[U-Boot] [PATCH 0/5] ARM: integrator: Kconfig Clean up
Masahiro Yamada (5): ARM: ARM720t: remove empty asm/arch/hardware.h ARM: integrator: move board select into mach-integrator/Kconfig ARM: integrator: split board select into AP/CP select and CM select ARM: integrator: abolish CONFIG_INTEGRATOR ARM: integrator: remove CONFIG_ARCH_CINTEGRATOR
arch/arm/Kconfig | 38 ++-------- arch/arm/cpu/arm720t/start.S | 1 - arch/arm/cpu/arm946es/cpu.c | 4 +- arch/arm/include/asm/arch-arm720t/hardware.h | 17 ----- arch/arm/include/asm/arch-tegra114/hardware.h | 22 ------ arch/arm/include/asm/arch-tegra124/hardware.h | 16 ---- arch/arm/include/asm/arch-tegra20/hardware.h | 13 ---- arch/arm/include/asm/arch-tegra30/hardware.h | 22 ------ arch/arm/mach-integrator/Kconfig | 50 +++++++++++++ board/armltd/integrator/Kconfig | 103 -------------------------- configs/integratorap_cm720t_defconfig | 5 +- configs/integratorap_cm920t_defconfig | 5 +- configs/integratorap_cm926ejs_defconfig | 5 +- configs/integratorap_cm946es_defconfig | 5 +- configs/integratorcp_cm1136_defconfig | 5 +- configs/integratorcp_cm920t_defconfig | 5 +- configs/integratorcp_cm926ejs_defconfig | 5 +- configs/integratorcp_cm946es_defconfig | 5 +- include/configs/integrator-common.h | 2 - include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 1 - 21 files changed, 81 insertions(+), 249 deletions(-) delete mode 100644 arch/arm/include/asm/arch-arm720t/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra114/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra124/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra20/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra30/hardware.h create mode 100644 arch/arm/mach-integrator/Kconfig delete mode 100644 board/armltd/integrator/Kconfig
arch/arm/cpu/arm720t/start.S includes <asm/arch/hardware.h>, but the hardware.h headers of ARM720T boards are all empty.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Cc: Linus Walleij linus.walleij@linaro.org Cc: Stephen Warren swarren@nvidia.com Cc: Tom Warren twarren@nvidia.com ---
arch/arm/cpu/arm720t/start.S | 1 - arch/arm/include/asm/arch-arm720t/hardware.h | 17 ----------------- arch/arm/include/asm/arch-tegra114/hardware.h | 22 ---------------------- arch/arm/include/asm/arch-tegra124/hardware.h | 16 ---------------- arch/arm/include/asm/arch-tegra20/hardware.h | 13 ------------- arch/arm/include/asm/arch-tegra30/hardware.h | 22 ---------------------- 6 files changed, 91 deletions(-) delete mode 100644 arch/arm/include/asm/arch-arm720t/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra114/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra124/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra20/hardware.h delete mode 100644 arch/arm/include/asm/arch-tegra30/hardware.h
diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index ec8e88d..0bb3441 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -9,7 +9,6 @@
#include <asm-offsets.h> #include <config.h> -#include <asm/hardware.h>
/* ************************************************************************* diff --git a/arch/arm/include/asm/arch-arm720t/hardware.h b/arch/arm/include/asm/arch-arm720t/hardware.h deleted file mode 100644 index 8ca42d9..0000000 --- a/arch/arm/include/asm/arch-arm720t/hardware.h +++ /dev/null @@ -1,17 +0,0 @@ -#ifndef __ARM7_HW_H -#define __ARM7_HW_H - -/* - * Copyright (c) 2004 Cucy Systems (http://www.cucy.com) - * Curt Brune curt@cucy.