[U-Boot] [PATCH 1/2] sunxi: Add generic defconfigs for A23 Q8 tablets with 800x480 LCD
The 7" Q8 tablet enclosure is used for a ton of slightly different cheap chinese tablets. There are some differences in which accelerometer / wifi is used, but other then that these are all the same from a u-boot / kernel pov.
When we get to adding accelerometer support the plan is to add some kind of autodetection and mangle the dt accordingly (likely using the new quirks mechanism).
For now this is a non issue as we do not yet have accelerometer support, and in the future, some sort of auto-detect is the way to go as we cannot expect users to exactly know what is inside their tablet.
The dts files this commit adds are identical to the ones submitted to the upstream kernel.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-a23-q8-tablet.dts | 65 +++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 1 + configs/q8_a23_tablet_800x480_defconfig | 25 +++++++++++++ 4 files changed, 93 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-a23-q8-tablet.dts create mode 100644 configs/q8_a23_tablet_800x480_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b51c4c6..6a053cc 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -154,7 +154,8 @@ dtb-$(CONFIG_MACH_SUN8I_A23) += \ sun8i-a23-evb.dtb \ sun8i-a23-gt90h-v4.dtb \ sun8i-a23-ippo-q8h-v5.dtb \ - sun8i-a23-ippo-q8h-v1.2.dtb + sun8i-a23-ippo-q8h-v1.2.dtb \ + sun8i-a23-q8-tablet.dtb dtb-$(CONFIG_MACH_SUN8I_A33) += \ sun8i-a33-et-q8-v1.6.dtb \ sun8i-a33-ga10h-v1.1.dtb \ diff --git a/arch/arm/dts/sun8i-a23-q8-tablet.dts b/arch/arm/dts/sun8i-a23-q8-tablet.dts new file mode 100644 index 0000000..6062ea7 --- /dev/null +++ b/arch/arm/dts/sun8i-a23-q8-tablet.dts @@ -0,0 +1,65 @@ +/* + * Copyright 2015 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-a23.dtsi" +#include "sun8i-q8-common.dtsi" + +/ { + model = "Q8 A23 Tablet"; + compatible = "allwinner,q8-a23", "allwinner,sun8i-a23"; +}; + +/* + * FIXME for now we only support host mode and rely on u-boot to have + * turned on Vbus which is controlled by the axp223 pmic on the board. + * + * Once we have axp223 support we should switch to fully supporting otg. + */ +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index f7a837a..67a9d29 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -50,6 +50,7 @@ F: configs/ga10h_v1_1_defconfig F: configs/gt90h_v4_defconfig F: configs/Ippo_q8h_v1_2_defconfig F: configs/Ippo_q8h_v1_2_a33_1024x600_defconfig +F: configs/q8_a23_tablet_800x480_defconfig F: configs/q8_a33_tablet_800x480_defconfig F: configs/q8_a33_tablet_1024x600_defconfig F: include/configs/sun9i.h diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig new file mode 100644 index 0000000..00c30dc --- /dev/null +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -0,0 +1,25 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_A23=y +CONFIG_DRAM_CLK=432 +CONFIG_DRAM_ZQ=63306 +CONFIG_MMC0_CD_PIN="PB4" +CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" +CONFIG_USB0_ID_DET="PH8" +CONFIG_AXP_GPIO=y +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:15,ri:211,up:10,lo:22,hs:30,vs:13,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 +CONFIG_VIDEO_LCD_POWER="PH7" +CONFIG_VIDEO_LCD_BL_EN="PH6" +CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_AXP221_DLDO1_VOLT=3300 +CONFIG_AXP221_ALDO1_VOLT=3000 +CONFIG_USB_MUSB_HOST=y
We now have generic q8_a?3_defconfig files for Q8 formfactor tablets with an A13 / A23 / A33 SoC, there is no need for these PCB variant specific defconfig-s and they only serve to confuse the user.
