[U-Boot] Problem wit MPC8548 TSEC ethernet and Marvell 88E1145 PHY
I'm trying to setup a new u-boot on an old STx AMC8548 board. I discovered the reason for instability I reported earlier, namely DDR's twoT_en option was not set. However, now I have a different problem.
Attempt to access the network always fails with "Got error 4" message. I can see ARP requests being broadcast to the network but nothing else happening.
The link speed is 100Mb.
STxAMC8548=> mii info PHY 0x10: OUI = 0x5043, Model = 0x0D, Rev = 0x04, 100baseT, FDX PHY 0x11: OUI = 0x5043, Model = 0x0D, Rev = 0x04, 10baseT, HDX PHY 0x12: OUI = 0x5043, Model = 0x0D, Rev = 0x04, 10baseT, HDX PHY 0x1F: OUI = 0x0000, Model = 0x00, Rev = 0x00, 1000baseX, HDX
STxAMC8548=> mii dump 0x10 0-5 0. (1140) -- PHY control register -- (8000:0000) 0.15 = 0 reset (4000:0000) 0.14 = 0 loopback (2040:0040) 0. 6,13 = b10 speed selection = 1000 Mbps (1000:1000) 0.12 = 1 A/N enable (0800:0000) 0.11 = 0 power-down (0400:0000) 0.10 = 0 isolate (0200:0000) 0. 9 = 0 restart A/N (0100:0100) 0. 8 = 1 duplex = full (0080:0000) 0. 7 = 0 collision test enable (003f:0000) 0. 5- 0 = 0 (reserved)
1. (7969) -- PHY status register -- (8000:0000) 1.15 = 0 100BASE-T4 able (4000:4000) 1.14 = 1 100BASE-X full duplex able (2000:2000) 1.13 = 1 100BASE-X half duplex able (1000:1000) 1.12 = 1 10 Mbps full duplex able (0800:0800) 1.11 = 1 10 Mbps half duplex able (0400:0000) 1.10 = 0 100BASE-T2 full duplex able (0200:0000) 1. 9 = 0 100BASE-T2 half duplex able (0100:0100) 1. 8 = 1 extended status (0080:0000) 1. 7 = 0 (reserved) (0040:0040) 1. 6 = 1 MF preamble suppression (0020:0020) 1. 5 = 1 A/N complete (0010:0000) 1. 4 = 0 remote fault (0008:0008) 1. 3 = 1 A/N able (0004:0000) 1. 2 = 0 link status (0002:0000) 1. 1 = 0 jabber detect (0001:0001) 1. 0 = 1 extended capabilities
2. (0141) -- PHY ID 1 register -- (ffff:0141) 2.15- 0 = 321 OUI portion
3. (0cd4) -- PHY ID 2 register -- (fc00:0c00) 3.15-10 = 3 OUI portion (03f0:00d0) 3. 9- 4 = 13 manufacturer part number (000f:0004) 3. 3- 0 = 4 manufacturer rev. number
4. (01e1) -- Autonegotiation advertisement register -- (8000:0000) 4.15 = 0 next page able (4000:0000) 4.14 = 0 reserved (2000:0000) 4.13 = 0 remote fault (1000:0000) 4.12 = 0 reserved (0800:0000) 4.11 = 0 asymmetric pause (0400:0000) 4.10 = 0 pause enable (0200:0000) 4. 9 = 0 100BASE-T4 able (0100:0100) 4. 8 = 1 100BASE-TX full duplex able (0080:0080) 4. 7 = 1 100BASE-TX able (0040:0040) 4. 6 = 1 10BASE-T full duplex able (0020:0020) 4. 5 = 1 10BASE-T able (001f:0001) 4. 4- 0 = 1 selector = IEEE 802.3
5. (45e1) -- Autonegotiation partner abilities register -- (8000:0000) 5.15 = 0 next page able (4000:4000) 5.14 = 1 acknowledge (2000:0000) 5.13 = 0 remote fault (1000:0000) 5.12 = 0 (reserved) (0800:0000) 5.11 = 0 asymmetric pause able (0400:0400) 5.10 = 1 pause able (0200:0000) 5. 9 = 0 100BASE-T4 able (0100:0100) 5. 8 = 1 100BASE-X full duplex able (0080:0080) 5. 7 = 1 100BASE-TX able (0040:0040) 5. 6 = 1 10BASE-T full duplex able (0020:0020) 5. 5 = 1 10BASE-T able (001f:0001) 5. 4- 0 = 1 selector = IEEE 802.3
Alex Dubov