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#if defined(CONFIG_INTEGRATOR) && defined(CONFIG_ARCH_INTEGRATOR) -/* include IntegratorCP/CM720T specific hardware file if there was one */ -#else -#error No hardware file defined for this configuration -#endif - -#endif /* __ARM7_HW_H */ diff --git a/arch/arm/include/asm/arch-tegra114/hardware.h b/arch/arm/include/asm/arch-tegra114/hardware.h deleted file mode 100644 index c21fbb6..0000000 --- a/arch/arm/include/asm/arch-tegra114/hardware.h +++ /dev/null @@ -1,22 +0,0 @@ -/* - * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. - * - * This program is free software; you can redistribute it and/or modify it - * under the terms and conditions of the GNU General Public License, - * version 2, as published by the Free Software Foundation. - * - * This program is distributed in the hope it will be useful, but WITHOUT - * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or - * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for - * more details. - * - * You should have received a copy of the GNU General Public License - * along with this program. If not, see http://www.gnu.org/licenses/. - */ - -#ifndef _TEGRA114_HARDWARE_H_ -#define _TEGRA114_HARDWARE_H_ - -/* include tegra specific hardware definitions */ - -#endif /* _TEGRA114_HARDWARE_H_ */ diff --git a/arch/arm/include/asm/arch-tegra124/hardware.h b/arch/arm/include/asm/arch-tegra124/hardware.h deleted file mode 100644 index 114fce8..0000000 --- a/arch/arm/include/asm/arch-tegra124/hardware.h +++ /dev/null @@ -1,16 +0,0 @@ -/* - * (C) Copyright 2013 - * NVIDIA Corporation <www.nvidia.com> - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _TEGRA124_HARDWARE_H_ -#define _TEGRA124_HARDWARE_H_ - -/* - * Include Tegra-specific hardware definitions - * Nothing needed currently for Tegra124 - */ - -#endif /* _TEGRA124_HARDWARE_H_ */ diff --git a/arch/arm/include/asm/arch-tegra20/hardware.h b/arch/arm/include/asm/arch-tegra20/hardware.h deleted file mode 100644 index a295894..0000000 --- a/arch/arm/include/asm/arch-tegra20/hardware.h +++ /dev/null @@ -1,13 +0,0 @@ -/* -* (C) Copyright 2010-2011 -* NVIDIA Corporation <www.nvidia.com> -* - * SPDX-License-Identifier: GPL-2.0+ -*/ - -#ifndef __TEGRA2_HW_H -#define __TEGRA2_HW_H - -/* include tegra specific hardware definitions */ - -#endif /* __TEGRA2_HW_H */ diff --git a/arch/arm/include/asm/arch-tegra30/hardware.h b/arch/arm/include/asm/arch-tegra30/hardware.h deleted file mode 100644 index b1a5aa9..0000000 --- a/arch/arm/include/asm/arch-tegra30/hardware.h +++ /dev/null @@ -1,22 +0,0 @@ -/* - * Copyright (c) 2010-2012, NVIDIA CORPORATION. All rights reserved. - * - * This program is free software; you can redistribute it and/or modify it - * under the terms and conditions of the GNU General Public License, - * version 2, as published by the Free Software Foundation. - * - * This program is distributed in the hope it will be useful, but WITHOUT - * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or - * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for - * more details. - * - * You should have received a copy of the GNU General Public License - * along with this program. If not, see http://www.gnu.org/licenses/. - */ - -#ifndef _TEGRA30_HARDWARE_H_ -#define _TEGRA30_HARDWARE_H_ - -/* include tegra specific hardware definitions */ - -#endif /* _TEGRA30-HARDWARE_H_ */
The board/SoC select menu in arch/arm/Kconfig is still cluttered. Add ARCH_INTEGRATOR into arch/arm/Kconfig and move the board select under arch/arm/mach-integrator.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Cc: Linus Walleij linus.walleij@linaro.org ---