Note that in case of the forfun_q88db_defconfig and TZX-Q8-713B7_defconfig for A13 based Q8 tablets there is not even a dts file for these in the upstream kernel, which is all the more reason to remove them.
The generic q8_a?3_defconfig files have been tested on an Et_q8_v1_6, Ippo_q8h_v1_2_a33_1024x600, Ippo_q8h_v1_2 and TZX-Q8-713B7 tablet, and the forfun_q88db_defconfig is identical to q8_a13_tablet_defconfig.
This leaves only the Ippo_q8h_v5 untested with the new generic defconfigs but there is no reason to assume that it will not work.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- Note this patch is intended for u-boot v2016.01, not v2015.10, the plan is to remove this defconfigs from v2016.01 and then at some date after v2016.01 has been released remove the matching dts files from the kernel. --- arch/arm/dts/Makefile | 6 -- arch/arm/dts/sun5i-a13-forfun-q88db.dts | 29 ------ arch/arm/dts/sun5i-a13-tzx-q8-713b7.dts | 29 ------ arch/arm/dts/sun8i-a23-ippo-q8h-v1.2.dts | 54 ----------- arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts | 136 --------------------------- arch/arm/dts/sun8i-a33-et-q8-v1.6.dts | 88 ----------------- arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts | 133 -------------------------- board/sunxi/MAINTAINERS | 22 ----- configs/Et_q8_v1_6_defconfig | 23 ----- configs/Ippo_q8h_v1_2_a33_1024x600_defconfig | 24 ----- configs/Ippo_q8h_v1_2_defconfig | 24 ----- configs/Ippo_q8h_v5_defconfig | 24 ----- configs/TZX-Q8-713B7_defconfig | 21 ----- configs/forfun_q88db_defconfig | 20 ---- 14 files changed, 633 deletions(-) delete mode 100644 arch/arm/dts/sun5i-a13-forfun-q88db.dts delete mode 100644 arch/arm/dts/sun5i-a13-tzx-q8-713b7.dts delete mode 100644 arch/arm/dts/sun8i-a23-ippo-q8h-v1.2.dts delete mode 100644 arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts delete mode 100644 arch/arm/dts/sun8i-a33-et-q8-v1.6.dts delete mode 100644 arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts delete mode 100644 configs/Et_q8_v1_6_defconfig delete mode 100644 configs/Ippo_q8h_v1_2_a33_1024x600_defconfig delete mode 100644 configs/Ippo_q8h_v1_2_defconfig delete mode 100644 configs/Ippo_q8h_v5_defconfig delete mode 100644 configs/TZX-Q8-713B7_defconfig delete mode 100644 configs/forfun_q88db_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6a053cc..3538553 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -107,14 +107,12 @@ dtb-$(CONFIG_MACH_SUN5I) += \ sun5i-a10s-r7-tv-dongle.dtb \ sun5i-a10s-wobo-i5.dtb \ sun5i-a13-ampe-a76.dtb \ - sun5i-a13-forfun-q88db.dtb \ sun5i-a13-hsg-h702.dtb \ sun5i-a13-inet-86vs.dtb \ sun5i-a13-inet-98v-rev2.dtb \ sun5i-a13-olinuxino.dtb \ sun5i-a13-olinuxino-micro.dtb \ sun5i-a13-q8-tablet.dtb \ - sun5i-a13-tzx-q8-713b7.dtb \ sun5i-a13-utoo-p66.dtb \ sun5i-r8-chip.dtb dtb-$(CONFIG_MACH_SUN6I) += \ @@ -153,13 +151,9 @@ dtb-$(CONFIG_MACH_SUN7I) += \ dtb-$(CONFIG_MACH_SUN8I_A23) += \ sun8i-a23-evb.dtb \ sun8i-a23-gt90h-v4.dtb \ - sun8i-a23-ippo-q8h-v5.dtb \ - sun8i-a23-ippo-q8h-v1.2.dtb \ sun8i-a23-q8-tablet.dtb dtb-$(CONFIG_MACH_SUN8I_A33) += \ - sun8i-a33-et-q8-v1.6.dtb \ sun8i-a33-ga10h-v1.1.dtb \ - sun8i-a33-ippo-q8h-v1.2.dtb \ sun8i-a33-q8-tablet.dtb \ sun8i-a33-sinlinx-sina33.dtb dtb-$(CONFIG_MACH_SUN9I) += \ diff --git a/arch/arm/dts/sun5i-a13-forfun-q88db.dts b/arch/arm/dts/sun5i-a13-forfun-q88db.dts deleted file mode 100644 index 24de86c..0000000 --- a/arch/arm/dts/sun5i-a13-forfun-q88db.dts +++ /dev/null @@ -1,29 +0,0 @@ -/* - * Copyright 2015 Hans de Goede hdegoede@redhat.com - * - * Minimal dts file for the Forfun Q88db for u-boot only - * - * SPDX-License-Identifier: GPL-2.0+ or X11 - */ - -/dts-v1/; -#include "sun5i-a13.dtsi" - -/ { - model = "Forfun Q88db"; - compatible = "forfun,q88db", "allwinner,sun5i-a13"; - - aliases { - serial0 = &uart1; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1_pins_b>; - status = "okay"; -}; diff --git a/arch/arm/dts/sun5i-a13-tzx-q8-713b7.dts b/arch/arm/dts/sun5i-a13-tzx-q8-713b7.dts deleted file mode 100644 index 47f630e..0000000 --- a/arch/arm/dts/sun5i-a13-tzx-q8-713b7.dts +++ /dev/null @@ -1,29 +0,0 @@ -/* - * Copyright 2015 Hans de Goede hdegoede@redhat.com - * - * Minimal dts file for the TZX Q8 713b7 for u-boot only - * - * SPDX-License-Identifier: GPL-2.0+ or X11 - */ - -/dts-v1/; -#include "sun5i-a13.dtsi" - -/ { - model = "TZX Q8 713b7"; - compatible = "tzx,q8-713b7", "allwinner,sun5i-a13"; - - aliases { - serial0 = &uart1; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1_pins_b>; - status = "okay"; -}; diff --git a/arch/arm/dts/sun8i-a23-ippo-q8h-v1.2.dts b/arch/arm/dts/sun8i-a23-ippo-q8h-v1.2.dts deleted file mode 100644 index 382d64c..0000000 --- a/arch/arm/dts/sun8i-a23-ippo-q8h-v1.2.dts +++ /dev/null @@ -1,54 +0,0 @@ -/* - * Copyright 2015 Hans de Goede hdegoede@redhat.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/* - * The Ippo Q8H v1.2 is almost identical to the v5, still it needs a separate - * dtb file since some gpio-s surrounding the wlan/bluetooth are different, - * and it uses different camera sensors. - */ - -#include "sun8i-a23-ippo-q8h-v5.dts" - -/ { - model = "Ippo Q8H Dual Core Tablet (v1.2)"; - compatible = "ippo,q8h-v1.2", "allwinner,sun8i-a23"; -}; diff --git a/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts b/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts deleted file mode 100644 index 8d9da68..0000000 --- a/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts +++ /dev/null @@ -1,136 +0,0 @@ -/* - * Copyright 2014 Chen-Yu Tsai - * - * Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; -#include "sun8i-a23.dtsi" -#include "sunxi-common-regulators.dtsi" - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> - -/ { - model = "Ippo Q8H Dual Core Tablet (v5)"; - compatible = "ippo,q8h-v5", "allwinner,sun8i-a23"; - - aliases { - serial0 = &r_uart; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins_a>; - status = "okay"; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_a>; - status = "okay"; -}; - -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - /* pull-ups and devices require PMIC regulator */ - status = "failed"; -}; - -&lradc { - vref-supply = <®_vcc3v0>; - status = "okay"; - - button@200 { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - channel = <0>; - voltage = <200000>; - }; - - button@400 { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - channel = <0>; - voltage = <400000>; - }; -}; - -&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_q8h>; - vmmc-supply = <®_vcc3v0>; - bus-width = <4>; - cd-gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; /* PB4 */ - cd-inverted; - status = "okay"; -}; - -&pio { - mmc0_cd_pin_q8h: mmc0_cd_pin@0 { - allwinner,pins = "PB4"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; - }; -}; - -&r_uart { - pinctrl-names = "default"; - pinctrl-0 = <&r_uart_pins_a>; - status = "okay"; -}; - -&usb_otg { - dr_mode = "host"; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; diff --git a/arch/arm/dts/sun8i-a33-et-q8-v1.6.dts b/arch/arm/dts/sun8i-a33-et-q8-v1.6.dts deleted file mode 100644 index 19db844..0000000 --- a/arch/arm/dts/sun8i-a33-et-q8-v1.6.dts +++ /dev/null @@ -1,88 +0,0 @@ -/* - * Copyright 2015 Vishnu Patekar - * Vishnu Patekar vishnupatekar0510@gmail.