONFIG_ZLIB) += zlib/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_TIZEN) += tizen/ obj-$(CONFIG_FIT) += libfdt/ @@ -26,7 +25,6 @@ obj-y += crc16.o obj-$(CONFIG_ERRNO_STR) += errno_str.o obj-$(CONFIG_FIT) += fdtdec_common.o obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o -obj-$(CONFIG_GZIP) += gunzip.o obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += smbios.o obj-y += initcall.o @@ -49,6 +47,9 @@ obj-$(CONFIG_RSA) += rsa/ obj-$(CONFIG_SHA1) += sha1.o obj-$(CONFIG_SHA256) += sha256.o
+obj-$(CONFIG_$(SPL_)ZLIB) += zlib/ +obj-$(CONFIG_$(SPL_)GZIP) += gunzip.o + obj-$(CONFIG_SPL_SAVEENV) += qsort.o obj-$(CONFIG_$(SPL_)OF_LIBFDT) += libfdt/ ifneq ($(CONFIG_SPL_BUILD)$(CONFIG_SPL_OF_PLATDATA),yy)
York
SPL supports U-Boot image in FIT format which has data outside of FIT structure. This adds support for embedded data for normal FIT images.
Changes in v3: Update doc/uImage.FIT/source_file_format.txt with embedded and external data
Changes in v2: Rebase on top of "SPL: FIT: factor out spl_load_fit_image()" by Andre Przywara
common/spl/spl_fit.c | 52 ++++++++++++++++++++++------------- doc/uImage.FIT/source_file_format.txt | 4 +++ 2 files changed, 37 insertions(+), 19 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index fe41ce0..9449a22 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -132,14 +132,16 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, void *fit, ulong base_offset, int node, struct spl_image_info *image_info) { - ulong offset; + int offset; size_t length; + int len; ulong load_addr, load_ptr; void *src; ulong overhead; int nr_sectors; int align_len = ARCH_DMA_MINALIGN - 1; uint8_t image_comp = -1, type = -1; + const void *data;
if (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP)) { if (fit_image_get_comp(fit, node, &image_comp)) @@ -153,28 +155,40 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, debug("%s ", genimg_get_type_name(type)); }
- offset = fdt_getprop_u32(fit, node, "data-offset"); - if (offset == FDT_ERROR) - return -ENOENT; - offset += base_offset; - length = fdt_getprop_u32(fit, node, "data-size"); - if (length == FDT_ERROR) - return -ENOENT; - load_addr = fdt_getprop_u32(fit, node, "load"); - if (load_addr == FDT_ERROR && image_info) + if (fit_image_get_load(fit, node, &load_addr)) load_addr = image_info->load_addr; - load_ptr = (load_addr + align_len) & ~align_len;
- overhead = get_aligned_image_overhead(info, offset); - nr_sectors = get_aligned_image_size(info, length, offset); + if (!fit_image_get_data_offset(fit, node, &offset)) { + /* External data */ + offset += base_offset; + if (fit_image_get_data_size(fit, node, &len)) + return -ENOENT;
- if (info->read(info, sector + get_aligned_image_offset(info, offset), - nr_sectors, (void*)load_ptr) != nr_sectors) - return -EIO; - debug("image dst=%lx, offset=%lx, size=%lx\n", load_ptr, offset, - (unsigned long)length); + load_ptr = (load_addr + align_len) & ~align_len; + length = len; + + overhead = get_aligned_image_overhead(info, offset); + nr_sectors = get_aligned_image_size(info, length, offset); + + if (info->read(info, + sector + get_aligned_image_offset(info, offset), + nr_sectors, (void *)load_ptr) != nr_sectors) + return -EIO; + + debug("External data: dst=%lx, offset=%x, size=%lx\n", + load_ptr, offset, (unsigned long)length); + src = (void *)load_ptr + overhead; + } else { + /* Embedded data */ + if (fit_image_get_data(fit, node, &data, &length)) { + puts("Cannot get image data/size\n"); + return -ENOENT; + } + debug("Embedded data: dst=%lx, size=%lx\n", load_addr, + (unsigned long)length); + src = (void *)data; + }
- src = (void *)load_ptr + overhead; #ifdef CONFIG_SPL_FIT_IMAGE_POST_PROCESS board_fit_image_post_process(&src, &length); #endif diff --git a/doc/uImage.FIT/source_file_format.txt b/doc/uImage.FIT/source_file_format.txt index 136d3d7..3ce47ed 100644 --- a/doc/uImage.FIT/source_file_format.txt +++ b/doc/uImage.FIT/source_file_format.txt @@ -288,6 +288,10 @@ The 'data-offset' property can be substituted with 'data-position', which defines an absolute position or address as the offset. This is helpful when booting U-Boot proper before performing relocation.
+Normal kernel FIT image has data embedded within FIT structure. Normal U-Boot +image has external data. Existence of 'data-offset' can be used to identify +which format is used. + 9) Examples -----------
Please see nit below.
ulong offset;
const void *data; if (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP)) { if (fit_image_get_comp(fit, node, &image_comp))
return -ENOENT;
return -ENOENT;
/* External data */
return -ENOENT;
return -EIO;
length = len;
return -EIO;
} else {
/* Embedded data */
return -ENOENT;
src = (void *)data;
I think actually external data is normal for SPL but not for U-Boot proper. I don't know if that is worth mentioning though.