arch/arm/Kconfig | 38 ++---------- arch/arm/mach-integrator/Kconfig | 57 ++++++++++++++++++ board/armltd/integrator/Kconfig | 103 -------------------------------- configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + include/configs/integratorap.h | 1 - 12 files changed, 70 insertions(+), 137 deletions(-) create mode 100644 arch/arm/mach-integrator/Kconfig delete mode 100644 board/armltd/integrator/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ac7a11b..8046d3e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -61,18 +61,6 @@ config SEMIHOSTING choice prompt "Target select"
-config TARGET_INTEGRATORAP_CM720T - bool "Support integratorap_cm720t" - select CPU_ARM720T - -config TARGET_INTEGRATORAP_CM920T - bool "Support integratorap_cm920t" - select CPU_ARM920T - -config TARGET_INTEGRATORCP_CM920T - bool "Support integratorcp_cm920t" - select CPU_ARM920T - config ARCH_AT91 bool "Atmel AT91"
@@ -92,14 +80,6 @@ config TARGET_SMDK2410 bool "Support smdk2410" select CPU_ARM920T
-config TARGET_INTEGRATORAP_CM926EJS - bool "Support integratorap_cm926ejs" - select CPU_ARM926EJS - -config TARGET_INTEGRATORCP_CM926EJS - bool "Support integratorcp_cm926ejs" - select CPU_ARM926EJS - config TARGET_ASPENITE bool "Support aspenite" select CPU_ARM926EJS @@ -247,10 +227,6 @@ config ARCH_VERSATILE bool "ARM Ltd. Versatile family" select CPU_ARM926EJS
-config TARGET_INTEGRATORCP_CM1136 - bool "Support integratorcp_cm1136" - select CPU_ARM1136 - config TARGET_IMX31_PHYCORE bool "Support imx31_phycore" select CPU_ARM1136 @@ -299,14 +275,6 @@ config ARCH_BCM283X select DM_SERIAL select DM_GPIO
-config TARGET_INTEGRATORAP_CM946ES - bool "Support integratorap_cm946es" - select CPU_ARM946ES - -config TARGET_INTEGRATORCP_CM946ES - bool "Support integratorcp_cm946es" - select CPU_ARM946ES - config TARGET_VEXPRESS_CA15_TC2 bool "Support vexpress_ca15_tc2" select CPU_V7 @@ -461,6 +429,9 @@ config ARCH_HIGHBANK bool "Calxeda Highbank" select CPU_V7
+config ARCH_INTEGRATOR + bool "ARM Ltd. Integrator family" + config ARCH_KEYSTONE bool "TI Keystone" select CPU_V7 @@ -789,6 +760,8 @@ source "arch/arm/cpu/armv7/exynos/Kconfig"
source "arch/arm/mach-highbank/Kconfig"
+source "arch/arm/mach-integrator/Kconfig" + source "arch/arm/mach-keystone/Kconfig"
source "arch/arm/mach-kirkwood/Kconfig" @@ -835,7 +808,6 @@ source "board/Marvell/aspenite/Kconfig" source "board/Marvell/db-mv784mp-gp/Kconfig" source "board/Marvell/gplugd/Kconfig" source "board/armadeus/apf27/Kconfig" -source "board/armltd/integrator/Kconfig" source "board/armltd/vexpress/Kconfig" source "board/armltd/vexpress64/Kconfig" source "board/bachmann/ot1200/Kconfig" diff --git a/arch/arm/mach-integrator/Kconfig b/arch/arm/mach-integrator/Kconfig new file mode 100644 index 0000000..4406399 --- /dev/null +++ b/arch/arm/mach-integrator/Kconfig @@ -0,0 +1,57 @@ +menu "Integrator Options" + depends on ARCH_INTEGRATOR + +choice + prompt "ARM Ltd. Integrator board select" + +config TARGET_INTEGRATORAP_CM720T + bool "Support integratorap_cm720t" + select CPU_ARM720T + +config TARGET_INTEGRATORAP_CM920T + bool "Support integratorap_cm920t" + select CPU_ARM920T + +config TARGET_INTEGRATORCP_CM920T + bool "Support integratorcp_cm920t" + select CPU_ARM920T + +config TARGET_INTEGRATORAP_CM926EJS + bool "Support integratorap_cm926ejs" + select CPU_ARM926EJS + +config TARGET_INTEGRATORCP_CM926EJS + bool "Support integratorcp_cm926ejs" + select CPU_ARM926EJS + +config TARGET_INTEGRATORCP_CM1136 + bool "Support integratorcp_cm1136" + select CPU_ARM1136 + +config TARGET_INTEGRATORAP_CM946ES + bool "Support integratorap_cm946es" + select CPU_ARM946ES + +config TARGET_INTEGRATORCP_CM946ES + bool "Support integratorcp_cm946es" + select CPU_ARM946ES + +endchoice + +config SYS_BOARD + default "integrator" + +config SYS_VENDOR + default "armltd" + +config SYS_CONFIG_NAME + default "integratorap" if TARGET_INTEGRATORAP_CM720T || \ + TARGET_INTEGRATORAP_CM920T || \ + TARGET_INTEGRATORAP_CM926EJS || \ + TARGET_INTEGRATORAP_CM946ES + default "integratorcp" if TARGET_INTEGRATORCP_CM920T || \ + TARGET_INTEGRATORCP_CM926EJS || \ + TARGET_INTEGRATORCP_CM946ES || \ + TARGET_INTEGRATORCP_CM1136 + +endmenu diff --git a/board/armltd/integrator/Kconfig b/board/armltd/integrator/Kconfig deleted file mode 100644 index 6153b5d..0000000 --- a/board/armltd/integrator/Kconfig +++ /dev/null @@ -1,103 +0,0 @@ -if TARGET_INTEGRATORAP_CM720T - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorap" - -endif - -if TARGET_INTEGRATORAP_CM920T - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorap" - -endif - -if TARGET_INTEGRATORCP_CM920T - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorcp" - -endif - -if TARGET_INTEGRATORAP_CM926EJS - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorap" - -endif - -if TARGET_INTEGRATORCP_CM926EJS - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorcp" - -endif - -if TARGET_INTEGRATORCP_CM1136 - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorcp" - -endif - -if TARGET_INTEGRATORAP_CM946ES - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorap" - -endif - -if TARGET_INTEGRATORCP_CM946ES - -config SYS_BOARD - default "integrator" - -config SYS_VENDOR - default "armltd" - -config SYS_CONFIG_NAME - default "integratorcp" - -endif diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 0bb7b08..5c15d57 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM720T" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORAP_CM720T=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index fb925d5..d2a9a71 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM920T" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORAP_CM920T=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 308a1e6..af4cfa5 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM926EJ_S" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORAP_CM926EJS=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index d1b9db5..ee07206 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM946ES" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORAP_CM946ES=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 3feb656..5deedc8 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM1136" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORCP_CM1136=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index f304bbe..5ed8539 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM920T" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORCP_CM920T=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index a8d762b..4840ec4 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM924EJ_S" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORCP_CM926EJS=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index 2e67dbc..dcd034d 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -1,3 +1,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CM946ES" CONFIG_ARM=y +CONFIG_ARCH_INTEGRATOR=y CONFIG_TARGET_INTEGRATORCP_CM946ES=y diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index e168c8c..8439db7 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -18,7 +18,6 @@ #include "integrator-common.h"
/* Integrator/AP-specific configuration */ -#define CONFIG_ARCH_INTEGRATOR #define CONFIG_SYS_HZ_CLOCK 24000000 /* Timer 1 is clocked at 24Mhz */
Select integrator boards by the combination of platform select (AP/CP) and core module select (CM720T, CM920T, ...).