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; -#include "sun8i-a33.dtsi" -#include "sunxi-common-regulators.dtsi" - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> - -/ { - model = "ET Q8 Quad Core Tablet (v1.6)"; - compatible = "et,q8-v1.6", "allwinner,sun8i-a33"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&lradc { - vref-supply = <®_vcc3v0>; - status = "okay"; - - button@200 { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - channel = <0>; - voltage = <200000>; - }; - - button@400 { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - channel = <0>; - voltage = <400000>; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; - status = "okay"; -}; diff --git a/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts b/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts deleted file mode 100644 index a438975..0000000 --- a/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts +++ /dev/null @@ -1,133 +0,0 @@ -/* - * Copyright 2015 Hans de Goede hdegoede@redhat.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; -#include "sun8i-a33.dtsi" -#include "sunxi-common-regulators.dtsi" - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> - -/ { - model = "Ippo Q8H Quad Core Tablet (v1.2)"; - compatible = "ippo,a33-q8h-v1.2", "allwinner,sun8i-a33"; - - aliases { - serial0 = &r_uart; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins_a>; - status = "okay"; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_a>; - status = "okay"; -}; - -&lradc { - vref-supply = <®_vcc3v0>; - status = "okay"; - - button@200 { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - channel = <0>; - voltage = <200000>; - }; - - button@400 { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - channel = <0>; - voltage = <400000>; - }; -}; - -&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_q8h>; - vmmc-supply = <®_vcc3v0>; - bus-width = <4>; - cd-gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; /* PB4 */ - cd-inverted; - status = "okay"; -}; - -&pio { - mmc0_cd_pin_q8h: mmc0_cd_pin@0 { - allwinner,pins = "PB4"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; - }; -}; - -&r_uart { - pinctrl-names = "default"; - pinctrl-0 = <&r_uart_pins_a>; - status = "okay"; -}; - -/* - * FIXME for now we only support host mode and rely on u-boot to have - * turned on Vbus which is controlled by the axp223 pmic on the board. - * - * Once we have axp223 support we should switch to fully supporting otg. - */ -&usb_otg { - dr_mode = "host"; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 67a9d29..c6371ea 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -48,8 +48,6 @@ F: configs/Wits_Pro_A20_DKT_defconfig F: include/configs/sun8i.h F: configs/ga10h_v1_1_defconfig F: configs/gt90h_v4_defconfig -F: configs/Ippo_q8h_v1_2_defconfig -F: configs/Ippo_q8h_v1_2_a33_1024x600_defconfig F: configs/q8_a23_tablet_800x480_defconfig F: configs/q8_a33_tablet_800x480_defconfig F: configs/q8_a33_tablet_1024x600_defconfig @@ -94,16 +92,6 @@ F: include/configs/sun7i.h F: configs/Cubieboard2_defconfig F: configs/Cubietruck_defconfig
