[U-Boot] [RFC 1/1] efi_loader: usage of cleanup_before_linux()
Always call cleanup_before_linux() on ARM 32bit during ExitBootServices().
This fixes a problem problem for booting BSD on ARM 32bit.
Reported-by: Jonathan Gray jsg@jsg.id.au Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 13 +------------ 1 file changed, 1 insertion(+), 12 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 4f6e8d1679..171f485f6b 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -39,14 +39,6 @@ LIST_HEAD(efi_register_notify_events); /* Handle of the currently executing image */ static efi_handle_t current_image;
-/* - * If we're running on nasty systems (32bit ARM booting into non-EFI Linux) - * we need to do trickery with caches. Since we don't want to break the EFI - * aware boot path, only apply hacks when loading exiting directly (breaking - * direct Linux EFI booting along the way - oh well). - */ -static bool efi_is_direct_boot = true; - #ifdef CONFIG_ARM /* * The "gd" pointer lives in a register on ARM and AArch64 that we declare @@ -1916,8 +1908,7 @@ static void efi_exit_caches(void) * Grub on 32bit ARM needs to have caches disabled before jumping into * a zImage, but does not know of all cache layers. Give it a hand. */ - if (efi_is_direct_boot) - cleanup_before_linux(); + cleanup_before_linux(); #endif }
@@ -2893,8 +2884,6 @@ efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle, if (ret != EFI_SUCCESS) return EFI_EXIT(EFI_INVALID_PARAMETER);
- efi_is_direct_boot = false; - image_obj->exit_data_size = exit_data_size; image_obj->exit_data = exit_data;
-- 2.20.1
NAK. Instead this should never call cleanup_before_linux() and we declare ourselves incompatible to old grub versions. That way we don't lure others into believing you could boot with caches disabled in a UEFI world.
Alex
- If we're running on nasty systems (32bit ARM booting into non-EFI Linux)
- we need to do trickery with caches. Since we don't want to break the EFI
- aware boot path, only apply hacks when loading exiting directly (breaking
- direct Linux EFI booting along the way - oh well).
- The "gd" pointer lives in a register on ARM and AArch64 that we declare
- cleanup_before_linux(); #endif }
-- 2.20.1
Agreed.
This is my fault by the way, for merging a loader in GRUB that was designed to be used without the linux EFI stub (way, waaaay back). Feel free to shout.
As of GRUB 2.04 release (and cherry-picked into debian Buster before that), the 32-bit and 64-bit UEFI ports use the same loader.
/ Leif
On Thu, Jul 18, 2019 at 9:47 PM Leif Lindholm leif.lindholm@linaro.org wrote:
Agreed.
Do you have a reference to this patch set handy?
Peter
I figured it might be good to write a proper summary and collect this info somewhere, so I just posted that to: https://lists.linaro.org/pipermail/cross-distro/2019-July/000933.html
/ Leif
On Fri, Jul 19, 2019 at 9:51 AM Leif Lindholm leif.lindholm@linaro.org wrote:
Seen it, awesome, thanks
Alexander Graf
Leif Lindholm
Peter Robinson