This allows us to remove CONFIG_SYS_EXTRA_OPTIONS and make Kconfig much cleaner.
arch/arm/mach-integrator/Kconfig | 57 +++++++++++++++------------------ configs/integratorap_cm720t_defconfig | 4 +-- configs/integratorap_cm920t_defconfig | 4 +-- configs/integratorap_cm926ejs_defconfig | 4 +-- configs/integratorap_cm946es_defconfig | 4 +-- configs/integratorcp_cm1136_defconfig | 4 +-- configs/integratorcp_cm920t_defconfig | 4 +-- configs/integratorcp_cm926ejs_defconfig | 4 +-- configs/integratorcp_cm946es_defconfig | 4 +-- 9 files changed, 41 insertions(+), 48 deletions(-)
diff --git a/arch/arm/mach-integrator/Kconfig b/arch/arm/mach-integrator/Kconfig index 4406399..6794660 100644 --- a/arch/arm/mach-integrator/Kconfig +++ b/arch/arm/mach-integrator/Kconfig @@ -2,40 +2,39 @@ menu "Integrator Options" depends on ARCH_INTEGRATOR
choice - prompt "ARM Ltd. Integrator board select" + prompt "Integrator platform select"
-config TARGET_INTEGRATORAP_CM720T - bool "Support integratorap_cm720t" - select CPU_ARM720T +config ARCH_INTEGRATOR_AP + bool "Support Integrator/AP platform"
-config TARGET_INTEGRATORAP_CM920T - bool "Support integratorap_cm920t" - select CPU_ARM920T +config ARCH_INTEGRATOR_CP + bool "Support Integrator/CP platform"
-config TARGET_INTEGRATORCP_CM920T - bool "Support integratorcp_cm920t" - select CPU_ARM920T +endchoice
-config TARGET_INTEGRATORAP_CM926EJS - bool "Support integratorap_cm926ejs" - select CPU_ARM926EJS +choice + prompt "Integrator core module select"
-config TARGET_INTEGRATORCP_CM926EJS - bool "Support integratorcp_cm926ejs" - select CPU_ARM926EJS +config CM720T + bool "Core Module for ARM720T" + select CPU_ARM720T
-config TARGET_INTEGRATORCP_CM1136 - bool "Support integratorcp_cm1136" - select CPU_ARM1136 +config CM920T + bool "Core Module for ARM920T" + select CPU_ARM920T
-config TARGET_INTEGRATORAP_CM946ES - bool "Support integratorap_cm946es" - select CPU_ARM946ES +config CM926EJ_S + bool "Core Module for ARM926EJ-STM" + select CPU_ARM926EJS
-config TARGET_INTEGRATORCP_CM946ES - bool "Support integratorcp_cm946es" +config CM946ES + bool "Core Module for ARM946E-STM" select CPU_ARM946ES
+config CM1136 + bool "Core Module for ARM1136JF-STM" + select CPU_ARM1136 + endchoice
config SYS_BOARD @@ -45,13 +44,7 @@ config SYS_VENDOR default "armltd"
config SYS_CONFIG_NAME - default "integratorap" if TARGET_INTEGRATORAP_CM720T || \ - TARGET_INTEGRATORAP_CM920T || \ - TARGET_INTEGRATORAP_CM926EJS || \ - TARGET_INTEGRATORAP_CM946ES - default "integratorcp" if TARGET_INTEGRATORCP_CM920T || \ - TARGET_INTEGRATORCP_CM926EJS || \ - TARGET_INTEGRATORCP_CM946ES || \ - TARGET_INTEGRATORCP_CM1136 + default "integratorap" if ARCH_INTEGRATOR_AP + default "integratorcp" if ARCH_INTEGRATOR_CP
endmenu diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 5c15d57..fc0dc67 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM720T" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORAP_CM720T=y +CONFIG_ARCH_INTEGRATOR_AP=y +CONFIG_CM720T=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index d2a9a71..eb6afb9 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM920T" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORAP_CM920T=y +CONFIG_ARCH_INTEGRATOR_AP=y +CONFIG_CM920T=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index af4cfa5..8667fcb 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM926EJ_S" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORAP_CM926EJS=y +CONFIG_ARCH_INTEGRATOR_AP=y +CONFIG_CM926EJ_S=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index ee07206..1e8c157 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM946ES" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORAP_CM946ES=y +CONFIG_ARCH_INTEGRATOR_AP=y +CONFIG_CM946ES=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 5deedc8..f039470 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM1136" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORCP_CM1136=y +CONFIG_ARCH_INTEGRATOR_CP=y +CONFIG_CM1136=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index 5ed8539..cb364a1 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM920T" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORCP_CM920T=y +CONFIG_ARCH_INTEGRATOR_CP=y +CONFIG_CM920T=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index 4840ec4..32ea7b9 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM924EJ_S" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORCP_CM926EJS=y +CONFIG_ARCH_INTEGRATOR_CP=y +CONFIG_CM926EJ_S=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index dcd034d..e7fc706 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -1,4 +1,4 @@ -CONFIG_SYS_EXTRA_OPTIONS="CM946ES" CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y -CONFIG_TARGET_INTEGRATORCP_CM946ES=y +CONFIG_ARCH_INTEGRATOR_CP=y +CONFIG_CM946ES=y
Switch to CONFIG_ARCH_INTEGRATOR defined by Kconfig.
arch/arm/cpu/arm946es/cpu.c | 4 ++-- include/configs/integrator-common.h | 2 -- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm946es/cpu.c b/arch/arm/cpu/arm946es/cpu.c index e20e5a8..5d864b9 100644 --- a/arch/arm/cpu/arm946es/cpu.c +++ b/arch/arm/cpu/arm946es/cpu.c @@ -53,7 +53,7 @@ static void cache_flush (void) asm ("mcr p15, 0, %0, c7, c6, 0": :"r" (i)); }
-#ifndef CONFIG_INTEGRATOR +#ifndef CONFIG_ARCH_INTEGRATOR
__attribute__((noreturn)) void reset_cpu(ulong addr __attribute__((unused))) { @@ -63,4 +63,4 @@ __attribute__((noreturn)) void reset_cpu(ulong addr __attribute__((unused))) ; }
-#endif /* #ifdef CONFIG_INTEGRATOR */ +#endif /* #ifdef CONFIG_ARCH_INTEGRATOR */ diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 4362925..12c7382 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -7,8 +7,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#define CONFIG_INTEGRATOR - #define CONFIG_SYS_TEXT_BASE 0x01000000 #define CONFIG_SYS_MEMTEST_START 0x100000 #define CONFIG_SYS_MEMTEST_END 0x10000000
This macro is not referenced at all.
include/configs/integratorcp.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index 7c1ef24..7518b60 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -18,7 +18,6 @@ #include "integrator-common.h"
/* Integrator CP-specific configuration */ -#define CONFIG_ARCH_CINTEGRATOR #define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer 1 is clocked at 1Mhz */
On Tue, Apr 21, 2015 at 5:12 AM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
NACK sorry what happened here?
$ git grep CONFIG_ARCH_CINTEGRATOR board/armltd/integrator/integrator.c:#ifdef CONFIG_ARCH_CINTEGRATOR board/armltd/integrator/integrator.c:#ifdef CONFIG_ARCH_CINTEGRATOR board/armltd/integrator/timer.c:#ifdef CONFIG_ARCH_CINTEGRATOR board/armltd/integrator/timer.c:#ifdef CONFIG_ARCH_CINTEGRATOR
I also need this #define for a CONFIG_DM patch where I have to select whether PL010 or PL011 is used in the board file.
Yours, Linus Walleij
2015-04-21 21:06 GMT+09:00 Linus Walleij linus.walleij@linaro.org:
I do not know either. I was crazy...
I have just posted v2. Sorry.
Linus Walleij
Masahiro Yamada