-ET Q8 V1.6 Tablet BOARD -M: VishnuPatekar vishnupatekar0510@gmail.com -S: Maintained -F: configs/Et_q8_v1_6_defconfig - -FORFUN-Q88DB TABLET -M: Jens Lucius info@jenslucius.com -S: Maintained -F: configs/forfun_q88db_defconfig - GEMEI-G9 TABLET M: Priit Laes plaes@plaes.org S: Maintained @@ -129,11 +117,6 @@ M: Michal Suchanek hramrach@gmail.com S: Maintained F: configs/iNet_86VS_defconfig
-IPPO-Q8H-V5 BOARD -M: Chen-Yu Tsai wens@csie.org -S: Maintained -F: configs/Ippo_q8h_v5_defconfig - LINKSPRITE-PCDUINO BOARD M: Zoltan Herpai wigyori@uid0.hu S: Maintained @@ -185,11 +168,6 @@ S: Maintained F: configs/Sinlinx_SinA33_defconfig W: http://linux-sunxi.org/Sinlinx_SinA33
-TZX-Q8-713B7 BOARD -M: Paul Kocialkowski contact@paulk.fr -S: Maintained -F: configs/TZX-Q8-713B7_defconfig - WEXLER-TAB7200 BOARD M: Aleksei Mamlin mamlinav@gmail.com S: Maintained diff --git a/configs/Et_q8_v1_6_defconfig b/configs/Et_q8_v1_6_defconfig deleted file mode 100644 index 65b8e1a..0000000 --- a/configs/Et_q8_v1_6_defconfig +++ /dev/null @@ -1,23 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_SUNXI=y -CONFIG_MACH_SUN8I_A33=y -CONFIG_DRAM_CLK=480 -CONFIG_DRAM_ZQ=15291 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" -CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" -CONFIG_AXP_GPIO=y -CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:168,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" -CONFIG_VIDEO_LCD_DCLK_PHASE=0 -CONFIG_VIDEO_LCD_POWER="PH7" -CONFIG_VIDEO_LCD_BL_EN="PH6" -CONFIG_VIDEO_LCD_BL_PWM="PH0" -CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-et-q8-v1.6" -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -CONFIG_AXP221_DLDO1_VOLT=3300 -CONFIG_AXP221_ALDO1_VOLT=3000 -CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig b/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig deleted file mode 100644 index 40ccf8f..0000000 --- a/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig +++ /dev/null @@ -1,24 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_SUNXI=y -CONFIG_MACH_SUN8I_A33=y -CONFIG_DRAM_CLK=480 -CONFIG_DRAM_ZQ=15291 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" -CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" -CONFIG_USB0_ID_DET="PH8" -CONFIG_AXP_GPIO=y -CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:51000,le:159,ri:160,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" -CONFIG_VIDEO_LCD_DCLK_PHASE=0 -CONFIG_VIDEO_LCD_POWER="PH7" -CONFIG_VIDEO_LCD_BL_EN="PH6" -CONFIG_VIDEO_LCD_BL_PWM="PH0" -CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ippo-q8h-v1.2" -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -CONFIG_AXP221_DLDO1_VOLT=3300 -CONFIG_AXP221_ALDO1_VOLT=3000 -CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ippo_q8h_v1_2_defconfig b/configs/Ippo_q8h_v1_2_defconfig deleted file mode 100644 index 5b49c44..0000000 --- a/configs/Ippo_q8h_v1_2_defconfig +++ /dev/null @@ -1,24 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_SUNXI=y -CONFIG_MACH_SUN8I_A23=y -CONFIG_DRAM_CLK=432 -CONFIG_DRAM_ZQ=63306 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" -CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" -CONFIG_USB0_ID_DET="PH8" -CONFIG_AXP_GPIO=y -CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:167,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" -CONFIG_VIDEO_LCD_DCLK_PHASE=0 -CONFIG_VIDEO_LCD_POWER="PH7" -CONFIG_VIDEO_LCD_BL_EN="PH6" -CONFIG_VIDEO_LCD_BL_PWM="PH0" -CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-ippo-q8h-v1.2" -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -CONFIG_AXP221_DLDO1_VOLT=3300 -CONFIG_AXP221_ALDO1_VOLT=3000 -CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ippo_q8h_v5_defconfig b/configs/Ippo_q8h_v5_defconfig deleted file mode 100644 index 5316860..0000000 --- a/configs/Ippo_q8h_v5_defconfig +++ /dev/null @@ -1,24 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_SUNXI=y -CONFIG_MACH_SUN8I_A23=y -CONFIG_DRAM_CLK=480 -CONFIG_DRAM_ZQ=63351 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" -CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" -CONFIG_USB0_ID_DET="PH8" -CONFIG_AXP_GPIO=y -CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:168,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" -CONFIG_VIDEO_LCD_DCLK_PHASE=0 -CONFIG_VIDEO_LCD_POWER="PH7" -CONFIG_VIDEO_LCD_BL_EN="PH6" -CONFIG_VIDEO_LCD_BL_PWM="PH0" -CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-ippo-q8h-v5" -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -CONFIG_AXP221_DLDO1_VOLT=3300 -CONFIG_AXP221_ALDO1_VOLT=3000 -CONFIG_USB_MUSB_HOST=y diff --git a/configs/TZX-Q8-713B7_defconfig b/configs/TZX-Q8-713B7_defconfig deleted file mode 100644 index f5e3574..0000000 --- a/configs/TZX-Q8-713B7_defconfig +++ /dev/null @@ -1,21 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_SUNXI=y -CONFIG_MACH_SUN5I=y -CONFIG_DRAM_CLK=408 -CONFIG_MMC0_CD_PIN="PG0" -CONFIG_USB0_VBUS_PIN="PG12" -CONFIG_USB0_VBUS_DET="PG1" -CONFIG_AXP_GPIO=y -# CONFIG_VIDEO_HDMI is not set -CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" -CONFIG_VIDEO_LCD_POWER="AXP0-0" -CONFIG_VIDEO_LCD_BL_EN="AXP0-1" -CONFIG_VIDEO_LCD_BL_PWM="PB2" -CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-tzx-q8-713b7" -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,AXP209_POWER" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -CONFIG_USB_MUSB_HOST=y diff --git a/configs/forfun_q88db_defconfig b/configs/forfun_q88db_defconfig deleted file mode 100644 index 30e0937..0000000 --- a/configs/forfun_q88db_defconfig +++ /dev/null @@ -1,20 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_SUNXI=y -CONFIG_MACH_SUN5I=y -CONFIG_DRAM_CLK=384 -CONFIG_USB0_VBUS_PIN="PG12" -CONFIG_USB0_VBUS_DET="PG1" -CONFIG_AXP_GPIO=y -# CONFIG_VIDEO_HDMI is not set -CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" -CONFIG_VIDEO_LCD_POWER="AXP0-0" -CONFIG_VIDEO_LCD_BL_EN="AXP0-1" -CONFIG_VIDEO_LCD_BL_PWM="PB2" -CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-forfun-q88db" -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,AXP209_POWER" -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -CONFIG_USB_MUSB_HOST=y
Note that in case of the forfun_q88db_defconfig and TZX-Q8 -713B7_defconfig for A13 based Q8 tablets there is not even a dts file for these in the upstream kernel, which is all the more reason to remove them.
Sounds reasonable. both patches in this series: Acked-by: Ian Campbell ian.campbell@citrix.com
Thanks, I've taken the liberty of using your hellion email address for this instead.
Regards,
Hans
Right, finger macros, sorry ;-)
Hans de Goede
Ian Campbell