- Examples
-- 2.7.4
<snip>
I will change to "U-Boot SPL image has external data" when merging this patch.
York
<snip>
I should say "U-Boot image for SPL boot has external data".
York
York
If CONFIG_SPL_OS_BOOT is enabled, boot OS if kernel image is found in FIT structure.
--- This presums the kernel image doesn't exist in a FIT image intended for U-Boot. If kernel image normally co-exists with U-Boot and other images and user intends to boot U-Boot, this patch needs to rewrite to favor "loadables" over either "firmware" or "kernel" so user can select which image to boot.
Changes in v3: Update doc/uImage.FIT/multi_spl.its to explain the priority of booting image.
Changes in v2: Split from previous patch, rebased on top of "SPL: FIT: allow loading multiple images" by Andre Przywara.
common/spl/spl_fit.c | 60 ++++++++++++++++++++++++++++++-------------- doc/uImage.FIT/multi_spl.its | 7 ++++++ 2 files changed, 48 insertions(+), 19 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 9449a22..49ccf1c 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -222,13 +222,16 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, ulong size; unsigned long count; struct spl_image_info image_info; - int node, images, ret; + bool boot_os = false; + int node = -1; + int images, ret; int base_offset, align_len = ARCH_DMA_MINALIGN - 1; int index = 0;
/* - * Figure out where the external images start. This is the base for the - * data-offset properties in each image. + * For FIT with external data, figure out where the external images + * start. This is the base for the data-offset properties in each + * image. */ size = fdt_totalsize(fit); size = (size + 3) & ~3; @@ -247,6 +250,9 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, * * In fact the FIT has its own load address, but we assume it cannot * be before CONFIG_SYS_TEXT_BASE. + * + * For FIT with data embedded, data is loaded as part of FIT image. + * For FIT with external data, data is not loaded in this step. */ fit = (void *)((CONFIG_SYS_TEXT_BASE - size - info->bl_len - align_len) & ~align_len); @@ -264,8 +270,17 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, return -1; }
+#ifdef CONFIG_SPL_OS_BOOT + /* Find OS image first */ + node = spl_fit_get_image_node(fit, images, FIT_KERNEL_PROP, 0); + if (node < 0) + debug("No kernel image.\n"); + else + boot_os = true; +#endif /* find the U-Boot image */ - node = spl_fit_get_image_node(fit, images, "firmware", 0); + if (node < 0) + node = spl_fit_get_image_node(fit, images, "firmware", 0); if (node < 0) { debug("could not find firmware image, trying loadables...\n"); node = spl_fit_get_image_node(fit, images, "loadables", 0); @@ -287,24 +302,31 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, if (ret) return ret;
+#ifdef CONFIG_SPL_OS_BOOT + if (!fit_image_get_os(fit, node, &spl_image->os)) + debug("Image OS is %s\n", genimg_get_os_name(spl_image->os)); +#else spl_image->os = IH_OS_U_BOOT; +#endif
- /* Figure out which device tree the board wants to use */ - node = spl_fit_get_image_node(fit, images, FIT_FDT_PROP, 0); - if (node < 0) { - debug("%s: cannot find FDT node\n", __func__); - return node; - } + if (!boot_os) { + /* Figure out which device tree the board wants to use */ + node = spl_fit_get_image_node(fit, images, FIT_FDT_PROP, 0); + if (node < 0) { + debug("%s: cannot find FDT node\n", __func__); + return node; + }
- /* - * Read the device tree and place it after the image. - * Align the destination address to ARCH_DMA_MINALIGN. - */ - image_info.load_addr = spl_image->load_addr + spl_image->size; - ret = spl_load_fit_image(info, sector, fit, base_offset, node, - &image_info); - if (ret < 0) - return ret; + /* + * Read the device tree and place it after the image. + * Align the destination address to ARCH_DMA_MINALIGN. + */ + image_info.load_addr = spl_image->load_addr + spl_image->size; + ret = spl_load_fit_image(info, sector, fit, base_offset, node, + &image_info); + if (ret < 0) + return ret; + }
/* Now check if there are more images for us to load */ for (; ; index++) { diff --git a/doc/uImage.FIT/multi_spl.its b/doc/uImage.FIT/multi_spl.its index e5551d4..d43563d 100644 --- a/doc/uImage.FIT/multi_spl.its +++ b/doc/uImage.FIT/multi_spl.its @@ -4,6 +4,13 @@ * (Bogus) example FIT image description file demonstrating the usage * of multiple images loaded by the SPL. * Several binaries will be loaded at their respective load addresses. + * + * For booting U-Boot, "firmware" is searched first. If not found, "loadables" + * is used to identify images to be loaded into memory. If falcon boot is + * enabled, "kernel" is searched first. If not found, it falls back to the + * same flow as booting U-Boot. Changing image type will result skipping + * specific image. + * * Finally the one image specifying an entry point will be entered by the SPL. */
York
York Sun
