[U-Boot] [PATCH] common: env: add kconfig entry for env storage
Add Kconfig entry for ENV storage
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de Cc: Tom Rini trini@konsulko.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Stefan Roese sr@denx.de Cc: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Cc: Francois Retief fgretief@spaceteq.co.za --- common/Kconfig | 73 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 73 insertions(+)
diff --git a/common/Kconfig b/common/Kconfig index c69c141..a630924 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -158,6 +158,79 @@ config SPI_BOOT
endmenu
+menu "ENV storage media" + +config ENV_IS_IN_DATAFLASH + bool "env stored in dataflash" + help + env stored in dataflash + +config ENV_IS_IN_EEPROM + bool "env stored in eeprom" + help + env stored in eeprom + +config ENV_IS_EMBEDDED + bool "env is embedded" + help + env is embedded + +config ENV_IS_IN_FLASH + bool "env stored in flash" + help + env stored in flash + +config ENV_IS_IN_MMC + bool "env stored in sd/mmc card" + help + env stored in sd/mmc card + +config ENV_IS_IN_NAND + bool "env stored in nand flash" + help + env stored in nand flash + +config ENV_IS_IN_NVRAM + bool "env stored in nvram" + help + env stored in nvram + +config ENV_IS_IN_ONENAND + bool "env stored in onenand" + help + env stored in onenand + +config ENV_IS_IN_SATA + bool "env stored in sata" + help + env stored in sata + +config ENV_IS_IN_SPI_FLASH + bool "env stored in spi flash" + help + env stored in spi flash + +config ENV_IS_IN_FAT + bool "env stored in a fat file" + help + env stored in a fat file + +config ENV_IS_IN_UBI + bool "env stored in a ubi file" + help + env stored in a ubi file + +config ENV_IS_IN_REMOTE + bool "env stored in remote" + help + env stored in remote + +config ENV_IS_NOWHERE + bool "env is nowhere" + help + env is nowhere +endmenu + config BOOTDELAY int "delay in seconds before automatically booting" default 2
Hi Peng,
endmenu
help
Can you add a little more help detail on this? Also I suspect we should have CONFIG_ENV as well, to enable the actual environment (independent of where it is stored).
Also, can you migrate the existing configs with moveconfig? That would be a big step forward and may inspire me to move it to linker lists.
On Mon, Oct 17, 2016 at 04:17:06PM -0600, Simon Glass wrote:
Hi Peng,
endmenu
help
Yes, please add a bit more to the text.
Actually, I bet this is going to be messy enough that I'm fine running the moveconfig myself right before I merge it in.
Hello Tom,
Am 18.10.2016 um 00:55 schrieb Tom Rini:
Hi Peng,
endmenu
help
Feel free to give me the patch for running the tbot test [1], that the patch does not change binaries ...
bye, Heiko
[1] https://github.com/hsdenx/tbot/blob/master/src/tc/uboot/tc_uboot_check_kconf...
Heiko Schocher
Peng Fan
